Project Pissed Wife Phase II 5.3L Vortec and 4L60e install! - Page 54 - JeepForum.com
post #796 of 1067 Old 02-10-2013, 12:16 PM Thread Starter
Why J?
Why J?'s Avatar
It was confirmed I r dumb.
I kicked the jack stand out from under it. Vibs gone.
Thanks Ripper.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #797 of 1067 Old 02-15-2013, 07:26 PM
HARLEYX2
1987 YJ Wrangler
[QUOTE=Why J?;14158169]Unfinished up my fuel system last night. I pressure tested it and have. I leaks with good pressure at the rail.
I went with AN from the rail to the frame just over the trans skid to hard lines. Put the new filter, Fram G15 $4.99, and filter mount, conduit holder $2.50, in the stock location. Ran some fuel injected hose on back to the pump.
Over all it was a pain dealing with the hard lines. If I did it over again I would go all AN.
Do the fuel rail fittings you used have metal clips in them or how do they connect to the fuel rail? The russell ones I got have plastic clips in them.
HARLEYX2 is offline
post #798 of 1067 Old 02-15-2013, 07:36 PM Thread Starter
Why J?
Why J?'s Avatar
I didn't get the ones with the clips, I had read that they can come loose and spray gas all over your runnin engine.
I went with the updated Russell fittings that screw together.
Why J? is offline
post #799 of 1067 Old 02-16-2013, 04:30 AM
beemerkid
Im trying to plan out my fuel system for a 2003 4.8L with the regulator on the rail. Its a long story but suffice it to say I own the engine but I wont see it for another few months. If im correct I can use Russell to AN at the fuel rail, but Im unsure af what I should do from the pump to there. Should I just run all new fuel injection hose to the pump? Go from the hard lines alont the frame? Ive never done fuel system work outside of swapping out a fuel pump but I want to do it right and would appreciate any input that yall have, since you have personal experience.
beemerkid is offline
post #800 of 1067 Old 02-16-2013, 06:32 AM Thread Starter
Why J?
Why J?'s Avatar
I used rubber FI line from the pump to the filter, you can keep the stock FI line it is 3/8. Then from the filter I used 3/8 hard line to the AN stuff up to the fuel rail. If I had to do it over again I would use rubber FI line from the pump to the filter and then all AN.
Why J? is offline
post #801 of 1067 Old 02-16-2013, 12:13 PM
beemerkid
Ok thanks. I think you mentioned some of it earlier in the thread but I couldnt find it, do you remember what the sizes are for any of this? If im correct the supply and return on the pump are barbs for a 3/8 FI hose. Do you by chance know the sizes on the rail? Im pretty sure youve said this all before so thanks.
post #802 of 1067 Old 02-16-2013, 12:23 PM Thread Starter
Why J?
Why J?'s Avatar
3/8 supply, 5/16 return.
Why J? is offline
post #803 of 1067 Old 02-16-2013, 02:11 PM
beemerkid
Thanks WhyJ
post #804 of 1067 Old 02-16-2013, 02:14 PM Thread Starter
Why J?
Why J?'s Avatar
Thanks WhyJ
No problemo.
Why J? is offline
post #805 of 1067 Old 02-16-2013, 06:14 PM
HARLEYX2
1987 YJ Wrangler
Do the fuel rail fittings you ordered have to have a special wrench to screw together? Also any pics of your finished air intake system?
HARLEYX2 is offline
post #806 of 1067 Old 02-16-2013, 06:24 PM
HARLEYX2
1987 YJ Wrangler
Also will a factory air intake tube work between the MAF and throttle body?
HARLEYX2 is offline
post #807 of 1067 Old 02-16-2013, 06:37 PM Thread Starter
Why J?
Why J?'s Avatar
If you don't want the fittings scratched up you need the anodized wrench. I put some tape on my adjustable wrench and they are fairly scratch free.
It should. Mine was ugly so I didn't reuse it.
Why J? is offline
post #808 of 1067 Old 02-16-2013, 06:58 PM
HARLEYX2
1987 YJ Wrangler
Yeah I dont care about scratches. The part Im talking about needing a special wrench for is the small part in front of the part that goes on the fuel rail.
HARLEYX2 is offline
post #809 of 1067 Old 02-16-2013, 07:34 PM Thread Starter
Why J?
Why J?'s Avatar
A wrench works fine.
Why J? is offline
post #810 of 1067 Old 02-17-2013, 03:07 PM
texasblackdirt
Yo why j, clear out your messages and specify what measurements you request. All the stuff I bought from you is sitting right in my living room until I can sell my old ford pickup and buy some more parts.
texasblackdirt is offline
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 85 02-25-2016 04:51 PM
Project "Pissed Wife" Why J? Jeep Builds 262 02-17-2014 08:06 AM
5.3L Vortec / 4L60E Engine swap mweber01 YJ Wrangler Technical Forum 9 08-10-2011 03:46 PM
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 11 08-19-2007 11:22 AM
phase 1 fix up project complete-take a look! BruceDJames YJ Wrangler Technical Forum 4 12-28-2005 06:23 PM
