Project (s)Low - '94 LCOG Build - Page 16 - JeepForum.com
post #226 of 275 Old 01-13-2013, 05:44 PM
CDW_327
Originally Posted by zte87
Yeah that looks great, now to decide arched or overlines haha!
So does this mean your getting rid of your MCE flat fenders?
CDW_327 is offline
post #227 of 275 Old 01-13-2013, 06:46 PM
zte87
GIVE IT THE ONION
zte87's Avatar
Yeap
zte87 is offline
post #228 of 275 Old 01-13-2013, 06:52 PM
CDW_327
Yeap
Want to sell em to me?
CDW_327 is offline
post #229 of 275 Old 01-13-2013, 07:03 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Ordered a set of M.O.R.E. E-brake cables for the YJ 8.8 swap.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #230 of 275 Old 01-14-2013, 08:58 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Got a lot of progress done on the 8.8 today with a buddy.
-Matt
White '94 YJ Sport
UltimatE is offline
post #231 of 275 Old 01-14-2013, 09:50 PM
trailrider787
Like the progress on the 8.8, I just welded the tubes to the pumpkin on mine. It has been pretty stout so far. I'm interested to see the final product though with your truss, looks good.
trailrider787 is offline
post #232 of 275 Old 01-14-2013, 10:02 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Thanks. I'm going to mock up everything, tack the perches + shock mounts in place, and have a friend's buddy weld it up. Also going to have him weld the tubes to the pumpkin. This axle should hold up very well.
-Matt
White '94 YJ Sport
UltimatE is offline
post #233 of 275 Old 01-14-2013, 10:16 PM
trailrider787
Sounds good, are you planning on installing a locker? Didn't see anything in your thread about one. I also did the superior super 88 kit and would highly recommend it, but if your on a budget maybe not. A Buddy just put an Aussie locker in his and it performs flawless, I'm running a eaton e locker but wouldn't recommend it considering problems that others have had.
post #234 of 275 Old 01-14-2013, 10:19 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
I've got a limited slip in the axle, so I'm going to run that for now. And with my little 4-popper the Super 8.8 kit is also on hold.
-Matt
White '94 YJ Sport
UltimatE is offline
post #235 of 275 Old 02-24-2013, 04:46 PM
CTeunuch
Going to be done in time for this?
http://www.jeepforum.com/forum/f357/...013-a-1483921/
Think Twice Garage
"Yeah, that might work, pass me the grinder..."
94ZJ AX15/HP44/8.8/5.13's/35'' MTZ's SOLD
99XJ 4.0/AW4/HP30/8.25 build coming soon...
CTeunuch is offline
post #236 of 275 Old 02-24-2013, 05:06 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Should have the axle back from welding tomorrow. Lots of random setbacks. Hope to have everything bolted back in this week and finishing the brakes. I'll have to see if the driveshaft still fits with the bigger 8.8. If all goes well' it'll be driving this weekend.
-Matt
White '94 YJ Sport
UltimatE is offline
post #237 of 275 Old 03-03-2013, 12:00 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Finally got the axle back. Worth the wait, since the fab work is top notch.
When I got the axles from the junk yard, the tubes were bent 1/8" and 1/4", and after welding they moved even more. The welder had to cut the ends off and relocate them with an alignment fixture.
-Matt
White '94 YJ Sport
UltimatE is offline
post #238 of 275 Old 07-24-2013, 07:36 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Shame on me...Letting the Heep sit for so long. I'm finally working some more on it.
The axle is in place, brakes are on. Axle U-bolts torqued to the leaves. Working on getting the brake lines in and mounting up the shocks. Ended up buying new BDS 3.5" springs for the rear and a set of 5/8" lift boom shackles to clear the military wrap. E-brake cables purchased and in hand, special made YJ to 8.8 cables, bolt on.
Hoping to have it done very soon. It'll soon be my DD again so it has to be done.
-Matt
White '94 YJ Sport
UltimatE is offline
post #239 of 275 Old 03-02-2014, 10:38 PM
AZdEvilYJ
Update?
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is online now
post #240 of 275 Old 07-06-2014, 06:56 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Its been a while ... life has a bad tendency of getting in the way of projects.
Welded the exhaust together yesterday. She's driveable again. I still need to get a tail pipe bent up, rear driveshaft balanced, fluids changed, tailgate installed, look at the front brakes (pulls hard to the left), etc, etc...
-Matt
White '94 YJ Sport
UltimatE is offline
Anyone doing a LCOG YJ build? Jay-P YJ Wrangler Technical Forum 103 04-11-2014 11:12 AM
Super Duper Pete's White Russian Buildathon neverhide34 Jeep Builds 146 12-21-2012 05:29 PM
LJ LCOG build, questions on springs,bumpstops,improving articulation etc.... GMBNT42 TJ Wrangler Technical Forum 4 08-06-2011 05:22 PM
LCOG Build!!! inglisleslie TJ Wrangler Technical Forum 57 04-14-2010 12:38 PM
Project Green Monkey...a.k.a. Project Empty Pockets - '97 TJ Sport build thread Poobah TJ Wrangler Technical Forum 20 12-14-2008 09:30 PM
