Project Pissed Wife Phase II 5.3L Vortec and 4L60e install! - Page 55 - JeepForum.com
post #811 of 1067 Old 02-17-2013, 03:11 PM Thread Starter
Why J?
Why J?'s Avatar
Originally Posted by texasblackdirt
Yo why j, clear out your messages and specify what measurements you request. All the stuff I bought from you is sitting right in my living room until I can sell my old ford pickup and buy some more parts.
Cleared. I need the measurement from the bottom of the mount to the bottom mounting hole for the t case.
That make sense?
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #812 of 1067 Old 02-17-2013, 03:17 PM Thread Starter
Why J?
Why J?'s Avatar
Texasblackdirt
In the pic, I need from the bottom to which ever hole I used on the mount. See pic.
Why J? is offline
post #813 of 1067 Old 02-17-2013, 03:27 PM
texasblackdirt
I'm calling it 3 and 11/16ths from the bottom edge of the mount, where it bolts to your crossmember or skid plate, to the center of the bolt holes that have been used. You used two lower bolts and one upper in the mount as far as I can tell, and the two lowers were at the same height
texasblackdirt is offline
post #814 of 1067 Old 02-17-2013, 03:54 PM Thread Starter
Why J?
Why J?'s Avatar
Your email said it was 3 and 7/16?
Which is it?
Why J? is offline
post #815 of 1067 Old 02-23-2013, 03:08 AM
beemerkid
Since I didnt pull my engine myself I dont have an intake, what do yall think about using a simple aftermarket cold air intake designed for a stock gm truck application. I was thinking the spectre 9900. At the least it would be easy and look clean.
http://www.jegs.com/i/Spectre/865/9900/10002/-1
beemerkid is offline
post #816 of 1067 Old 02-23-2013, 05:43 AM Thread Starter
Why J?
Why J?'s Avatar
You will probably have to cut it down some. But I basically did the same thing except I used an intake from Airraid.
Why J? is offline
post #817 of 1067 Old 02-23-2013, 05:49 AM
beemerkid
Sounds perfect. And from what i can tell they retain the MAF right behind the filter yes?
post #818 of 1067 Old 02-23-2013, 06:21 AM Thread Starter
Why J?
Why J?'s Avatar
Correct.
Just don't make the mistake I did and put a turn in the air flow right in front of the MAF. It will screw up your MAF readings and lead to a lean condition.
Why J? is offline
post #819 of 1067 Old 02-23-2013, 06:25 AM Thread Starter
Why J?
Why J?'s Avatar
I am still waiting on parts. I think I have the clutch figured out and installed. Trans is in, t case is in. I just need my new Under Cover Fab skid to show up and I can get the drive shafts in. Which may need to be lengthened. Not sure yet.
I would of had this all wrapped up but I forgot to order my skid. The stock one will work, but mine is cut up from using the automatic and I don't want to mess around with modifying it to work with the 5 speed, when I going to replace it anyhow. Its been cold and raining here so Im not in a big hurry to get it all done.
Why J? is offline
post #820 of 1067 Old 02-23-2013, 01:39 PM
beemerkid
Correct.
Thanks for the tip, I remember you having problems with that earlier.
post #821 of 1067 Old 02-28-2013, 07:32 PM
texasblackdirt
When is the skid plate gonna be there? Surely you are tracking the shipment by now.
post #822 of 1067 Old 02-28-2013, 07:46 PM Thread Starter
Why J?
Why J?'s Avatar
Got the skid plate yesterday. i'm in the garage making a trans mount. then it test drive time.
Why J? is offline
post #823 of 1067 Old 02-28-2013, 07:54 PM
texasblackdirt
Sweet! Post pics when you're happy with it
post #824 of 1067 Old 02-28-2013, 08:12 PM Thread Starter
Why J?
Why J?'s Avatar
modded 4.0 trans mount bracket.
Why J? is offline
post #825 of 1067 Old 02-28-2013, 08:40 PM
texasblackdirt
Just a couple notches and two new holes as far as I can tell. Is that what was done?
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 85 02-25-2016 04:51 PM
Project "Pissed Wife" Why J? Jeep Builds 262 02-17-2014 08:06 AM
5.3L Vortec / 4L60E Engine swap mweber01 YJ Wrangler Technical Forum 9 08-10-2011 03:46 PM
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 11 08-19-2007 11:22 AM
phase 1 fix up project complete-take a look! BruceDJames YJ Wrangler Technical Forum 4 12-28-2005 06:23 PM
