Project Pissed Wife Phase II 5.3L Vortec and 4L60e install! - Page 59 - JeepForum.com
post #871 of 1067 Old 03-10-2013, 07:54 AM
texasblackdirt
Originally Posted by USMCBuckWild
Why J, you have to remember: Hindsight is 20/20.
All in all, this was an amazing build with a very informative and descriptive writeup from a detail oriented professional. Its rather typical that someon looks back and has mixed feelings about a project. You Sir, should have no qualms. You went theough alot of ***-pain, Identified issues and influenced serious changes with a major manufacturer and paved the way for alot of the rest of us to get off our a$$es and get started on something.
You want a real project? I'll trade you MY YJ!
Lol
texasblackdirt is offline
post #872 of 1067 Old 03-12-2013, 03:28 PM Thread Starter
Why J?
Why J?'s Avatar
I really appreciate that, thank you.
Now that I think about it I was able to sell the 4.0 for more than I paid for the 5.3/4L60e. If I had waited till it blew I would have been out those funds.
I appreciate the offer for the trade but I have had enough projects for the year. I plan on driving the crap out of my Yj, then this winter get into another project.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #873 of 1067 Old 03-12-2013, 03:33 PM
texasblackdirt
Not so bad after all
post #874 of 1067 Old 03-18-2013, 06:35 AM
Cajun90YJ
Whyjwhat thermostat are you using and White temp are you running at Hwy speed? I have a stock thermostat and I seem to be running about 212 to214 on the Hwy. That seems a little high to me. I am going to check it with my scan tool this afternoon to verify my computer agrees with my gauge
Cajun90YJ is offline
post #875 of 1067 Old 03-18-2013, 06:49 AM
Ripper3494
Thats a bit above where mine runs. My fan kicks on at 210 but on the highway it usually runs 208-210 (stock thermo for me)
Probably sent from under my broken heep
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #876 of 1067 Old 03-18-2013, 08:45 AM Thread Starter
Why J?
Why J?'s Avatar
I am running the stock thermostat.
I am showing on my stock gauge right @195-197 on the highway. Which is very close to what the ECU is seeing.
The gauges are inaccurate at best is the older YJ if you are running stock gauges.
When you check your temps if they are a little high look at your fuel trims. If you are leaning out it can cause you to run a little warm.
Why J? is offline
post #877 of 1067 Old 03-18-2013, 02:14 PM
Cajun90YJ
I'm running autometer gauges and at lunch I was able to drive it with my scanner hooked up, my gauge is accurate I am running 221 to 223 on the freeway at about 75 to 80mph but as soon as I get off and drive around town it drops to 195 to 208. Fan comes on at 205 and goes off 195 I beleive. It will idle all day long with no problems, I wonder if my a/c condensor and trans cooler are blocking flow. I will drive it after work and check the fuel trims.
post #878 of 1067 Old 03-18-2013, 04:57 PM Thread Starter
Why J?
Why J?'s Avatar
What rad are you running?
Why J? is offline
post #879 of 1067 Old 03-18-2013, 06:52 PM
Cajun90YJ
Running a novak radiator and electric fan , I called novak and they told me that my winch was causing it so I removed the winch and tryed it again while checking my fuel trim. Trim looks good and it is better but it is still running hotter than it should 218 at freeway speed 75 and 80. Not sure but I think it may be the radiator
post #880 of 1067 Old 03-18-2013, 07:07 PM Thread Starter
Why J?
Why J?'s Avatar
Is this a new problem?
The winch being there is bull****. I have a winch in front if mine.
I am assuming you have a full coolant system? , fan shroud, over flow tank, heater core plumed in, everything?
Does running the cab heater help cool things down?
And Novak is just south of worthless as far as diag goes.
Why J? is offline
post #881 of 1067 Old 03-18-2013, 07:44 PM
USMCBuckWild
Poor circulation will cause it as well. Poor circulation, a LARGE air bubble in the cooling system as well. The old Chrysler small blocks were notorious for the water pump becoming airbound and the engine overheating and acting erraticly.
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #882 of 1067 Old 03-18-2013, 08:38 PM
Chrisnvegas
Chrisnvegas's Avatar
WhyJ, when you get a chance, can you post a pic of your Jeep in the driveway? I have read every word in the thread and have actually been looking forward to seeing it on the road!
(I know, I need to get a life)
Incredible build...
My Jeep is NOT a Fiat!
Chrisnvegas is online now
post #883 of 1067 Old 03-18-2013, 08:51 PM
Cajun90YJ
Well its the first time I have run it on the freeway so Yea I guess it is new. I have everything plummed in and all full of fluids, I have been driving it for about 350 miles now around town and to work less then 3 miles. I was headed to the exhaust shop this morning to have my exhast tweeked and I noticed it creeping up. I did not try the heater.
Buckwild I don't think it is air I have no problems any other time, only on the freeway and it is very consistant not erratic.
I'm going to call novak in the morning,they wanted me to report back to them after I ran it without the winch. They told me that they have seen this problem from time to time with the YJ ( I'm like WTF they should put that next to the $800 price tag on the fan rad combo!) and were thinking of adding some air dams around the rad to force the air through the radiator,
post #884 of 1067 Old 03-18-2013, 08:52 PM Thread Starter
Why J?
Why J?'s Avatar
Incredible build...
Here ya go.
Why J? is offline
post #885 of 1067 Old 03-18-2013, 09:01 PM Thread Starter
Why J?
Why J?'s Avatar
The Yj and Tj have the same area for a radiator, hell they use the same radiator so I find that hard to believe. Maybe they know something I don't, but I doubt it.
I have had a issue with my Jeep over heating only on the highway before my swap and it was a clogged up rad. It flowed fine at idle and around town but over heated on the highway.
Your not overheating 220 is a normal operating temp.
I would look at air flow and coolant flow. Bad water pump, upper rad hose collapsing at higher Rpm's.
Trying running the heat to make sure it works and to see if it will cool things down.
Why J? is offline
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 85 02-25-2016 04:51 PM
Project "Pissed Wife" Why J? Jeep Builds 262 02-17-2014 08:06 AM
5.3L Vortec / 4L60E Engine swap mweber01 YJ Wrangler Technical Forum 9 08-10-2011 03:46 PM
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 11 08-19-2007 11:22 AM
phase 1 fix up project complete-take a look! BruceDJames YJ Wrangler Technical Forum 4 12-28-2005 06:23 PM
