Project Pissed Wife Phase II 5.3L Vortec and 4L60e install! - Page 7 - JeepForum.com
post #91 of 1067 Old 08-26-2012, 04:16 PM Thread Starter
Why J?
Why J?'s Avatar
Mounts are burned in and the motor is in for good. Also got the rear drive shaft and the throttle cable in. I ended up using the Jeep throttle cable, the GM cable is about an inch to short.
Jeep cable mounted to GM intake and throttle body.
Also looks like the truck mechanical fan is going to work.
Need to figure out a trans mount. If anyone has an idea let me know. I think I found a radiator I want just need to pull the trigger in it. Need wiring and exhaust.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #92 of 1067 Old 08-26-2012, 09:35 PM
BionicOnion
wow man looking good. i thought about trying the jeep throttle cable but mine didn't seem to work at all. maybe ill have to take another look at that. also let me know what you come up with for radiator hoses. im trying to figure out how to get around the intake.... ugg project is right
BionicOnion is offline
post #93 of 1067 Old 08-26-2012, 11:12 PM Thread Starter
Why J?
Why J?'s Avatar
I want to say I saw some hose part numbers on the Novak swap guide or there radiator page. Might be a place to start.
Why J? is offline
post #94 of 1067 Old 08-27-2012, 11:21 AM
HARLEYX2
1987 YJ Wrangler
What are you gonna run for fuel lines?
HARLEYX2 is offline
post #95 of 1067 Old 08-27-2012, 11:24 AM Thread Starter
Why J?
Why J?'s Avatar
I am going to run a new 3/8" supply line and use the Jeeps existing 5/6" supply line as the return.
Why J? is offline
post #96 of 1067 Old 08-27-2012, 11:52 AM
scubamc
Not sure if it will help but I use a lower hose from 1986 Nissan V6 truck and the upper hose is from a 04 Yukon.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #97 of 1067 Old 08-27-2012, 12:09 PM Thread Starter
Why J?
Why J?'s Avatar
Got any part numbers?
What Rad are you running?
Why J? is offline
post #98 of 1067 Old 08-27-2012, 12:51 PM
scubamc
I thought I saved the tags off the hoses but they are not in the "money pit" file. The radiator is a universal one that we welded mounting tabs to.
scubamc is offline
post #99 of 1067 Old 08-27-2012, 12:55 PM Thread Starter
Why J?
Why J?'s Avatar
What did you do about the temp sender?
I have looked at several adapters and the difference between the sender 1/8 npt and the plug 12m-1.5 isn't much. I think an adapter would be kind of brittle.
I have my machine shop here at work drilling out the plug and taping it to 1/8 npt but I dont know if that will work. I was thinking that the steel would be less likely to fail over brass.
Why J? is offline
post #100 of 1067 Old 08-27-2012, 01:39 PM
MattGATRTJ
To answer 2 questions. I used stock jeep hose cut in half for the upper. Also I bought a cheap radiator hose adapter from ebay and drilled it out to 3/8 npt and a 1/8 npt. The 3/8 npt hole I connected the jeep temp sensor. To the 1/8 npt, I put a nipple fitting here and routed the head vent hose to it.
You can see here. The sensor is installed but the vent hose was not yet.
Also used the AA transmission mount and made a crossmember.
MattGATRTJ is offline
post #101 of 1067 Old 08-27-2012, 01:43 PM
MattGATRTJ
If you have access to a machine shop you can have the sensor turned down and re threaded.
post #102 of 1067 Old 08-27-2012, 01:50 PM Thread Starter
Why J?
Why J?'s Avatar
The sensor is smaller than the hole. Tried having an adapter made to go from 1/8 to 12m but the material is too thin and just tares when you put any torque on it.
Why J? is offline
post #103 of 1067 Old 08-27-2012, 02:00 PM
MattGATRTJ
Oh, early sensor must be smaller. Mine was 3/8" npt. I would go with the adapter in the hose, they are already tapped for 1/8"npt.
post #104 of 1067 Old 08-27-2012, 02:14 PM Thread Starter
Why J?
Why J?'s Avatar
I have looked at the AA trans mount and Im not sure if that is the route I am going. I have the Novak 231 shifter and I need to figure out if they will work with each other.
What kind of ticks me off is that there are mount holes drilled and tapped in the adapter it self. But to my knowledge they do not sell a mount that works there.
Why J? is offline
post #105 of 1067 Old 08-27-2012, 02:21 PM Thread Starter
Why J?
Why J?'s Avatar
I am still thinking on this. I would prefer the sender to be in the block. But if it cant happen then I will put it in one of the heater the hoses. Since they are always seeing water from the block.
Why J? is offline
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 85 02-25-2016 05:51 PM
Project "Pissed Wife" Why J? Jeep Builds 262 02-17-2014 09:06 AM
5.3L Vortec / 4L60E Engine swap mweber01 YJ Wrangler Technical Forum 9 08-10-2011 04:46 PM
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 11 08-19-2007 12:22 PM
phase 1 fix up project complete-take a look! BruceDJames YJ Wrangler Technical Forum 4 12-28-2005 07:23 PM
