Project Rust Bucket - Page 15 - JeepForum.com
post #211 of 310 Old 05-01-2012, 01:40 AM Thread Starter
oalali
Sorry for not updating. I was busy with the Jeep for the few days.
The truck is currently out and I'm driving it around to break in the engine.
Here are the pending issue.
1- Engine Pinging/knocking noise.
I have Pining/knocking noise in the engine under load/acceleration. I don't have the same issue when idling or cruising. It also seems that this issue is the original cause of the engine overheating I faced before.
This needs to be investigated. Timing chain and other stuff needs to be tuned.
2- AEV Tummy Tuck.
I decided to spread the chassis. I don't believe that this will affect anything. But this was postponed until the new adjustable control arms arrive.
3- The rear Savvy Off road lights
I need to make a circuit to convert my 4 wire system to 3 wire system. So the old lights went back in for now.
oalali is offline
post #212 of 310 Old 05-01-2012, 01:51 AM
chmo
Originally Posted by Hendrix View Post
The love for the Jeep is the same worldwide... It could bring peace to the world if we all loved each other as much as we love our Jeeps.
Not only the love for the Jeep, my dear ... not only that!
Although there is something like a global "common sense" and basic common needs ... it gets "flavored" enough by the ones (of whatever tribe) who are "defending" their interests to cause violence and disruption.
On an individual level fortunately we all are still HUMANS! I hope our "wise" men at the top of the different "tribes" come to this wisdom too one day.
"The more I know, the more I realize how much I don't know"
chmo is offline
post #213 of 310 Old 05-01-2012, 06:21 AM
Dogbones
with the regular I6 i had knocking as well, i found synthetics like mobil 1 helped alot
Dogbones is offline
post #214 of 310 Old 05-04-2012, 11:24 PM Thread Starter
oalali
The engine is currently running on break in oil. The Golen manual recommends 10w40 which is what I'm planning to run afterwards.
oalali is offline
post #215 of 310 Old 05-05-2012, 02:03 PM
Dogbones
lets see this thing out in the sun!
also how do you like the clutch? I've heard some people swear by the one you got and some swear by LuK...
Dogbones is offline
post #216 of 310 Old 05-05-2012, 03:27 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
Hurry up!
I finally got mine out on the trail today, when do you think yours will be ready to play off road?
Necromancer_tat is offline
post #217 of 310 Old 05-06-2012, 12:10 AM Thread Starter
oalali
The clutch is great so far! It's off-road performance haven't been tested yet.
pairing it with the B&M shifter was a great choice. The truck feels like a sport car !
oalali is offline
post #218 of 310 Old 05-06-2012, 12:12 AM Thread Starter
oalali
Originally Posted by Necromancer_tat View Post
Hurry up!
I hope to get every thing done and hit the dunes by the end of this week.
It will be tough test as temperatures might exceed 48C (118F).
oalali is offline
post #219 of 310 Old 05-06-2012, 06:03 AM
Necromancer_tat
I don't know how you do it! Good luck though! Did you get the pinging/knocking thing sorted out?
post #220 of 310 Old 05-06-2012, 10:53 PM Thread Starter
oalali
Not yet, I'm still searching for a reliable shop...
I also have lots of other things these days, I can't give Rust Bucket enough attention ..
oalali is offline
post #221 of 310 Old 05-07-2012, 08:17 AM
Cuder
I don't have a stroker, but I have read on this forum and my club's forum that adjusting the crank position sensor will help with the problems you have. You can get one that is adjustable or slot the holes in the one you have.
Also, an adjustable MAP sensor was mentioned.
My Build Thread:
Cuder is offline
post #222 of 310 Old 05-07-2012, 10:21 PM Thread Starter
oalali
Thanks for the info!
Could you please post the thread links if you still have them ?
oalali is offline
post #223 of 310 Old 05-07-2012, 10:54 PM
chmo
e.g. "http://www.jeepstrokers.com/forum/viewtopic.php?f=15&t=2608&p=24982" or
e.g. "http://www.jeepstrokers.com/forum/viewtopic.php?f=5&t=3293"
oalali, man ... didn't you do a paint job to your intake manifold as well?
If the sealing surfaces (towards block and towards throttle body) e.g. got painted too you might experience vacuum leak issues which can be another reason for pinging!!! I would strongly recommend disassembling the intake and TB stuff and eventually cleaning the surfaces from the paint with thinner! (no sanding or other invasive methods!!!)
chmo is offline
post #224 of 310 Old 05-09-2012, 01:29 AM Thread Starter
oalali
Thanks!
The truck is at the Dyno today and I believe that they will be able to diagnose the issue.
This may sound strange, but I'm suspecting that the engine is actually running rich! This can be either caused by too much fuel or too little air.
The intake leak might be a possibility. But they haven't painted any contact surface. Also, All surfaces where cleaned before the installation. Anyway, I will get them to inspect it for any leaks.
I'm also installing a fuel regulator and fuel/ignition Chip to deal with this. I hope to get some positive results today. Wish me luck !
oalali is offline
post #225 of 310 Old 05-13-2012, 12:51 AM Thread Starter
oalali
Sorry for not updating, here is what happened so far:
After few dyno inspections runs, we discovered that the engine is running rich while idle and lean while on load.
The tuner tried to fix this by installing AEM's F/IC8 controller. After a 3 degree retard and fuel table adjustment, the results became as following:
1- On idle, the engine is running way too rich.
2- On load, the fuel is better but is still a bit lean.
3- Knock was eliminated until engine reaches above average temperature.
4- Fuel consumption is very high.
We stopped right there. We can't retard the timing, or increase the fuel anymore as the engine had some hard time starting. Also the fuel consumption was very bad.
To be continued ..
oalali is offline
1998 , abu dhabi , rust bucket , tj , uae
The Rust Bucket Project 84MSRB Jeep Builds 114 12-19-2013 08:39 AM
Bucket O Rust Build YMEOFCR Jeep Builds 1 02-11-2012 11:12 PM
XJ rust bucket build blankdeluxe Jeep Builds 18 07-11-2011 12:18 PM
Swap in bucket seats DUX4LIFE Jeep Picture Requests 0 03-29-2010 07:53 PM
Rust bucket Jeeps! yellojeeper Jeep Picture Requests 14 01-29-2009 08:42 PM
