Project REDLYNER: Rock Crawler Driven Daily... - Page 271 - JeepForum.com
 4Likes
post #4051 of 6915 Old 07-12-2013, 02:50 PM
IEcrawlerTJ01
You are correct. Those are NOT the currie alum knuckles. Nor did I say they were. Those are the currie machined f-450 stuff
Blaines personal rig has the alum knuckles though
And the question is. Why mess with the "beefier" 05+. When the 99-04 have been proven time after time to be plenty strong and Within my knowledge have been no known failures
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #4052 of 6915 Old 07-12-2013, 03:08 PM
MO2500
Your axle came with the arm and you added the mount, right? I like that.
Drag link on top, tie rod on bottom right?
There you go Jay. That's perfect.
Yep, fordtechguru machined knuckles and arms. Tie-rod is on the bottom of the hi-steer arm and draglink on the side (but yes, on top of the TR).
It took 5 days of wheeling in Colorado and Moab before I hit my TR for the very first time on Helldorado. It's nice having it above the axle tube.
Instagram: @omsmike
MO2500 is offline
post #4053 of 6915 Old 07-12-2013, 03:15 PM
Sundowner
But the logical side of me took over and said it was going to cost far too much for what I can justify.
Blasphemy!
Sundowner is offline
post #4054 of 6915 Old 07-12-2013, 03:44 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Love the tow rig Jay. Its going to look real nice hooked to the 100K Jeep.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4055 of 6915 Old 07-18-2013, 08:56 AM Thread Starter
REDLYNER
REDLYNER's Avatar
Had a great talk with Chase at East Coast Gear Supply yesterday. Each of our last three conversations have been over 30 minutes long, I'm sure when he sees my number on caller ID he looks at his calendar first because he knows I'll have a million questions .
We made some changes to the front axle direction- I am going with slugs instead of the manual Warn hubs, Chase also re-confirmed the steering design (same as the ones they roll out on their custom 60 builds), and most importantly, I'm switching from Trail Gear RA9 to a Spider9. The wife is much happier going with a name she recognizes .
Front Rubi 44 is sold pending funds minus the Vanco Big Brake Kit and the Currie/Ironman steering. The goal is to have the new axle under the jeep by or around 8/9, so brakes and steering would be available for pickup then. Let me know if anyone here is interested before I list them for the masses.
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
post #4056 of 6915 Old 07-18-2013, 09:09 AM
mcannon111
Sounds great, good to hear some progress! Only concern i have is that if the jeep is going to be driven a good bit on the road in the summer months, i'd be concerned about slugs with them super joints. You will either have to grease the joints once a month, or swap in some premos or mile marker hubs for pavement pounding. Honestly my recommendation is don't do slugs and just do yukon hubs. Those things are freaking slick, and indestructible. Slugs are sweet, but i don't think they would pair well with driving it to work and back every day in the summer.
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #4057 of 6915 Old 07-18-2013, 09:30 AM Thread Starter
REDLYNER
REDLYNER's Avatar
I had a long discussion about this with ECGS, the bottom line is that I didn't want anything manual. The goal was to have it setup as convenient as the Rubi axle, IE from my drivers seat, I can go from pavement to offroad and get into locked 4WD without having to exit the cab.
My understanding is that the slugs will make the 9 act like the Rubi (shafts spinning all of the time, no load). Where as the Warn or Yukon hubs I would have to manually switch them to engage the axle shafts. Where am I wrong and if so, what options are available?
REDLYNER is offline
post #4058 of 6915 Old 07-18-2013, 09:47 AM
Jankoid
What is difficult about twisting the knob on a manual hub when you are airing down your tires?
Jankoid is offline
post #4059 of 6915 Old 07-18-2013, 09:54 AM Thread Starter
REDLYNER
REDLYNER's Avatar
REDLYNER is offline
post #4060 of 6915 Old 07-18-2013, 10:02 AM
Jankoid
That doesn't answer my question. You lock them in at the beginning of the day and unlock them at the end. I don't see how that is any less convenient than the rubi axle. It takes all of 5 seconds and it's not like you're never going to step foot outside of the Jeep...
Jankoid is offline
post #4061 of 6915 Old 07-18-2013, 10:13 AM
mcannon111
In your rubi axle you just had spicer 760x ujoints right? Those ujoints have needle bearings which work great for everyday pavement pounding. But superjoints do not have needle bearings, they are just simply a greased cap. That is part of the reason why they are so strong. But driving them on the street for extended periods of time can cause some problems from them causing them to wear out quicker if not constantly greased. Maybe you'd prefer to pull out the grease gun and grease them up every week, but i'd rather just put a yukon hub on it, lock it up at the trail head, unlock once leaving the trail. Grease them up every other trip, and thats it.
post #4062 of 6915 Old 07-18-2013, 10:33 AM
AngryTJ
I assume for racing he would want the ability to unlock without having to climb out of the driving seat.
Don't know if he was locked the entire time he was ripping through the desert but having the option of pushing a button instead of jumping out is nice
AngryTJ is offline
post #4063 of 6915 Old 07-18-2013, 10:41 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
That is why he has the arb in the front. Locking in at the beginning of the day and then unlocking at the end is going to wheel just like drive slugs.
But drive slugs on the road are not going to be the same as unlocking hubs on the road.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #4064 of 6915 Old 07-18-2013, 10:57 AM Thread Starter
REDLYNER
REDLYNER's Avatar
That is correct. Mike and I actually had a system of reminding me to turn on the lockers when we got into the rocks and obstacles. I ran 4wd open through the soft stuff and the whoops, 2wd through the lake bed, and 4WD locked in the rocks.
My understanding is that with the slugs, it will imitate the Rubi 44. Meaning axle shafts and driveshaft spin, but there is not a load on them. Where as with the manual hubs, the axle shafts are not spinning when unlocked. Correct?
I don't pretend to be an expert on any of it, but I do know what I want and now it is just getting the right parts to create that scenario.
REDLYNER is offline
post #4065 of 6915 Old 07-18-2013, 11:19 AM
mike_dippert
hodophobic
mike_dippert's Avatar
Manual hubs disconnect the wheel from the axle shaft.
mike_dippert is offline
aluminum , coilovers , custom , ecors , fuel cell , immaculate wheeling queen , koh , level 5 hair gel , offroad racing , racing , sinister fab , smittybuilt emc , sniper fab , tnt , toothbrush detailing , ultra4
Daily Driven Xj VDuBLuv82 Jeep Picture Requests 54 05-04-2011 10:05 AM
project daily driver/ baby hauler sparkyB34 Jeep Builds 0 04-18-2010 07:49 PM
82 CJ Rock Crawler (Big Red) seedubau Jeep Builds 14 04-18-2009 12:02 AM
warn rock crawler rebelkid17 Jeep Picture Requests 12 10-26-2008 07:54 PM
rock crawler series 87 ep191 Jeep Picture Requests 4 10-25-2008 12:58 AM
