-   Jeep Builds (http://www.jeepforum.com/forum/f22/)
-   -   Project Stay out of the Pines. (http://www.jeepforum.com/forum/f22/project-stay-out-pines-1035544/)
MuddyJeepZJ 05-19-2010 09:03 PM
Going to be a build with tons of pics of the long arm build up on a TJ. All work is designed, cut, welded, fabricated, etc by Joe from EndlessMtnFab EndlessMtnFab
Originally Posted by EndlessMtnFab
Bolting on a long arm kit can generally be done in a weekend. Properly designing & building a suspension takes time. Although not an "easy" task, most folks with a bit of knowledge and skill can build a long arm and wheel it. But it takes a little extra effort to set one up for suitable street driving.
8.8 axle Pre-Removal
http://i55.photobucket.com/albums/g1...e/P1010204.jpg
http://i55.photobucket.com/albums/g1...e/P1010207.jpg
8.8 Removal
http://i55.photobucket.com/albums/g1...e/P1010210.jpg
http://i55.photobucket.com/albums/g1...e/P1010236.jpg
http://i55.photobucket.com/albums/g1...e/P1010237.jpg
http://i55.photobucket.com/albums/g1...e/P1010238.jpg
Ballistic Fab Brackets
http://i55.photobucket.com/albums/g1...e/P1010209.jpg
8.8 truss Mock-up
http://i55.photobucket.com/albums/g1...e/P1010190.jpg
http://i55.photobucket.com/albums/g1...e/P1010191.jpg
http://i55.photobucket.com/albums/g1...e/P1010192.jpg
http://i55.photobucket.com/albums/g1...e/P1010193.jpg
http://i55.photobucket.com/albums/g1...e/P1010196.jpg
http://i55.photobucket.com/albums/g1...e/P1010197.jpg
http://i55.photobucket.com/albums/g1...e/P1010198.jpg
http://i55.photobucket.com/albums/g1...e/P1010201.jpg
MuddyJeepZJ 05-19-2010 09:04 PM
231 Transfer Case Upgrade/Rebuild
Ryan is also up against some driveline angle issues. His tucked skid, combined with 4.5 inch springs leaves him with a drivesshaft angle of 22 and a pinion angle of 19. The average 1310 CV maxes out at roughly 25 and Ryan is currently using 18 so far. This doesn't leave sufficient amount for droop. In fact .... the CV binds before the coils can fully unseat. The solution we are considering is a clearanced 1350 Setup to allow for greater strength AND flex. A clearanced 1350 generally offers 32-35 of movement.
http://i55.photobucket.com/albums/g1...e/P1010202.jpg
http://i55.photobucket.com/albums/g1...e/P1010203.jpg
http://i55.photobucket.com/albums/g1...e/P1010206.jpg
http://i55.photobucket.com/albums/g1...e/P1010233.jpg
http://i55.photobucket.com/albums/g1...e/P1010234.jpg
http://i55.photobucket.com/albums/g1...e/P1010235.jpg
Rear Coil Relocation
http://i55.photobucket.com/albums/g1...e/P1010211.jpg
http://i55.photobucket.com/albums/g1...e/P1010212.jpg
http://i55.photobucket.com/albums/g1...e/P1010214.jpg
http://i55.photobucket.com/albums/g1...e/P1010215.jpg
http://i55.photobucket.com/albums/g1...e/P1010216.jpg
http://i55.photobucket.com/albums/g1...e/P1010219.jpg
http://i55.photobucket.com/albums/g1...e/P1010220.jpg
http://i55.photobucket.com/albums/g1...e/P1010221.jpg
http://i55.photobucket.com/albums/g1...e/P1010223.jpg
http://i55.photobucket.com/albums/g1...e/P1010224.jpg
http://i55.photobucket.com/albums/g1...e/P1010225.jpg
http://i55.photobucket.com/albums/g1...e/P1010226.jpg
http://i55.photobucket.com/albums/g1...e/P1010228.jpg
http://i55.photobucket.com/albums/g1...e/P1010229.jpg
MuddyJeepZJ 05-19-2010 09:05 PM
http://i55.photobucket.com/albums/g1...e/P1010230.jpg
Frame Repair
In regards to the repair .... both sides will be cut out equally. The passenger side damage is not as extensive as the driver side; however, I do see random spots of soft/pocked metal and will be pro-active in the repair. The patch will be .125 plate and will be "frenched" into the cuts. Once welded, I will grind everything flush and plate over with a larger piece to ensure sufficient overlap. The overlapping plate will be perimeter & plug welded.
http://i55.photobucket.com/albums/g1...J/aa374ebb.jpg
http://i55.photobucket.com/albums/g1...J/ced16c37.jpg
http://i55.photobucket.com/albums/g1...J/8a42d9e0.jpg
http://i55.photobucket.com/albums/g1...e/P1010239.jpg
http://i55.photobucket.com/albums/g1...e/P1010246.jpg
http://i55.photobucket.com/albums/g1...e/P1010247.jpg
http://i55.photobucket.com/albums/g1...e/P1010248.jpg
http://i55.photobucket.com/albums/g1...e/P1010249.jpg
http://i55.photobucket.com/albums/g1...e/P1010250.jpg
http://i55.photobucket.com/albums/g1...e/P1010252.jpg
http://i55.photobucket.com/albums/g1...e/P1010253.jpg
http://i55.photobucket.com/albums/g1...e/P1010254.jpg
http://i55.photobucket.com/albums/g1...e/P1010255.jpg
http://i55.photobucket.com/albums/g1...e/P1010258.jpg
http://i55.photobucket.com/albums/g1...e/P1010259.jpg
http://i55.photobucket.com/albums/g1...e/P1010260.jpg
http://i55.photobucket.com/albums/g1...e/P1010261.jpg
MuddyJeepZJ 05-24-2010 09:28 PM
8.8 Bracket Removal and Truss Build
http://i55.photobucket.com/albums/g1...e/P1010262.jpg
http://i55.photobucket.com/albums/g1...e/P1010263.jpg
http://i55.photobucket.com/albums/g1...e/P1010264.jpg
http://i55.photobucket.com/albums/g1...e/P1010265.jpg
http://i55.photobucket.com/albums/g1...e/P1010266.jpg
http://i55.photobucket.com/albums/g1...e/P1010267.jpg
http://i55.photobucket.com/albums/g1...e/P1010270.jpg
http://i55.photobucket.com/albums/g1...e/P1010273.jpg
http://i55.photobucket.com/albums/g1...e/P1010274.jpg
http://i55.photobucket.com/albums/g1...e/P1010275.jpg
http://i55.photobucket.com/albums/g1...e/P1010277.jpg
http://i55.photobucket.com/albums/g1...e/P1010279.jpg
http://i55.photobucket.com/albums/g1...e/P1010280.jpg
http://i55.photobucket.com/albums/g1...e/P1010281.jpg
MuddyJeepZJ 05-24-2010 09:29 PM
http://i55.photobucket.com/albums/g1...e/P1010282.jpg
http://i55.photobucket.com/albums/g1...e/P1010283.jpg
http://i55.photobucket.com/albums/g1...e/P1010285.jpg
http://i55.photobucket.com/albums/g1...e/P1010287.jpg
http://i55.photobucket.com/albums/g1...e/P1010288.jpg
http://i55.photobucket.com/albums/g1...e/P1010290.jpg
http://i55.photobucket.com/albums/g1...e/P1010291.jpg
http://i55.photobucket.com/albums/g1...e/P1010292.jpg
http://i55.photobucket.com/albums/g1...e/P1010293.jpg
http://i55.photobucket.com/albums/g1...e/P1010294.jpg
http://i55.photobucket.com/albums/g1...e/P1010296.jpg
http://i55.photobucket.com/albums/g1...e/P1010297.jpg
http://i55.photobucket.com/albums/g1...e/P1010298.jpg
http://i55.photobucket.com/albums/g1...e/P1010299.jpg
MuddyJeepZJ 05-25-2010 08:49 PM
Finishing up the Rear truss.
http://i55.photobucket.com/albums/g1...e/P1010300.jpg
http://i55.photobucket.com/albums/g1...e/P1010301.jpg
Bent to attach to truss
http://i55.photobucket.com/albums/g1...e/P1010304.jpg
Welded into place
http://i55.photobucket.com/albums/g1...e/P1010305.jpg
http://i55.photobucket.com/albums/g1...e/P1010306.jpg
ABS Sensor Removal and hole filled
http://i55.photobucket.com/albums/g1...e/P1010307.jpg
http://i55.photobucket.com/albums/g1...e/P1010309.jpg
http://i55.photobucket.com/albums/g1...e/P1010310.jpg
http://i55.photobucket.com/albums/g1...e/P1010312.jpg
http://i55.photobucket.com/albums/g1...e/P1010315.jpg
Lower Control Arm Brackets
http://i55.photobucket.com/albums/g1...e/P1010317.jpg
http://i55.photobucket.com/albums/g1...e/P1010318.jpg
http://i55.photobucket.com/albums/g1...e/P1010320.jpg
http://i55.photobucket.com/albums/g1...e/P1010321.jpg
MuddyJeepZJ 05-31-2010 06:52 PM
8.8 Breather tube relocation
http://i55.photobucket.com/albums/g1...e/P1010323.jpg
http://i55.photobucket.com/albums/g1...e/P1010327.jpg
http://i55.photobucket.com/albums/g1...e/P1010328.jpg
Truss Welded Up
http://i55.photobucket.com/albums/g1...e/P1010330.jpg
http://i55.photobucket.com/albums/g1...e/P1010332.jpg
http://i55.photobucket.com/albums/g1...e/P1010333.jpg
LCA mounted on Axle
http://i55.photobucket.com/albums/g1...e/P1010334.jpg
http://i55.photobucket.com/albums/g1...e/P1010335.jpg
Hendrix 05-31-2010 06:58 PM
Thats some great work so far. Crawled
littledevilTJ 05-31-2010 07:24 PM
damn thats a lot of rust!!!
MuddyJeepZJ 05-31-2010 08:18 PM
Yeah I was shocked myself. Hence the name of the thread. The amount of rusted off pieces of metal along with sand inside he frame was amazing.
MuddyJeepZJ 05-31-2010 08:20 PM
Cross Member Round #1 using 2x5 steel
http://i55.photobucket.com/albums/g1...e/P1010336.jpg
http://i55.photobucket.com/albums/g1...e/P1010339.jpg
http://i55.photobucket.com/albums/g1...e/P1010340.jpg
http://i55.photobucket.com/albums/g1...e/P1010347.jpg
http://i55.photobucket.com/albums/g1...e/P1010348.jpg
http://i55.photobucket.com/albums/g1...e/P1010352.jpg
After making the proper height allowances to clear the transfer case and allow access to remove the nuts and bolts it was determined that the 2x5 piece of metal had far too much movement for our liking and we decided to move on to another idea.
Threaded bungs being inserted into frame rail for cross member to attach to
http://i55.photobucket.com/albums/g1...e/P1010337.jpg
http://i55.photobucket.com/albums/g1...e/P1010341.jpg
http://i55.photobucket.com/albums/g1...e/P1010343.jpg
http://i55.photobucket.com/albums/g1...e/P1010344.jpg
http://i55.photobucket.com/albums/g1...e/P1010345.jpg
http://i55.photobucket.com/albums/g1...e/P1010346.jpg
http://i55.photobucket.com/albums/g1...e/P1010349.jpg
http://i55.photobucket.com/albums/g1...e/P1010350.jpg
http://i55.photobucket.com/albums/g1...e/P1010351.jpg
http://i55.photobucket.com/albums/g1...e/P1010353.jpg
Cross Member Round 2 using 1/4" flat steel
http://i55.photobucket.com/albums/g1...e/P1010354.jpg
http://i55.photobucket.com/albums/g1...e/P1010355.jpg
Save a Horse ride a band saw!
http://i55.photobucket.com/albums/g1...e/P1010356.jpg
Cutting the UCA brackets out of 2x5
http://i55.photobucket.com/albums/g1...e/P1010357.jpg
MuddyJeepZJ 05-31-2010 08:22 PM
http://i55.photobucket.com/albums/g1...e/P1010358.jpg
http://i55.photobucket.com/albums/g1...e/P1010359.jpg
http://i55.photobucket.com/albums/g1...e/P1010360.jpg
Rear cross member mocked up with LCA and UCA brackets in place.
Additional bracing will be coming after final fitment as well.
MuddyJeepZJ 06-06-2010 08:10 PM
Cross Member Round #2
http://i55.photobucket.com/albums/g1...e/P1010361.jpg
http://i55.photobucket.com/albums/g1...e/P1010362.jpg
http://i55.photobucket.com/albums/g1...e/P1010363.jpg
http://i55.photobucket.com/albums/g1...e/P1010364.jpg
http://i55.photobucket.com/albums/g1...e/P1010365.jpg
http://i55.photobucket.com/albums/g1...e/P1010366.jpg
http://i55.photobucket.com/albums/g1...e/P1010367.jpg
http://i55.photobucket.com/albums/g1...e/P1010368.jpg
http://i55.photobucket.com/albums/g1...e/P1010369.jpg
http://i55.photobucket.com/albums/g1...e/P1010370.jpg
http://i55.photobucket.com/albums/g1...e/P1010371.jpg
http://i55.photobucket.com/albums/g1...e/P1010372.jpg
MuddyJeepZJ 06-24-2010 08:38 PM
Getting close to the back being complete.
http://i55.photobucket.com/albums/g1...e/P1010412.jpg
http://i55.photobucket.com/albums/g1...e/P1010413.jpg
http://i55.photobucket.com/albums/g1...e/P1010414.jpg
http://i55.photobucket.com/albums/g1...e/P1010415.jpg
http://i55.photobucket.com/albums/g1...e/P1010416.jpg
http://i55.photobucket.com/albums/g1...e/P1010417.jpg
http://i55.photobucket.com/albums/g1...e/P1010419.jpg
http://i55.photobucket.com/albums/g1...e/P1010420.jpg
http://i55.photobucket.com/albums/g1...e/P1010421.jpg
http://i55.photobucket.com/albums/g1...e/P1010422.jpg
http://i55.photobucket.com/albums/g1...e/P1010423.jpg
http://i55.photobucket.com/albums/g1...e/P1010424.jpg
http://i55.photobucket.com/albums/g1...e/P1010425.jpg
http://i55.photobucket.com/albums/g1...e/P1010426.jpg
http://i55.photobucket.com/albums/g1...e/P1010427.jpg
http://i55.photobucket.com/albums/g1...e/P1010428.jpg
MuddyJeepZJ 06-25-2010 09:38 PM
Ford Shock Mounts
http://i55.photobucket.com/albums/g1...e/P1010429.jpg
http://i55.photobucket.com/albums/g1...e/P1010431.jpg
http://i55.photobucket.com/albums/g1...e/P1010432.jpg
http://i55.photobucket.com/albums/g1...e/P1010433.jpg
http://i55.photobucket.com/albums/g1...e/P1010435.jpg
http://i55.photobucket.com/albums/g1...e/P1010436.jpg
The time now is 05:07 AM.
