Project Pissed Wife Phase II 5.3L Vortec and 4L60e install! - Page 62 - JeepForum.com
post #916 of 1067 Old 04-21-2013, 07:50 PM
Cajun90YJ
50 series flowmaster sounds good on acceleration, no loud drone in the cab, quiet at an idle.
Cajun90YJ is offline
post #917 of 1067 Old 04-21-2013, 08:15 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
I've been looking at walker quiet flow mufflers for my SBC set up. I am so over the flow masters. If that doesn't get me quiet enough then I'm going to put in some hi flow resonators as well .
http://item.mobileweb.ebay.com/viewi...id=79643067907
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #918 of 1067 Old 04-22-2013, 06:07 AM
Ripper3494
Isn't 2.25 a little small?
Sent from AutoGuide.com App
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #919 of 1067 Old 04-22-2013, 06:16 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Not for true dual. I'm sure I have less than 300 hp. No need for 2-1/2. If I had a cross over to single exhaust then yes.
March 2017 YJOTM
87TPIYJ is offline
post #920 of 1067 Old 04-22-2013, 06:21 AM
Ripper3494
Ah ok duals that makes sense.
build thread:
RC vs BDS
post #921 of 1067 Old 05-08-2013, 08:08 PM Thread Starter
Why J?
Why J?'s Avatar
I have been driving the Jeep the last week or so and nothing fell off. It has been running great. I got the shifter boot on and wired in the Dakota digital box to give the ECU a VSS signal and it works fine. The boot bolted up in the stock location and I mounted the Dakota box under the dash near the fuse box to keep it dry.
I did notice that my temps are a little lower with the manual. I think that the auto added some heat through the rad along with the extra cooler in front of the rad reduced some flow. So I am happy about that.
Overall the Jeep is a blast to drive and I am very happy with it. I will be going wheeling for the first time in over a year this weekend so the boys are pumped about that. I don't have any plans for more mods till this fall/ winter.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #922 of 1067 Old 05-17-2013, 03:10 PM
texasblackdirt
I'm glad you're not pissed off at it anymore and everything seems to be going good. I just added a pic of my rig to my build thread that's sure to get a laugh!
texasblackdirt is offline
post #923 of 1067 Old 05-25-2013, 08:24 AM
jeepcj304
how did you level the front end to accomodate the weight? i'm running 2" bbs with shocks. thought about the ome 934s to bring it up a bit more.
ROGUE7
jeepcj304 is offline
post #924 of 1067 Old 05-25-2013, 11:13 AM Thread Starter
Why J?
Why J?'s Avatar
I didn't have to anything, the 5.3 and 4.0 are relatively the same weight. The 5.3 is slightly lighter but my suspension sits the same as it did before the swap.
Why J? is offline
post #925 of 1067 Old 05-25-2013, 10:32 PM
caoboy
Can you go run it on 1/4 mile track? I'd love to see a vortec Jeep stacks up to other vehicles.
caoboy is offline
post #926 of 1067 Old 05-26-2013, 04:01 PM
Rabbitsh
Im sorry, I was checking all the posts and watched this image about "made in Chena"... i cant hold the impulse to post it on 9gag... lol. So here is the link so u can vote to share this image around the world...
http://9gag.com/gag/aYNznrw/
Rabbitsh is offline
post #927 of 1067 Old 05-27-2013, 03:44 PM
jeepcj304
Gotcha. I swapped from 2.5 and shocks bottomed out.
ROGUE7
post #928 of 1067 Old 05-27-2013, 05:03 PM Thread Starter
Why J?
Why J?'s Avatar
Then you will need to upgrade to a 4.0 spring and shock.
Why J? is offline
post #929 of 1067 Old 05-27-2013, 08:08 PM
texasblackdirt
Or go ahead and lift her on up some if you can afford it right now.
post #930 of 1067 Old 06-01-2013, 06:42 PM
8pitcher
8pitcher's Avatar
Weren't people swapping in 4.3's?
8pitcher is offline
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 85 02-25-2016 04:51 PM
Project "Pissed Wife" Why J? Jeep Builds 262 02-17-2014 08:06 AM
5.3L Vortec / 4L60E Engine swap mweber01 YJ Wrangler Technical Forum 9 08-10-2011 03:46 PM
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 11 08-19-2007 11:22 AM
phase 1 fix up project complete-take a look! BruceDJames YJ Wrangler Technical Forum 4 12-28-2005 06:23 PM
