Project REDLYNER: Rock Crawler Driven Daily... - Page 280 - JeepForum.com
 4Likes
post #4186 of 6915 Old 08-20-2013, 09:54 PM
MO2500
Originally Posted by aw12345
Your forgetting the illustrious codriver, master gardener and seriously good fab guy that had a helping hand in making your Jeep do what it did
Haha, this made me laugh! Thanks, Art!
Jay, definitely get the wheels and tires checked and balanced best you can. I didn't see anything wrong with the work done that would be causing DW if everything is tight. Might have to play with alignment next.
Instagram: @omsmike
MO2500 is offline
post #4187 of 6915 Old 08-20-2013, 10:06 PM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
Well, i don't think it would be in Team Redlyner spirit if you weren't down to the last day trying to get everything ready lol.
SEMPER FI
LifeProof is offline
post #4188 of 6915 Old 08-20-2013, 10:27 PM Thread Starter
REDLYNER
REDLYNER's Avatar
I swear that I try for the exact opposite..... but history doesn't exactly help my case .
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
post #4189 of 6915 Old 08-20-2013, 11:32 PM
aw12345
Tire balance, caster and toe in. Steering dampener or hydro assist. I am sure they got everything nice and tight and no slob no where.
Spin the tires barely of the ground and check for wobbeling of the front tires.
aw12345 is offline
post #4190 of 6915 Old 08-21-2013, 06:54 AM
Imped
Imped's Avatar
ECGS has been trying to trouble shoot it for two days and haven't figured it out? That's surprising.....it ain't that tough.
Have the wife turn the wheel between 11 and 1 while you watch underneath. What's loose? Don't forget to rock the tires back and forth with the rig in gear to check the control arm ends.
What's caster? Toe-in about 1/8-3/16"?
That bastard should be rock solid. If you have full on DW with those components, it'll be something pretty obvious.
OlllllllO
IndyORV
Imped is offline
post #4191 of 6915 Old 08-21-2013, 08:04 AM Thread Starter
REDLYNER
REDLYNER's Avatar
ECGS doesn't have a high speed balancer. I really think it is in the wheels... Well, I really hope. We did the steering test, track bar, tie rod, drag link don't move a millimeter. Rock solid. There is some play in the shaft that comes straight out of the steering box, but I don't think that would cause it .
It's at Coulwood Tire & Auto now, hoping for a progress by noon. I will post up with some details.
REDLYNER is offline
post #4192 of 6915 Old 08-21-2013, 08:12 AM
IEcrawlerTJ01
Steering box is not gonna be the main problem. But it could definitely play a part. I have encountered that problem before it induced a shimmy at speed. Which if anything else is bad. Could def add to the DW
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #4193 of 6915 Old 08-21-2013, 08:20 AM
Imped
Imped's Avatar
Is there any play inside the steering box? If there's anything more than a very tiny delay between the input (steering shaft) and output (pitman arm) then that isn't helping....but it likely isn't your root cause. The play in the steering shaft isn't helping but again, doubt that it's the root cause. Those tires would have to be seriously out of wack to be giving you such fits but I suppose it's possible.
OlllllllO
IndyORV
Imped is offline
post #4194 of 6915 Old 08-21-2013, 08:27 AM Thread Starter
REDLYNER
REDLYNER's Avatar
So a few things about that:
  1. The steering box didn't just suddenly get loose over the last 7 days, it was like that before I did the swap and I had the jeep up to 75mph last Tuesday with old axle and old Racelines.
  2. When I personally mounted the MTR/Ks to the old Racelines, I had death wobble until they were balanced by Discount Tire (who will no longer touch my jeep )
Side note- the new brakes are unbelievably strong. I nearly embarrassed myself pulling the jeep into the parking spot at Coulwood locking up the tires just going from trailer to space.
REDLYNER is offline
post #4195 of 6915 Old 08-21-2013, 08:29 AM
Imped
Imped's Avatar
You really should take a 60-0 video once you get the tires balanced........
OlllllllO
IndyORV
Imped is offline
post #4196 of 6915 Old 08-21-2013, 10:03 AM Thread Starter
REDLYNER
REDLYNER's Avatar
Hmmmm... Tire shop called. Tires were out of balance, they got them in check and took it for a test drive. Got it up to 60 and it was smooth as silk. Turned around to head back to the shop and death wobble kicked in. The shop owner said it was his first DW experience and it was the most scared he's ever been in a vehicle. Not what I wanted to hear. They can't fit their alignment machine over the beadlocks, so he said he's out of options.
Question: if the track bar was slightly shorter than the drag link, would that contribute to DW?
REDLYNER is offline
post #4197 of 6915 Old 08-21-2013, 10:07 AM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Juat a thought, if the wheels are not hub centric, care needs to be taken while tightening the lug nuts to ensure the wheel centers. They should never be snugged and then torqued on the ground... only torque with no weight on them. And if you can, just run hub centric rings to avoid the problem all together. You probably know all that just throwing it out there.
Edit: the inconsistent nature eliminates mis aligned wheels on the hub.... it would happen every time.
gst95dsm is offline
post #4198 of 6915 Old 08-21-2013, 10:10 AM
Imped
Imped's Avatar
No.
Something is loose. Now you have to find it. Even if the tires aren't perfectly balanced, it shouldn't matter. A good front end can handle poor balance.
OlllllllO
IndyORV
Imped is offline
post #4199 of 6915 Old 08-21-2013, 10:11 AM Thread Starter
REDLYNER
REDLYNER's Avatar
I am open to ALL suggestions.
REDLYNER is offline
post #4200 of 6915 Old 08-21-2013, 10:11 AM
Hendrix
TJOTY 2013
Hendrix's Avatar
I my experiences there are 3 factors that lead to DW.
1. Balance of tires
2. Loose bolts or worn part.
3. Poor alignment.
Did you ever add hydro assist?
K.C.C.O.
Carpe Diem
Hendrix is offline
aluminum , coilovers , custom , ecors , fuel cell , immaculate wheeling queen , koh , level 5 hair gel , offroad racing , racing , sinister fab , smittybuilt emc , sniper fab , tnt , toothbrush detailing , ultra4
Daily Driven Xj VDuBLuv82 Jeep Picture Requests 54 05-04-2011 10:05 AM
project daily driver/ baby hauler sparkyB34 Jeep Builds 0 04-18-2010 07:49 PM
82 CJ Rock Crawler (Big Red) seedubau Jeep Builds 14 04-18-2009 12:02 AM
warn rock crawler rebelkid17 Jeep Picture Requests 12 10-26-2008 07:54 PM
rock crawler series 87 ep191 Jeep Picture Requests 4 10-25-2008 12:58 AM
