Project Pissed Wife Phase II 5.3L Vortec and 4L60e install! - Page 11 - JeepForum.com
post #151 of 1067 Old 09-07-2012, 11:02 AM Thread Starter
Why J?
Why J?'s Avatar
After thinking it over and calling Summit I have decided that I am going with the AN stuff for the fuel lines,no point in c heaping out now and risking a fuel fire. I ended up getting the cost down to $95 which is a lot better than I originally thought. This gets me from the fuel rail down to the hard lines on the frame. My motor has the supply and return line at the rail.
EAR-165056ERL
Fitting, -6 AN Male to 5/16 in. Tube, Aluminum, Red/Blue Anodized, Each
$9.95 1 $9.95
RUS-644113
Adapter Fitting
$14.95 1 $14.95
RUS-644123
Adapter Fitting
$14.95 1 $14.95
SUM-2200077B
Fitting, Hose End, Tube Adapter, Straight, Male -6 AN Hose to 3/8 in. Tubing, Aluminum, Black, Each
$7.95 1 $7.95
SUM-220690B
Fitting, Hose End, Straight, -6 AN Hose to Female -6 AN, Aluminum, Black Anodized, Each
$4.88 4 $19.52
SUM-230606
Hose, Braided Stainless Steel, -6 AN, 6 ft. Length, Each
$26.95 1 $26.95
Part Subtotal$94.27
My radiator shows a delivery date of Monday, my Trans mount showed up a few days ago and I hope to get it installed this weekend. Should have my fuel done by end of next week. All I need is my harness, but who knows when that will show up. When I sent of off I was told 2 week turn around after receipt. That was the 10th of last month. So we are looking at 4 weeks now. Kind of pissing me off.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #152 of 1067 Old 09-07-2012, 11:55 AM
MattGATRTJ
If you havent pulled the trigger yet. You can get the push lock hose and fittings a little cheaper and its a lot easier to work with than the stainless braided stuff.
I ran 6an front to back twice for the pressure and return.
MattGATRTJ is offline
post #153 of 1067 Old 09-07-2012, 12:15 PM Thread Starter
Why J?
Why J?'s Avatar
I looked at that stuff. I didn't have a warm fuzzy about plastic line. I'm sure it is fine stuff, I know all new cars have it. Hell my GM car has rubber lines in the engine compartment.
For the cost and piece of mind it give me I went the more expensive route.
Why J? is offline
post #154 of 1067 Old 09-07-2012, 12:25 PM
MattGATRTJ
Its rubber. Same as the braided stuff minus the braid. I have worked with both. This stuff is the best. The an fittings are slightly different the way they connect. The hose is just a little cheaper. The blue hose is for high temps.
post #155 of 1067 Old 09-07-2012, 12:48 PM Thread Starter
Why J?
Why J?'s Avatar
I didnt think push loc was rated for gas? I thought it was only rated for oil and coolant. Now Russel has gas rated twist lok hose that is gas rated.
It's rubber fuel hose as far as I'm concerned and its not something I was comfortable with the exhaust being right there.
Why J? is offline
post #156 of 1067 Old 09-07-2012, 04:05 PM
HARLEYX2
1987 YJ Wrangler
Glad to see you have your fuel figured out. You are farther along than me on that for sure. LOL Take pics when you do it. Are you running all new feed and return to the tank or are you just gonna use your old factory feed as a return? Also who is doing your harness?
HARLEYX2 is offline
post #157 of 1067 Old 09-07-2012, 04:28 PM Thread Starter
Why J?
Why J?'s Avatar
I will. I want to make sure it all works before I post up incorrect info and someone else follows that bad info. Which is why my electrical isn't up yet.
My return line is 5/16 just like my supply line. So I am just going to tap into that. I ran all new 3/8 supply line.
Wayne over on Pirate4x4. I'm not really sure why isn't taking so long. It was suppose to be 2 weeks and that has come an gone. Right now I'm looking at 4 weeks. I know that he went on a week vacation the week after he received my harness. I sent him a PM this afternoon, but haven't heard back.
Why J? is offline
post #158 of 1067 Old 09-07-2012, 06:02 PM
HARLEYX2
1987 YJ Wrangler
Cool. We're you finally able to get the corvette manifolds to work ok?
HARLEYX2 is offline
post #159 of 1067 Old 09-07-2012, 06:37 PM Thread Starter
Why J?
Why J?'s Avatar
Uuuummmmm No! They hit the motor mounts. I'm not pulling the motor to clearence the mounts. So I sold the C6 manifolds and bought some 2012 Camero SS manifolds. They dump straight down at cylinder 4. Plenty O room.
Why J? is offline
post #160 of 1067 Old 09-07-2012, 09:50 PM
HARLEYX2
1987 YJ Wrangler
How much were they?
HARLEYX2 is offline
post #161 of 1067 Old 09-08-2012, 05:26 AM Thread Starter
Why J?
Why J?'s Avatar
How much were they?
$85. Same cost as the C6 manifolds.
Why J? is offline
post #162 of 1067 Old 09-08-2012, 09:14 AM
HARLEYX2
1987 YJ Wrangler
Any link to where to buy them and do you have pics of them installed? Thanks
HARLEYX2 is offline
post #163 of 1067 Old 09-08-2012, 09:17 AM Thread Starter
Why J?
Why J?'s Avatar
I purchased them on Ebay but I don't have them yet. They just shipped out yesterday from AZ.
You can see them installed in the Dookey Reverenge build on Pirate in the hardcore section.
Why J? is offline
post #164 of 1067 Old 09-09-2012, 02:09 PM
BionicOnion
hey whyj i told you i'd show u a few pics of my intake when i finished. only reason i'd change now is fan clearance. any updates on my egr valve and connector yet? i know you said it'd be a few weeks
onto the pics
i like it
shouldn't have any problems with upper rad hose now
BionicOnion is offline
post #165 of 1067 Old 09-10-2012, 01:18 PM Thread Starter
Why J?
Why J?'s Avatar
onto the pics
i like it
Lookin good!
I got word this morning that my wiring harness is inbound. Ill send you that stuff early next week.
I was out of town all weekend. Took the family to a cabin in the Smokey Mtns near Pigeon Forge. Needed the rest.
I did some work yesterday after getting back. Got the trans mount from AA installed. It was easy,and looks like it set the trans and tcase at the same height as the ax15/231. So that works out well. This allowed me to get the belly pan in and finalize the trans shifter and to get the trans cooler line run. So over all it was a productive day.
My radiator showed up today, really nice item. And my fuel lines should be here Tuesday. Exhaust manifolds are inbound and should be here by weeks end. So I feel like I am getting close, exhaust is the only thing I haven't nailed down yet but everything else needs to be in so that I can route that.
I don't have any pics right now that I can post up at work. I get that on here shortly.
Why J? is offline
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 85 02-25-2016 04:51 PM
Project "Pissed Wife" Why J? Jeep Builds 262 02-17-2014 08:06 AM
5.3L Vortec / 4L60E Engine swap mweber01 YJ Wrangler Technical Forum 9 08-10-2011 03:46 PM
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 11 08-19-2007 11:22 AM
phase 1 fix up project complete-take a look! BruceDJames YJ Wrangler Technical Forum 4 12-28-2005 06:23 PM
