Project Procrastination, a TJuggy Build 42" pitbulls, stretched, on tons - Page 9 - JeepForum.com
post #121 of 619 Old 04-30-2011, 07:18 PM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Picked up some Chromed out 8 lug H2 Rimz today. I'm starting to gather parts. I got the wheels at a good price.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #122 of 619 Old 05-01-2011, 04:27 PM Thread Starter
JeepRocks86
I've got a MORE front HC bumper for sale. It currently retails for about 571 plus a lot of shipping. I want 350 for it.
Bumper only, Jeep, Winch, etc are not included.
Let me know if you're interested.
http://www.mountainoffroad.com/_e/Je..._Wranglers.htm
For Sale:
post #123 of 619 Old 05-01-2011, 07:01 PM
freshlikefruit
your jeep is sick. i like where you are going, but personally im still in the 35" HP 30 crowd. is your front 30 high or low pinion. Im sure its in your build thread but im 7 oberon's deep and reading isnt my strong suit right now haha.
97 tj, dirt on it
freshlikefruit is offline
post #124 of 619 Old 05-01-2011, 08:25 PM Thread Starter
JeepRocks86
My 30 is the factory LP. I wish I would have put a HP in when I did the gears, but oh well.
Yukon Chromo Shafts
4.88s
Lockright
I've replaced the unit bearings once on it
In the next few weeks I will be redoing the steering with teh JCR over the knuckle kit and building a custom track bar for it.
For Sale:
post #125 of 619 Old 06-08-2011, 07:26 AM Thread Starter
JeepRocks86
Have had some more recent updates, Photos later.
Going to be replacing the PS pump and putting a genright pulley on (old pulley broke when I tried to pull it off, and I decided it was probably a good time to replace the pump since it's apart and also, at times it would whine after long hot day of wheeling.)
PSC steering box
Knuckle over steering
Rebuilding the front track bar mount
rebuilding the front track bar
2 weld on bead locks
different front bumper
I have a week before I leave for Harlan so I have a lot to finish up.
For Sale:
post #126 of 619 Old 06-08-2011, 06:26 PM
99TJSahara
Are you gonna be at the K&I four wheelers show n shine on the 25th?
-Joey
04 Grand Cherokee Overland
-sold
99TJSahara is offline
post #127 of 619 Old 06-08-2011, 08:37 PM Thread Starter
JeepRocks86
There is a good chance I will be there. I will probably be there with or without the jeep. I haven't been to much KI stuff lately. I was going to go last night, but I spent the night in the garage. I've also been very busy with school and work as well.
For Sale:
post #128 of 619 Old 06-08-2011, 11:16 PM Thread Starter
JeepRocks86
I will get some photos later.
So far this evening, from 1140pm to 1255am
PS pump is on
Genright PS pulley is on
PS filter is on
Also leak checked my welds on my wheels... Let's say I have some patching to do tomorrow.
About to go replace the subwoofer in the center console.
Tomorrow morning I'm going to the junk yard to get a couple things to finish up the install. Also I plan on cutting down my RE track bar to raise it up to work with my knuckle over steering. I hope the bends in it won't come into contact with anything. If so, I'm going to cut the tube off and go buy some strait DOM and re use the ends since i'm on a time crunch.
For Sale:
post #129 of 619 Old 06-09-2011, 12:01 AM
kyle_craig
Cool build...Subscribed.
kyle_craig is offline
post #130 of 619 Old 06-09-2011, 01:02 AM Thread Starter
JeepRocks86
Thanks.
So I put the new sub in... It's not working. Something is wired wrong. I will have to worry about it later.
My current future plan is to sell the rear 60 and pick up a 14 bolt. The SRW 14 bolt will be shaved and I will probably put a detroit in it to save money when compared to an ARB.
For Sale:
post #131 of 619 Old 06-09-2011, 08:18 PM Thread Starter
JeepRocks86
after 2 trips to the junk yard today, I got the knuckles. I forgot to take my large socket set the first time, so I couldn't get the lower ball joint nut off.
I welded up some of the holes in the beadlocks. There are still a few more, but i'm hoping that some RTV will fix the rest.
I'm in the process of reaming them out, but I had to come in because it's about 90 degrees outside with a very high humidity.
Edit: Both knuckles are reamed. The sub is working, I ended up using the gray wire and the one paired with the black wire if I remember correctly.
I still have a lot of work to do before next wednesday. Track bar and mount, install steering links, put tires on wheels, bolt the tires together, clean out the interior, and a lot more.
For Sale:
post #132 of 619 Old 06-10-2011, 09:55 AM
Red_Raider911
Red_Raider911 is offline
post #133 of 619 Old 06-14-2011, 08:39 AM Thread Starter
JeepRocks86
last night/ yesterday/early this morning
got one lower ball joint in, it took about 3 hours each to get them out and it's a lot of work getting them in. They have already broken one ball joint press.
installed the lockright in the front end and torqued the ring gear down.
mounted one of my weld on bead locks.
today's list...
modify track bar
modify track bar bracket upper
weld lower bracket on
install the knuclkes
attach steering linkage
attach winch, bumper, and steering box skid
fab lower sway bar mounts
and a lot more.
For Sale:
post #134 of 619 Old 06-15-2011, 01:10 AM
ibjeepin95
We need pics!
ibjeepin95 is offline
post #135 of 619 Old 06-15-2011, 07:38 AM Thread Starter
JeepRocks86
I've been a little busy for photos and I can't seem to find my camera.
Yesterday I got the knuckles on, front diff assembled, lower track bar welded on, modified the upper track bar mount (still need to weld it in), rebuilt the RE joint (need to cut the track bar down), and a whole lot of other stuff.
Lots to do before I leave in the next 24 hours.
For Sale:
14b , custom , hardcore , hp60 , indyorv , pitbull , psc , rockers
Project Ton Ton - 1 Ton Cherokee HP60/14b andrewmacc Jeep Builds 300 10-08-2014 07:46 AM
cj's on coilovers 80CJ5SBC Jeep Picture Requests 3 12-13-2011 09:12 AM
Coilovers YJCRAZY1995 Jeep Picture Requests 4 12-06-2011 01:51 PM
WJ with shaved cladding JSRichar5985 Jeep Picture Requests 2 05-22-2011 11:35 PM
Lets see some coilovers! ljs89 Jeep Picture Requests 0 07-10-2009 06:59 AM
