Project Pandora - Page 7 - JeepForum.com
post #91 of 1333 Old 09-01-2009, 07:00 PM
ET48
Originally Posted by Jeep02Apex View Post
Go hard or go home Ethan, methinks the only option for the rear is a 4-link. But I am not sure where to go with the front...time to start researching. I'll be looking at a lot of other builds now for ideas and sending things your way for a final decision.
Yeah, kinda what I was thinking. We can sell the old arms and make some of the money back at least. Alright, I've been looking around also and found some neat concepts, but can't make up my mind.
Here are the creeper joints I found:
Suspension - Creeper joints Rod ends Shackle Mounts
Tommy R's custom long arm build:
http://www.jeepforum.com/forum/f37/l...20/index4.html
Nother build from Pirate:
TJ build #3 (rockwells) - Pirate4x4.Com Bulletin Board
That cage looks great man!! Really adds alot.
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #92 of 1333 Old 09-01-2009, 08:09 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Ok I just read Tommy's build. Freaking awesome. Almost exactly what I pictured when I ran through how a build like this would go if we did it. I would love to get more detailed information about his mounts and his truss.
His front LCA mounts are angled I believe...to what angle? And what specs did he build his truss to? Height, width, uca mount location and angle, etc etc.
I'm going to ask him
I am now going to start reading the pirate build.
Apex is offline
post #93 of 1333 Old 09-01-2009, 08:16 PM
ET48
Pretty neat thread huh? I would probably go with DOM tubing though, it would look way better.
Yah, details would be sweet. He has the same 4.5" lift as us so everything should be very close.
ET48
ET48 is offline
post #94 of 1333 Old 09-01-2009, 08:19 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Ok the pirate one had too much **** in it that I couldn't wrap my brain around lol. It's too involved. But it doesn't look like a front 4-link is much of an option. Too much time and trouble...
Apex is offline
post #95 of 1333 Old 09-01-2009, 08:20 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
DOM tubing for sure, but that shouldn't change anything. I really like his set-up and think it would work very well if we went that direction.
Also doesn't look TOO difficult, I think we could make that happen over winter break on both Jeeps pretty easily. Oh and I can't weld...lol
Apex is offline
post #96 of 1333 Old 09-01-2009, 08:34 PM
ET48
Yeah, that one was a big long build.
I think the front LCAs with the radius arms and track bar would work great. Tri 4 link should also work great in the rear. I wouldn't think it would be too unrealistic to get both jeeps done as long as we had everything ready to go. I'll do all the welding. Maybe I can borrow a MIG from my uncle.
ET48
ET48 is offline
post #97 of 1333 Old 09-01-2009, 08:43 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Radius arm in the front and 4-link rear seems to be the most popular choice among the homebrew LAs.
I think if we follow Tommy's build as close as possible, we can build our control arms to whatever spec we need to keep our pinion angle/caster all the same. Also would you rather go JJ on the lowers at both ends?
If we can get a tally on all the parts, and a price that we'd be looking at I could start saving for this.
Selling our control arms is a plus. (I'm getting new bushings soon from RE as a warranty replacement)
Apex is offline
post #98 of 1333 Old 09-01-2009, 08:59 PM
ET48
I might do something different where the rear LCAs attach to the frame. Something different with the skid. If we went with double JJs, it could give us twice the adjustment range if we made both ends adjustable, although it will raise the cost some.
So if we need JJs for 4 LCA both ends, and 2 UCAs one end each that comes to 6 Johnny or Creeper joints. At $33 a piece, that is $198 for the JJs.
We could get jam nuts and fasteners at the local fastener shop;
Need to get some grinding wheels and some cut off wheels
Got torches
Got lincoln buzbox
Got welding rods
Need some 1/4" sheet steel and DOM tubing.
By the end I could see our project running $500 overall for each jeep. Not too bad for home brew stuff.
ET48
ET48 is offline
post #99 of 1333 Old 09-01-2009, 09:15 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Got torches
Got lincoln buzbox
Got welding rods
I have a few grinding wheels and cut-offs laying around my garage, unused.
My math is adding up different.
front LCAs: 4
front UCAs: 2
rear LCAs: 4
rear UCAs: 4
right? so 12?... holy ****.
Wonder if we can score a sweet deal somewhere on DOM and 1/4" sheet...
Apex is offline
post #100 of 1333 Old 09-01-2009, 09:22 PM
ET48
front LCAs: 4
front UCAs: 2
rear LCAs: 4
rear UCAs: 4
What the heck was I thinking......
No 14 isn't? Maybe we should only use one JJ per arm? Be alot cheaper and it would flex just as good, as Tommy proved for us.
I might be able to get some sheet steel and DOM. We need to plan what material we want and I will check on some pricing.
ET48
ET48 is offline
post #101 of 1333 Old 09-01-2009, 09:32 PM
ET48
Look at this:
Toys by Troy Suspension - 1
The rear center link is interesting. One attachment point on the truss but two on the frame. Not sure if I like it though....
ET48
ET48 is offline
post #102 of 1333 Old 09-01-2009, 09:34 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Yes. One per. Just like our RE arms. They flex good. My god that would have been crazy expensive.
It looks like in Tommy's he uses 10.
One per arm in the front: 4
One per LCA in rear: 2
Two per UCA in rear: 4
So $330 for JJ if that is the case.
I know a guy who works in a welding shop, I'll see if they have any scrap 1/4" we can snag.
I'm re-reading Tommy's build...
Apex is offline
post #103 of 1333 Old 09-01-2009, 09:35 PM
RickHonzaRubicn
i like the herculiner man. did the same to mine i love the fact my floorboard by my trans isnt so hot anymore. jeep looks good man
RickHonzaRubicn is offline
post #104 of 1333 Old 09-01-2009, 09:40 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Look at this:
Weird, not a fan.
Apex is offline
post #105 of 1333 Old 09-01-2009, 09:41 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Thanks for the compliments man. Herculiner is one of my favorite mods.
Apex is offline
indyorv
CJ5 Project redcj576 Jeep CJ Forum 148 05-25-2013 11:34 PM
'94 XJ Project DDR Jeep Builds 32 08-30-2011 09:50 PM
The TJ Project GriffTatum Jeep Builds 17 08-11-2011 01:44 PM
my project YJ confusedYJTJ Jeep Builds 6 10-26-2010 08:04 PM
my 97 project andrew383 Jeep Builds 7 09-19-2010 01:08 PM
