Project Pissed Wife Phase II 5.3L Vortec and 4L60e install! - Page 10 - JeepForum.com
post #136 of 1067 Old 09-04-2012, 02:49 PM
USMCBuckWild
Originally Posted by Why J? View Post
So I do not know what to do about connecting the 3/8 and 5/16 hard lines to the GM fuel rail. I currently have a rubber line to make that transition. But Im not excited about it.
I have looked at the AN stuff and there is no way that I am spending $165 to make 2 3ft sections of tubing. That is insane.
Any ideas welcome.
You can find the exact same AN fittings in brass at the hardware store. If you have any extra line it easy to slap together a few lines. If not, go to a heavy equipment dealer (John Deere, Case, CAT) bring the fittings you need to adapt and have them make it. Made me custom power steering lines for $32 for both. I understand it doesn't have to be super high pressure, but The variety of fittings they have, they can make almost anything on the cheap.
USMCBuckWild is offline
post #137 of 1067 Old 09-04-2012, 02:52 PM
8pitcher
8pitcher's Avatar
Any ideas welcome.
A 3/8 to 5/16 adapter from home depot.
8pitcher is offline
post #138 of 1067 Old 09-04-2012, 11:02 PM Thread Starter
Why J?
Why J?'s Avatar
So I have the fuel lines all plumbed. I ended up using the rail quick connects from the motor and tieing those into the new lines. It was an obvious solution that was staring me in the face.
So now I want to energize the pump to make sure I have no leaks. I know that I need key on but how to do that. I figure I can jumper 2 posts on the relay but which 2? Any help appreciated!
Also when I have the key on all my gauges are functioning except for the gas gauge, it is reading way over full and the tank is almost empty. I think I am missing a ground some where?
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #139 of 1067 Old 09-04-2012, 11:59 PM Thread Starter
Why J?
Why J?'s Avatar
Disregard that I figured it out. Didn't have a ground hooked up. Also figured out how to jumper fuel pump relay. And the key has to be on run.
So as of tonight I have all gauges working. Starter wire is kicking, all interior lights work along with all exterior lighting. I'm going to post up what to cut and what to not later. Just need tack (Dakota digital) and getting the speedo working but I just need to splice the Jeep VSS to the speedometer, or so says Novak.
I have been kind of down the last week or so with no noticeable progress and I HATE running fuel lines with a passion. But my trans mount from AA showed up so I can finalize the drivetrain, Jeep electrical is good and fuel lines are run. Just need my wiring harness and ECU from Wayne (pirate4x4) and she should run. Hopefully.
Had one small leak, which is fixed. Just have to get the gas fumes out of the garage before I burn the house down.
Why J? is offline
post #140 of 1067 Old 09-05-2012, 12:15 AM
honda250ex
1987 YJ Wrangler
What kinda clutch are you running? sorry if I missed it already
It's better to live one day as a lion than a hundred years as a lamb.
http://www.jeepforum.com/forum/f12/honda250exs-buildup-860712/
honda250ex is offline
post #141 of 1067 Old 09-05-2012, 12:30 AM Thread Starter
Why J?
Why J?'s Avatar
I'm running an 4L60E auto trans, no clutch for me.
Why J? is offline
post #142 of 1067 Old 09-05-2012, 12:32 AM Thread Starter
Why J?
Why J?'s Avatar
One last wire to cut.
I have Dk green with an orange stripe going from the alt wiring harness to the connector on the right side under the battery. What does this do? Can I just cut it?
Why J? is offline
post #143 of 1067 Old 09-05-2012, 07:21 AM
HARLEYX2
1987 YJ Wrangler
How did you connect your new fuel lines to the old fuel rail fittings?
HARLEYX2 is offline
post #144 of 1067 Old 09-05-2012, 09:44 AM
ldso
Great build. Keep up the good work!
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
post #145 of 1067 Old 09-05-2012, 07:54 PM
BionicOnion
dang man someone hosed you on an stuff big time. my rail fittings were less than 20 each from jegs. -6 braided hose for a 20ft section i think was like 70 bucks and a few other -6 straight fittings at 5 a piece. only problem is if you screw one up..it's like 5 bucks and 10 to ship it lol. glad it worked out for you. im going to transfer my sending unit to the rci this weekend or next and gotta get i think 2 -6 fittings to reseal where i messed one up somehow *leaking from a seal internally?* and one to change the 90 from the rail to a straight fitting.
BionicOnion is offline
post #146 of 1067 Old 09-05-2012, 08:06 PM Thread Starter
Why J?
Why J?'s Avatar
I had no idea what to get with the AN stuff, but it worked out
When I cut the alt wiring out I had a green with orange stripe wire that goes into the large connector under the battery box. It appears to terminate at the ASD relay. Is this something that needs to be hooked up? Or can I just cut the wire out.
I assume that since the ECU is gone the ASD no longer functions. Correct? It will just be a pass throught if power to the Fuel pump relay?
Why J? is offline
post #147 of 1067 Old 09-06-2012, 02:22 PM
HARLEYX2
1987 YJ Wrangler
So how did you connect your fuel lines at the fuel rail?
HARLEYX2 is offline
post #148 of 1067 Old 09-06-2012, 04:16 PM Thread Starter
Why J?
Why J?'s Avatar
For right now I just bubbled flares the lines and used a small piece of fuel injector hose to connect them together. I'm not sure this is what I will run yet or not.
Why J? is offline
post #149 of 1067 Old 09-06-2012, 05:41 PM
HARLEYX2
1987 YJ Wrangler
Did you just use regular hose clamps? I know you dont want to spend alot of fuel lines and I dont want to on mine either but I looked at it like this. If I have a fuel leak because I was to cheap and it catches on fire it could all burn to the ground before I could save it and I would loose alot more than 150.00 in fuel line.
HARLEYX2 is offline
post #150 of 1067 Old 09-06-2012, 06:07 PM Thread Starter
Why J?
Why J?'s Avatar
I completely understand. That is why I bubble flared the line and used fuel injection hose along with fuel injection clamps. It shouldn't leak. It's a better setup than stock.
I still may go with An stuff simPly because if I have an issue with the stock stuff replacement is pricey.
Why J? is offline
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 85 02-25-2016 04:51 PM
Project "Pissed Wife" Why J? Jeep Builds 262 02-17-2014 08:06 AM
5.3L Vortec / 4L60E Engine swap mweber01 YJ Wrangler Technical Forum 9 08-10-2011 03:46 PM
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 11 08-19-2007 11:22 AM
phase 1 fix up project complete-take a look! BruceDJames YJ Wrangler Technical Forum 4 12-28-2005 06:23 PM
