Project Pissed Wife Phase II 5.3L Vortec and 4L60e install! - Page 60 - JeepForum.com
post #886 of 1067 Old 03-18-2013, 10:47 PM
Chrisnvegas
Chrisnvegas's Avatar
Very cool. Tastefully done...
My Jeep was running hot on the highway as well. I took my old brass radiator to a shop, had it rebuilt. At the same time, I replaced the belts, hoses, thermostat, cleaned out the block and heater core, replaced the water pump with a quality mopar, (Hey, it lasted 20 years?) and bought a new AC Delco fan clutch. Pretty much a new cooling system. It's not really the highway so much, but I use my Jeep at Dumont Dunes a lot. Sand dunes will find a weak cooling system, and they did.
I don't like globbing on RTV. I use only a thin layer of aviation gasket sealer applied carefully with a q tip.
I know there are all kinds of threads about electric fans, and how fans will never come on on the highway. I respectfully disagree with some of it. The clutch fan will come on whenever a predetermined amount of heat is absorbed by the thermo spring in front. (My fan will engage and make all kinds of noise while climbing a steep mountain road here in the summer. It's called 110 degrees!)
And, besides idle, there is no way I can imagine an electric fan moving the amount of air the clutch fan will move when locked in. I tested it and it sucks my shirt through the grill and into the radiator at only a thousand RPMs or so.
Anyway, I know you guys know more than me. I just wanted to throw my 2 cents in.
"Auto racing began 5 minutes after the second car was built."
Henry Ford
Chrisnvegas is online now
post #887 of 1067 Old 03-18-2013, 10:51 PM Thread Starter
Why J?
Why J?'s Avatar
I agree with every word. Exactly why I'm ruining a mechanical fan on mine.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #888 of 1067 Old 03-28-2013, 06:29 PM Thread Starter
Why J?
Why J?'s Avatar
Originally Posted by Cajun90YJ
Well its the first time I have run it on the freeway so Yea I guess it is new. I have everything plummed in and all full of fluids, I have been driving it for about 350 miles now around town and to work less then 3 miles. I was headed to the exhaust shop this morning to have my exhast tweeked and I noticed it creeping up. I did not try the heater.
Buckwild I don't think it is air I have no problems any other time, only on the freeway and it is very consistant not erratic.
I'm going to call novak in the morning,they wanted me to report back to them after I ran it without the winch. They told me that they have seen this problem from time to time with the YJ ( I'm like WTF they should put that next to the $800 price tag on the fan rad combo!) and were thinking of adding some air dams around the rad to force the air through the radiator,
What ever happened with this? We're you able to get is sorted out?
Why J? is offline
post #889 of 1067 Old 03-28-2013, 07:52 PM
Cajun90YJ
I ran it without the winch and like you said, no change. So I pressured it up with a cooling system pressure tester and it bleed down like three times I added coolant each time and it finally quit taking coolant. So it did have air in it, I would have bet money I got all the air out. Anyhow I drove it and 210 on the Hwy and 195 around town. It was 210 around town, I have-not put the winch back on yet though. Thanks for the input guys.
Cajun90YJ is offline
post #890 of 1067 Old 03-28-2013, 07:55 PM Thread Starter
Why J?
Why J?'s Avatar
Sounds like you got it squared away.
Why J? is offline
post #891 of 1067 Old 03-29-2013, 07:55 AM
USMCBuckWild
There ya go. Glad it was nothing serious.
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #892 of 1067 Old 04-07-2013, 03:47 PM
Duncan542
About to pull the 4 banger!
Duncan542 is offline
post #893 of 1067 Old 04-07-2013, 04:44 PM Thread Starter
Why J?
Why J?'s Avatar
Saweet! Get that crap outta there!
Why J? is offline
post #894 of 1067 Old 04-07-2013, 04:58 PM
Duncan542
Clear your pms why j!
post #895 of 1067 Old 04-07-2013, 05:04 PM Thread Starter
Why J?
Why J?'s Avatar
Cleared
Why J? is offline
post #896 of 1067 Old 04-09-2013, 03:44 AM
Duncan542
Engine, tranny, t case all in one shot.
post #897 of 1067 Old 04-09-2013, 05:34 AM
texasblackdirt
I finally pulled a 5.3, 4l60e, harness and computer out of a wrecked 2000 for 1000 even on Sunday. The PO died of a heart attack behind the wheel, and crashed the pickup
texasblackdirt is offline
post #898 of 1067 Old 04-09-2013, 08:43 PM
USMCBuckWild
Craigslist inEastern NC:
All aluminum 6.0 with computer, complete wiring, 4L60Ecomplete, t-case, running with fresh bearings: $1,800 or best offer.
Wish I had some extra $$$$ hangin around.
post #899 of 1067 Old 04-09-2013, 08:48 PM
Ripper3494
Wish I was in NC... I'd be all over that lol. Then I'd have 4 running 6.0s in the garage. Well ones a 6.4, but it was a 6.0
Sent from AutoGuide.com App
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #900 of 1067 Old 04-09-2013, 08:59 PM
texasblackdirt
Rub it in a hole! Lol
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 85 02-25-2016 05:51 PM
Project "Pissed Wife" Why J? Jeep Builds 262 02-17-2014 09:06 AM
5.3L Vortec / 4L60E Engine swap mweber01 YJ Wrangler Technical Forum 9 08-10-2011 04:46 PM
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 11 08-19-2007 12:22 PM
phase 1 fix up project complete-take a look! BruceDJames YJ Wrangler Technical Forum 4 12-28-2005 07:23 PM
