Project REDLYNER: Rock Crawler Driven Daily... - Page 4 - JeepForum.com
 4Likes
post #46 of 6915 Old 06-14-2010, 03:09 PM Thread Starter
REDLYNER
REDLYNER's Avatar
Originally Posted by TheRealSICNICK View Post
Ok so im new to the whole jeep scene so hope you can bear with my questions!!! I currently have a 4" pro comp lift and want to upgrade to 35s, I want to go with the tube fenders aswell... I want to make sure the tires will fit... I would like my jeep to look similar to yours at the stage with the 35s. Any input would be greatly appriciated!!!
Since you already have the lift, all you would need is:
Front and rear tube fendors, body match the front
Black wheels with M/Ts
Front stinger
Then it would look pretty similar.
REDLYNER is offline
post #47 of 6915 Old 06-14-2010, 10:19 PM
BigGreenTJ27
Originally Posted by REDLYNER View Post
Thanks dude!
I have tow hooks up front and I have always hooked up to those. No problems as of yet.
There are some other bumper/stingers out there that have d-ring mounts. Clayton at Poison Spyder (no longer the owner) was really cool with me and hooked me up with a nice deal on mine, so that's why I run it.
Ahh I see. I didn't take the time to see that you still had the stock tow hooks on there. I have always been a little skeptical about pulling on them. But if it works for you, I'm sure it'll work for me. Looks like I'll be ordering this bumper in the next day or two. Thanks man!
BigGreenTJ27 is offline
post #48 of 6915 Old 06-15-2010, 07:01 AM Thread Starter
REDLYNER
REDLYNER's Avatar
^ Just an FYI, they are not the stock tow hooks. I picked up some aftermarket 10,000lb rated hooks and they seem to have a longer arch to hook things to.
REDLYNER is offline
post #49 of 6915 Old 06-15-2010, 10:26 AM
zachbh
Great looking Jeep
zachbh is offline
post #50 of 6915 Old 06-15-2010, 08:18 PM
wzrroc
awesome rig! Just wondering what you painted your frame with and what prep work you did?
thanks.
Green 95 YJ. 2.5L Low output. 2.5" RE lift. 1.25" shackles. 33" BFG Mud Terrains.
(SOLD)
Jeep #2: Green '98 TJ 4.0L|AA SYE, Tom Woods shaft|4.88s|3" teraflex lift|2" BB|1.25" BL|1" MML|35" BFG All Terrains|Warn XD9000i|
Daily Driver: 1991 Ford Escort, white w/ graffitti stencils
"I will never understand why people will spend money on huge rims with skinny tires when you can get small rims (15") with huge tires."
"I'm teaching my jeep to roll over, so keep your distance."
wzrroc is offline
post #51 of 6915 Old 06-15-2010, 11:31 PM
WillieP23
^^^Im also curious about how you painted your frame. Thanks
WillieP23 is offline
post #52 of 6915 Old 06-16-2010, 07:59 AM Thread Starter
REDLYNER
REDLYNER's Avatar
thanks.
Thanks dude!
I am using a Krylon no rust semi flat black. The stuff is awesome!! Only problem is that it is $6 a can I just taped up the crap I didn't want to get paint on, grabbed a cardboard shield and sprayed away.
So the beadlocks weren't as bad as I thought they would be. We had three of us working as a team and the tires went on pretty quickly. I had to watch a youtube video on how to mount them, but other than that it was pretty straight forward. While we had the tires off, I went ahead and lengthened the Rokmen short arms front and rear to get me to 95" wheelbase.
Pics (some are cellphone, sorry)-
UPS dropping off the goods:
Getting to work on the lock rings:
Bolted up and ready for install:
Short arms stretched and wheels mounted up:
So the wheelbase is too far back to take it off-roading with the current armor, which means it will have to be removed and the tub cut. That will only be temporary until i get the stretch kit on and bolt up some new stretch corners.
REDLYNER is offline
post #53 of 6915 Old 06-16-2010, 02:37 PM
wzrroc
now that your getting rid of the rear armor, how did you like it? XRC stuff tends to get a bad rap but on a budget they look like the best choice.
(SOLD)
wzrroc is offline
post #54 of 6915 Old 06-16-2010, 04:14 PM Thread Starter
REDLYNER
REDLYNER's Avatar
They were great! I almost kept them and just comp cut them, but I don't think 37"s are big enough to make a comp cut look good.
So between now and when I started cutting the suspension off, I had to go try out the new beadlocks! This meant cutting off some sheet metal to make room for the tires and 1" short arm "stretch". 1st thing I learned is that I do not cut circles very well.
Pulled the rubber tub out and prepped for the blade:
Marked my line with a highlighter:
Started cutting. There were several little braces that made it a pain, but it eventually cut off. All of the marks or stains on the rotor is my sweat.:
Steel removed, half circle complete:
Wheels mounted back up for fitment:
I finished this up on a Friday so we could head out to The Gulches on Saturday. Great off-road park and the tires didn't rub at all! This is still on 3.5" springs.
Pics from the day:
Fully stuffed, no rubbing:
It's ugly as hell, but it is just temporary. Much more cutting to be made.......
REDLYNER is offline
post #55 of 6915 Old 06-16-2010, 05:53 PM
300whisper
2010 JK Wrangler
Excellent, excellent build. How difficult was the axle swap and can 44s support 37s? How are they on gas? Sorry if you mentioned this before I probably got lost in the pics!
300whisper is offline
post #56 of 6915 Old 06-16-2010, 06:17 PM
TheRealSICNICK
are you selling the old armor???
TheRealSICNICK is offline
post #57 of 6915 Old 06-16-2010, 09:22 PM Thread Starter
REDLYNER
REDLYNER's Avatar
Axle swap was pretty easy. I have done 4 or 5 now, so it has become pretty routine.
The 37"s max out the built 44's for sure. I don't hammer it and I never let the rig bounce when trying to crawl over something, so I may have better luck than others. Some people swear the 44 is fine, but most hardcore guys would say go with a 60 and not worry about it. While mine may never break, it will always be in the back of my mind.
Gas milage on these pretty much sucks. They are tall and they are heavy... not a great combo.
Everything I have taken off is already sold.
REDLYNER is offline
post #58 of 6915 Old 06-17-2010, 09:45 AM
theducksguts
or carry spare shafts and not worry about it.
Check out my
theducksguts is offline
post #59 of 6915 Old 06-17-2010, 07:14 PM
-ExDementia-
1991 XJ Cherokee
Just one question, what do you do for a living?
Love the jeep man.
"The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, 'You know, I want to set those people over there on fire, but I'm just not close enough to get the job done.'" - George Carlin
Click
for the elusive search button everyone talks about.
-ExDementia- is offline
post #60 of 6915 Old 06-18-2010, 06:48 PM Thread Starter
REDLYNER
REDLYNER's Avatar
UPS delivers the goods:
Clayton 5" rear stretch kit!
Thanks to Zach at A to Z fab for the sweet deal!
REDLYNER is offline
aluminum , coilovers , custom , ecors , fuel cell , immaculate wheeling queen , koh , level 5 hair gel , offroad racing , racing , sinister fab , smittybuilt emc , sniper fab , tnt , toothbrush detailing , ultra4
Daily Driven Xj VDuBLuv82 Jeep Picture Requests 54 05-04-2011 10:05 AM
project daily driver/ baby hauler sparkyB34 Jeep Builds 0 04-18-2010 07:49 PM
82 CJ Rock Crawler (Big Red) seedubau Jeep Builds 14 04-18-2009 12:02 AM
warn rock crawler rebelkid17 Jeep Picture Requests 12 10-26-2008 07:54 PM
rock crawler series 87 ep191 Jeep Picture Requests 4 10-25-2008 12:58 AM
