Project (s)Low - '94 LCOG Build - Page 7 - JeepForum.com
post #91 of 277 Old 02-16-2011, 11:06 AM
Big4mike9
Have you taken your lift/tire combo wheeling yet? If so, how do you like it so far? Wish you went higher?
93 YJ.......Under Construction
Big4mike9 is offline
post #92 of 277 Old 02-16-2011, 01:59 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Yup, went wheeling twice in the fall just before winter. Both times it performed flawlessly. I only bottomed out on my frame once, and that was on a single rock that stuck up pretty far. I rubbed a tiny bit on the left rear causing the corner to be bent a little, but that is on an untrimmed fender opening and no bumpstops.
I am open/open and never got stuck on either trip as well.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #93 of 277 Old 02-16-2011, 02:02 PM
Big4mike9
So wish you went bigger? Or happy where your at?
post #94 of 277 Old 02-16-2011, 02:14 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Very happy with the stance. Off camber situations I felt just fine, solid as a rock. One wrangler in our group was on ~8" and 36" TSLs nearly went head over heels on a rock climb where I just kinda slid sideways.
I'm going to try and keep the height as is or maybe a smidge higher to eventually get to 40's on 1 tons.
-Matt
White '94 YJ Sport
UltimatE is offline
post #95 of 277 Old 02-16-2011, 02:20 PM
Big4mike9
Nice. Thanks ultimate.
post #96 of 277 Old 02-20-2011, 02:04 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Mounted up my rear TJ flares ... Finally got pulled over for being flareless in central MA (6 months of driving without them heh) Hopefully that'll keep the fuzz of my tail for now. I still need to make and/or buy front flat fenders to make that legal, as I cut the hell out of them going flat. No where to mount the front TJ flares.
-Matt
White '94 YJ Sport
UltimatE is offline
post #97 of 277 Old 02-20-2011, 03:08 PM
autoboy454
you did half the cutting for front tube fenders. get something bent up so you can run a 3" flare front tube fender. Just my opinion
Love to wheel? Live in/around Massachusetts? Check us out!
autoboy454 is offline
post #98 of 277 Old 03-16-2011, 01:59 PM
RustedYJ
Love the look so far. Subscribed.
RustedYJ is offline
post #99 of 277 Old 03-17-2011, 02:48 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Thanks!
Took off the hard top today, drove around topless. 56* and sunny =]
-Matt
White '94 YJ Sport
UltimatE is offline
post #100 of 277 Old 03-17-2011, 05:18 PM
Louie4
Sweet. I'm going to take the hardtop off for my wheeling trip. Should be sunny and 80+ degrees.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #101 of 277 Old 04-05-2011, 02:16 PM
sacrifice
Just read through your build. Love everything about it. Not sure if you said it or not but what front bumper is that?
granny shifting not double clutchin like I should
'89 YJ Build Thread:
WhyJayPA's '88 Build: http://www.jeepforum.com/forum/f22/mean-green-build-college-budget-1164650/
sacrifice is offline
post #102 of 277 Old 04-05-2011, 05:50 PM
Unii
probably a fabtech, trail gear has one just like it but with 2 extra bars on the front.
Unii is offline
post #103 of 277 Old 04-05-2011, 07:13 PM
YJames90
YJames90's Avatar
Awesome build. What the distance from the ground to the bottom on the rocker panel?
YJames90 is offline
post #104 of 277 Old 04-29-2011, 03:10 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
25" to the rocker panel.
Doing a once-over of the Jeep, poking, prodding, checking things out today. Found 2 more holes in the tub. Found a 6" long hole of rust in the frame between the fuel filter mount and the frame side mount (Rear left leaf spring). Another smaller hole above the right rear shock mount, and the mount itself is starting to rust off.
Not sure what I'm gonna do. So much rust on this thing...
-Matt
White '94 YJ Sport
UltimatE is offline
post #105 of 277 Old 04-29-2011, 03:44 PM
SDGBASSE
The usual : throw all the money you had on the side at it and fix it. no but seriously, if you have good welding skills, I'd try to fix it, would be a waste to get rid of it.....
Originally Posted by ZeroGravity View Post
I didn't click the link because it says "power probe" in the url.
SDGBASSE is offline
Anyone doing a LCOG YJ build? Jay-P YJ Wrangler Technical Forum 103 04-11-2014 10:12 AM
Super Duper Pete's White Russian Buildathon neverhide34 Jeep Builds 146 12-21-2012 04:29 PM
LJ LCOG build, questions on springs,bumpstops,improving articulation etc.... GMBNT42 TJ Wrangler Technical Forum 4 08-06-2011 04:22 PM
LCOG Build!!! inglisleslie TJ Wrangler Technical Forum 57 04-14-2010 11:38 AM
Project Green Monkey...a.k.a. Project Empty Pockets - '97 TJ Sport build thread Poobah TJ Wrangler Technical Forum 20 12-14-2008 08:30 PM
