Project Pissed Wife Phase II 5.3L Vortec and 4L60e install! - Page 58 - JeepForum.com
post #856 of 1067 Old 03-06-2013, 12:31 PM
texasblackdirt
Spline engagement not quite right, from the output shaft to the tcase? No idea why you would only have this problem in neutral.
texasblackdirt is offline
post #857 of 1067 Old 03-06-2013, 12:32 PM Thread Starter
Why J?
Why J?'s Avatar
Originally Posted by REDnBLUES View Post
The way you describe this, are you saying that when you the vibration, the clutch pedal is pushed in? Or is the clutch pedal not a factor?
The only time it does not do it is when I am driving down the road.
If I rev it with the clutch pushed in it does it. If I put the trans in neutral with the clutch out, it does it.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #858 of 1067 Old 03-06-2013, 12:33 PM Thread Starter
Why J?
Why J?'s Avatar
It should be fine.
Remember it does the same thing with no trans even bolted up to the engine.
Why J? is offline
post #859 of 1067 Old 03-06-2013, 12:36 PM
texasblackdirt
Motor mounts pissed off from being on and off over and over? Pipe your intake and exhaust outside the garage so it will be as quiet as possible, stick a piece of hose in your ear, and have your wife hold it steady at 1500 rpms while you have a listen
post #860 of 1067 Old 03-06-2013, 12:41 PM Thread Starter
Why J?
Why J?'s Avatar
Ill give that a try.
Thanks.
Why J? is offline
post #861 of 1067 Old 03-06-2013, 12:47 PM
texasblackdirt
I hope that gets it pinpointed. It has a good chance of working, turning the engine noise down and the vibration up. If you had somebody else who knew what they were doing to help you could get a real long piece of fuel line, and have the other guy move it around all over the place.
post #862 of 1067 Old 03-09-2013, 12:35 PM Thread Starter
Why J?
Why J?'s Avatar
Figured out my vibration today. Ended up being an out of balance flywheel.
I had the only mechanic I trust check it out for me. Took it to a local clutch shop this morning and had the flywheel and the pressure plate neutral balanced. Ended up costing me a $70 diag fee and a $35 balance charge.
Got it all back together this afternoon and all is well.
I'm going to call Novak in the morning. They advised me that this flywheel was neutral balanced and didn't need to be balanced.
Need to paint the skid and get the trans cover and boot installed and then she is done....... For now.
Why J? is offline
post #863 of 1067 Old 03-09-2013, 03:17 PM
texasblackdirt
And now you don't want to sell it! Hells yeah brother glad u got it worked out!
post #864 of 1067 Old 03-09-2013, 07:08 PM Thread Starter
Why J?
Why J?'s Avatar
I wasn't saying I would sell it. I was reconsidering the swap. And I still stand by that. What I meant is that unless you have an engine issue than the swap isn't worth it. Until you need to replace the engine. Then it is a good swap.
I am stupid because I had a perectly, low mile drive train and ripped it out.
That was dumb.
I love the power and torque of the 5.3L. But I should have waited for the 4.0 to blow and spend the cash and upgarding other companents.
Why J? is offline
post #865 of 1067 Old 03-09-2013, 07:27 PM
texasblackdirt
Oh well you said you were at a loss and seriously considering your rig so I thought that's what you meant
post #866 of 1067 Old 03-09-2013, 07:42 PM Thread Starter
Why J?
Why J?'s Avatar
I went back and reread my post. I need to edit it. I was posting from my phone.
It should read I was reconsidering my decision to swap in the 5.3. It currently reads like I was considering sellig my rig. Which itsn't gonna happen.
Why J? is offline
post #867 of 1067 Old 03-09-2013, 07:42 PM
texasblackdirt
I started with a 4 cylinder that had a chunk missing out of the block, oil pan and intake. Used for only 00-03 I am spending the same on the swap as I would have replacing that engine. 2.3 I think it was. Got the black TJ for 3200, sold 1100 in parts from it, and spent 800 on black hard top, so I'm 2900 in, plus the swap parts I took off your hands.
post #868 of 1067 Old 03-09-2013, 07:45 PM
texasblackdirt
Yeah no sense in selling it anyway. Drive it till it runs like crap, sell 5.3 swap complete bolt on assembly, and buy a heavily modded 4.0 stroker.
post #869 of 1067 Old 03-09-2013, 07:58 PM Thread Starter
Why J?
Why J?'s Avatar
No it runs good.
I had a good drive train and shouldn't have considered a swap until it was crap. Other than the normal swap headaches it is a good swap.
If I had it to do over again I would have waited till my 4.0 crapped the bed.
Your in a perfect place to swap.
Why J? is offline
post #870 of 1067 Old 03-10-2013, 07:44 AM
USMCBuckWild
Why J, you have to remember: Hindsight is 20/20.
All in all, this was an amazing build with a very informative and descriptive writeup from a detail oriented professional. Its rather typical that someon looks back and has mixed feelings about a project. You Sir, should have no qualms. You went theough alot of ***-pain, Identified issues and influenced serious changes with a major manufacturer and paved the way for alot of the rest of us to get off our a$$es and get started on something.
You want a real project? I'll trade you MY YJ!
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 85 02-25-2016 04:51 PM
Project "Pissed Wife" Why J? Jeep Builds 262 02-17-2014 08:06 AM
5.3L Vortec / 4L60E Engine swap mweber01 YJ Wrangler Technical Forum 9 08-10-2011 03:46 PM
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 11 08-19-2007 11:22 AM
phase 1 fix up project complete-take a look! BruceDJames YJ Wrangler Technical Forum 4 12-28-2005 06:23 PM
