Project Rust Bucket - Page 17 - JeepForum.com
post #241 of 310 Old 06-08-2012, 12:05 PM Thread Starter
oalali
Originally Posted by DesertDozer View Post
Awesome build and a great looking rig, mashallah, where do you wheel?
Thanks !
I usually wheel at different places in Abu Dhabi, Dubai, and all the other Emirates.
I'm part of AD4x4.com club.
oalali is offline
post #242 of 310 Old 06-08-2012, 08:56 PM Thread Starter
oalali
Jscherb Was kind enough to draw me some pictures for my next Project !
I'm going to use either Flat Fender or AEV Highline!
oalali is offline
post #243 of 310 Old 06-10-2012, 09:15 AM Thread Starter
oalali
Back to Rust Bucket This week. I hope that the project starts moving again very soon.
If you read through the past 17 pages, you will know that the two main things that are holding the project:
1- the knocking issue.
2- the overheating issue.
I came to believe that the second issue is the cause of the first. the engine is basically running lean, and that is why it runs hotter. To investigate this in a more scientific way. I decided to install a wide band sensor.
Having said that, I hate installing gauges and I want to keep my truck as stock looking as possible. Install an AFR now, air tank pressure later, few other gauges after than, and I will end up with a interior of a boy racer!
Therefore, I decided to only install a single gauge. That single gauge should give me all current and future information I need. I shopped around, placed some orders, and this is what I received Yesterday.
After a brief unboxing, it looks like this:
As you can see, I ordered PLX DM-100 and could of sensor modules with it.
The main unit reads directly from the OBD II. This allow me to read some useful information out of the engine's PCM. Things like that exact engine temperature, trims, error codes and many more will be easily accessible.
Having said that, the PCM can only support Narrow band data. Therefore I bought this:
The sensor will provide the DM-100 with Wide Band AFR information.
One additional thing I bought was an SM-FluidPressure sensor module.
why do I need that ? We will see later!
oalali is offline
post #244 of 310 Old 06-10-2012, 09:52 AM
TheDoc25
Originally Posted by oalali View Post
I saw an LJ version with the single cab black roof today, the colour was bronze with the flat fenders looked great. This build should be interesting...
TheDoc25 is offline
post #245 of 310 Old 06-10-2012, 11:29 AM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
If the PCM will only read narrow band sensors, then why did you get a wide band sensor? I've heard that a lot of people have had issues running any other sensors besides OEM Jeep sensors.
My newest build:
Necromancer_tat is offline
post #246 of 310 Old 06-11-2012, 03:07 AM Thread Starter
oalali
It will be interesting, but it will also take a long time to complete. I'm thinking about a minimum of 1 year build time.
oalali is offline
post #247 of 310 Old 06-11-2012, 03:27 AM Thread Starter
oalali
Sorry for the confusion.
The Wide Band O2 sensor will not be feeding the information to the PCM. It will be feeding it to the DM-100. This will allow me to read the Air Fuel Ratio from the DM-100 and do the necessary adjustments accordingly.
oalali is offline
post #248 of 310 Old 06-11-2012, 09:37 AM Thread Starter
oalali
This is a high level diagram of how things should look like.
oalali is offline
post #249 of 310 Old 06-11-2012, 03:10 PM Thread Starter
oalali
Some updates.
Here are the results of the fuel pressure test:
Once in Operation Temperature, the truck stays between 48 and 49PSI.
The gauge needle is very stable.
When turned of, the pressure almost imediatly goes down to 45 PSI. It took 7 minutes for the pressure to go down from 45 PSI to 20 PSI.
So, Can we now eliminate any fuel pressure problems ??
oalali is offline
post #250 of 310 Old 07-18-2012, 10:02 PM
Cuder
Did you ever get it running right?
My Build Thread:
Cuder is offline
post #251 of 310 Old 07-19-2012, 01:56 AM
Lo2aY
4 Wheel Station
Lo2aY's Avatar
Crawled!
very nice color and mods
Instagram: Lo2aYJP
JK Build thread (soon)
J8 Build thread (soon)
Brute Build thread (soon)
This hobby is not about who can shop the best, it's about creating things that did not exist before. It's about giving a machine a soul and making it an extention of your persona.
There is always someone who can spend more than you can. Don't measure your self worth against others. You can create, you can be fast and you can fail. It's all part of life.
Lo2aY is offline
post #252 of 310 Old 07-21-2012, 09:54 PM
TheDoc25
bump, how did you go with the new gauge
and getting it running smoothly?
TheDoc25 is offline
post #253 of 310 Old 09-04-2012, 04:31 PM
offroadlife03
colors sweet ,nice build ,how much better is the stroker ,does it have good torqe
offroadlife03 is offline
post #254 of 310 Old 11-20-2012, 12:07 PM
Cuder
What happened here? A guy in my club had the same problem with his stroker. He put another cam in and fixed it.
My Build Thread:
Cuder is offline
post #255 of 310 Old 11-22-2012, 12:10 AM Thread Starter
oalali
Thanks for the note. Is there a link to his post that I can read from ?
oalali is offline
1998 , abu dhabi , rust bucket , tj , uae
The Rust Bucket Project 84MSRB Jeep Builds 114 12-19-2013 09:39 AM
Bucket O Rust Build YMEOFCR Jeep Builds 1 02-12-2012 12:12 AM
XJ rust bucket build blankdeluxe Jeep Builds 18 07-11-2011 01:18 PM
Swap in bucket seats DUX4LIFE Jeep Picture Requests 0 03-29-2010 08:53 PM
Rust bucket Jeeps! yellojeeper Jeep Picture Requests 14 01-29-2009 09:42 PM
