Project REDLYNER: Rock Crawler Driven Daily... - Page 123 - JeepForum.com
 4Likes
post #1831 of 6906 Old 02-21-2012, 06:38 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Looks good Jay. What is your frame height now? Ground to bottom of the frame?
Hendrix is offline
post #1832 of 6906 Old 02-22-2012, 12:38 AM
LostJeeper
Originally Posted by REDLYNER View Post
The guys at the shop thought that even a narrower 37" (the Pitbulls are extremely wide) would have solved my tire rubbing at full stuff issue. Right now, the wider wheel spacers are working. But I don't like having to use them. So it's a bandaide until I get some wider axles.
Might save some weight if you went to narrower tire as well.
Armed Forces Jeeps
MT WAVE SAR
KF7IRO
LostJeeper is offline
post #1833 of 6906 Old 02-22-2012, 05:49 AM
indyrubi
Looking good!!
Is the top of the rear hoops tied into anything? I'm in the process of doing basicly the same on mine right now and was thinking that they might need to be braced.
indyrubi is offline
post #1834 of 6906 Old 02-22-2012, 08:20 AM Thread Starter
REDLYNER
Mall Crawling Racer
REDLYNER's Avatar
It is 22" from the ground to the center of my belly pan and 23 1/2" from the ground to the bottom of the frame by the center body mount. That is around 1/2" taller than where I was before swapping out all of the coilovers. I'm estimating a slight drop once the springs settle a little.
Another huge reason I am looking at my options.
Originally Posted by indyrubi View Post
Looking good!!
It is not currently braced up top, but will be tied into my cage in the next month or so. The bottom of the shock hoop has a gusset on each side, so hopefully that will get me by until I tie in the top.
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
post #1835 of 6906 Old 02-22-2012, 08:36 AM Thread Starter
REDLYNER
Mall Crawling Racer
REDLYNER's Avatar
So I have 22 days until I leave to pre-run/race for the first ECORS race of the year. I have a few business trips in the mix too, which will leave me about 13 days to get this stuff finished. Since I don't want to be cranking on this at the 11th hour, that brings it down to about 10 days. In those 10 days, I was hoping to get some practice and seat time in along with getting the coilovers tuned, and I haven't quite figured out how to squeeze that in. Hmmmm....
Still to go:
  • Install front Riddler diff cover (need to buy diff fluid)
  • Install fire wall (need to finish mount and drill filler hole)
  • Get numbers and stickers cut (need to send art work to printer)
  • Rubber buffer for PSC half doors (keep doors from vibrating)
  • Replace coolant reservoir (arrives tomorrow via UPS)
  • Rear tail gate cover/skin (either buy Savvy's or have one custom made)
  • Install submarine belts on both seats (have to find them in the garage)
  • Install new springs on c/o's (won't arrive until next week)
  • Swap out tops
  • Prep pit gear
Nothing major on the list, but still a ton of tedious little stuff.
REDLYNER is offline
post #1836 of 6906 Old 02-22-2012, 01:11 PM
Redcrazzy
Your build is very impressive man. I am going to try and be as thoughtful in my build as you have with yours. Very meticiously planned. Congrats on the baby boy btw, haven't checked back on this build in awhile so I didn't know you had a little one. Bet he loves the jeep.
Redcrazzy is offline
post #1837 of 6906 Old 02-22-2012, 08:19 PM
jose_p_adams
makes me feel better about mine sitting at 24.5 on 39.5" iroks.
jose_p_adams is online now
post #1838 of 6906 Old 02-23-2012, 12:07 PM Thread Starter
REDLYNER
Mall Crawling Racer
REDLYNER's Avatar
Firewall project complete!
One thing checked off the list, and three or four more added.
RCI fuel cell with Artec mount:
Marking the holes to be drilled for the mount:
Drilled and being bolted down:
Front tabs in place:
I used a 4 1/2" hole saw for the filler hole. Then lined it with some door trim:
All finished!
This should silence the fuel pump a good bit as well. I will eventually put a billet fuel cap on, but I didn't want to spend another $50 on this project.
From in the cab:
REDLYNER is offline
post #1839 of 6906 Old 02-23-2012, 12:19 PM
MO2500
Looks good I need to do something similar with mine eventually. I don't know if I'll keep the same cell though which is keeping me from tackling this project. Eventually I'd like to go to a flatter cell with internal bladder and run an external fuel pumps instead of the TJ pump. I know your probably looking at swapping to a bladder cell soon for racing anyway.
ODonnell Motorsports
Build Thread
Instagram: @omsmike
MO2500 is online now
post #1840 of 6906 Old 02-23-2012, 01:30 PM
Imped
Fantastic....let me know how it does with muffling the fuel pump and annoying sound of the rollover valve ball.
OlllllllO
Float Test Build
IndyORV
Imped is online now
post #1841 of 6906 Old 02-23-2012, 06:10 PM
JJeeper09
My fuel pump seems to be dying. Start ups take a few times I want to do away with the stock pump so bad.
Looks good Jay
JJeeper09 is offline
post #1842 of 6906 Old 02-24-2012, 12:28 PM
gspup
Would you choose Treps again ? Trying to decide, also looking at MTRKs but I don't know anyone other than you who has used Treps? I only drive about 5,000 miles a year so treadwear isn't really important but I do drive to the trail.
gspup is offline
post #1843 of 6906 Old 02-24-2012, 12:47 PM
Rumbloki
Awesome setup. Great pics.
Rumbloki is offline
post #1844 of 6906 Old 02-24-2012, 01:22 PM
Imped
FYI, if you ever want to get rid of the footman loops, once you've drilled out the rivets Chrysler christmas tree plastic fender things press in real well.
OlllllllO
Float Test Build
IndyORV
Imped is online now
post #1845 of 6906 Old 02-25-2012, 02:00 PM
Surly
Drove past you on 16 today man, jeep was looking awesome as always! Good luck at ECORS.
01 XJ
Surly is offline
aluminum , coilovers , custom , ecors , fuel cell , immaculate wheeling queen , koh , level 5 hair gel , offroad racing , racing , sinister fab , smittybuilt emc , sniper fab , tnt , toothbrush detailing , ultra4
Daily Driven Xj VDuBLuv82 Jeep Picture Requests 54 05-04-2011 09:05 AM
project daily driver/ baby hauler sparkyB34 Jeep Builds 0 04-18-2010 06:49 PM
82 CJ Rock Crawler (Big Red) seedubau Jeep Builds 14 04-17-2009 11:02 PM
warn rock crawler rebelkid17 Jeep Picture Requests 12 10-26-2008 06:54 PM
rock crawler series 87 ep191 Jeep Picture Requests 4 10-24-2008 11:58 PM
