Project Procrastination, a TJuggy Build 42" pitbulls, stretched, on tons - Page 7 - JeepForum.com
 1Likes
post #91 of 624 Old 02-21-2011, 11:40 PM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Took measurements to see how to run my shocks. It looks like I will be able to run 13" travel shocks front and rear with my 4.5" RE coils.
I plan on using the Ford F250 mounts front and rear.
I got a good deal on a pair of 11" BBCS and pair of 13" BBCS I may end up selling the 11s and buy 13s.
I will have to cut out the rear upper mounts to run the new ones. To run the 13s in the rear I will need to raise the upper mount 6.5" from it's current location. This will also allow me to raise the lower mount up about an inch to get it parallel to the ground.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #92 of 624 Old 02-28-2011, 10:08 AM Thread Starter
JeepRocks86
Did some work over the weekend. I am now running a 13" travel shock in the rear on the driver side. The passenger side is tonight.
I also lengthened the wheel base a little as well.
We're headed to Harlan this coming weekend if anyone is interested in Joining.
For Sale:
post #93 of 624 Old 02-28-2011, 11:52 PM Thread Starter
JeepRocks86
maybe tomorrow I'll get some photos. The driver side is pretty much finished. It needs paint.
Today I cut the old upper shock mounts out. I would have worked more but, I ran out of welding wire.
For Sale:
post #94 of 624 Old 03-01-2011, 07:10 AM
mallard15
Sounds good man. Can't wait to see it. Jeep looking good.
Bestop Extendatrunk for sale (150$) PM me
Yukon 4.10 R&P Gears Set (300$) PM me
mallard15 is offline
post #95 of 624 Old 03-01-2011, 09:23 PM Thread Starter
JeepRocks86
Well I wasn't able to get the same wire because of work and then school.
My JCR over knuckle steering and axle side track bar bracket came in today. So much for it taking 15+ Days. I believe it shipped monday.
I wanted to go in the garage this evening, but I have too much school work right now.
Currently the passenger side has a huge notch in it for where the mount should go.
It will have to be welded up by friday because it's getting put on a trailer and taken to Harlan friday.
For Sale:
post #96 of 624 Old 03-03-2011, 07:21 PM Thread Starter
JeepRocks86
it's not super pretty but it will work.
That is the full 14" of the F250 shock tower. I cut the angle out of it and used filler metal to fill in the remaining triangle. The lower mounts are parallel to the ground.
For Sale:
post #97 of 624 Old 03-03-2011, 07:40 PM
mallard15
Looks good. Im sure you will like the long shocks
post #98 of 624 Old 03-04-2011, 08:55 AM Thread Starter
JeepRocks86
I did some more work last night. test fit the tires and flexed them out. Had to grind a little bit on the fenders to clear the extra .5" of wheel base. Also did some painting and other stuff.
I was only able to work for about 2 hours because I didn't get out to the garage until after 12am and worked until a little past 2am. School has to come first...
I still have lots to do before my trip today.
For Sale:
post #99 of 624 Old 03-07-2011, 12:28 PM Thread Starter
JeepRocks86
Overall the weekend wasn't very good.
I broke my short side dana 30 chromo shaft at the carrier on the first rock, which wasn't even a hard spot. I'm thinking the shaft may have already been cracked or previously stressed which is why it may have broken.
After pulling the axle out, draining the diff, and pounding the U joint out, we were unable to get the part out of the differential without removing the carrier. I did run the rest of the day with just the stub shaft and 3 wheel drive.
The longer shocks did really help the jeep ride on the trail at higher speeds. At some points I was able to hit 35mph on some of the gravel wash out roads at Harlan. The 4 door basically stock JK and my buddy with a short arm TJ were unable to keep up with myself and the other guy in our group with long arms and air shocks up front.
I'm supposed to be getting a phone call on where to send my axle shaft for a replacement.
For Sale:
post #100 of 624 Old 03-07-2011, 12:34 PM
aaronb
Sharp jeep!!
aaronb is offline
post #101 of 624 Old 04-13-2011, 12:55 AM Thread Starter
JeepRocks86
I'm going to pick up a 1979 King Pin Dana 60 out of a Snow Fighter 250 Tomorrow.
For Sale:
post #102 of 624 Old 04-13-2011, 07:08 AM
mallard15
Nice man. It's getting a little more interesting now haha.
post #103 of 624 Old 04-13-2011, 08:30 AM
Lamont_24
When you say Harlan, are you going to Black Mountain or where?
Purple Jeep Club member #13
Lamont_24 is offline
post #104 of 624 Old 04-13-2011, 08:57 AM Thread Starter
JeepRocks86
black mountain.
plan is
538s
ARBs
35 spline outers to begin with
35 spline warn hubs
high steer arms (already have a PSC box)
RCV's or other shafts are in the distant future
35 spline rear shafts
For Sale:
post #105 of 624 Old 04-13-2011, 10:44 AM
REDLYNER
REDLYNER's Avatar
Originally Posted by JeepRocks86 View Post
black mountain.
plan is
538s
ARBs
35 spline warn hubs
I'm jealous.
Sweet build man! We will have to meet up on one of these trails, I'm in NC, but wheel all over the SE.
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
14b , custom , hardcore , hp60 , indyorv , pitbull , psc , rockers
Project Ton Ton - 1 Ton Cherokee HP60/14b andrewmacc Jeep Builds 300 10-08-2014 08:46 AM
cj's on coilovers 80CJ5SBC Jeep Picture Requests 3 12-13-2011 10:12 AM
Coilovers YJCRAZY1995 Jeep Picture Requests 4 12-06-2011 02:51 PM
WJ with shaved cladding JSRichar5985 Jeep Picture Requests 2 05-23-2011 12:35 AM
Lets see some coilovers! ljs89 Jeep Picture Requests 0 07-10-2009 07:59 AM
