Project Pandora - Page 12 - JeepForum.com
post #166 of 1333 Old 02-11-2010, 11:14 AM
2006_Sport
Corners look sweet.
2006_Sport is offline
post #167 of 1333 Old 02-11-2010, 11:17 AM Thread Starter
Apex
Recon death squad
Apex's Avatar
Corners look sweet.
Lol I laughed..then the more I stared at it, the creepier it got.
Apex is offline
post #168 of 1333 Old 02-11-2010, 11:20 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
looks like you've all had problems with the tail gate hinges. just drill the head off of the bolt and remove the hinge and twist it out with vice grips?
what size bit is best for that? looks like something im going to have to compete with when i get my Savvy's
My builds:
and
or follow us on
spyder6 is offline
post #169 of 1333 Old 02-11-2010, 11:32 AM Thread Starter
Apex
Recon death squad
Apex's Avatar
Yea, they suck. The first two came out nicely, the next six required a 5/16 drill bit to drill out. You'll know when you've gotten through the head, they sort of make a crack/pop noise when it seperates and then the head stays on the drill bit.
With a good sharp bit and some used motor oil, it's a breeze. Use a cheap bit and you'll be at it all day. (ask me how I know)
Apex is offline
post #170 of 1333 Old 02-11-2010, 11:56 AM
SuperWade2
More Money than Brains
SuperWade2's Avatar
The 17/32 bit is only for the spots that need nutserts, I used the 5/16 on all of the other mounting spots... Same 5/16 bit that I used to remove the heads from the stripped torx bit.
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #171 of 1333 Old 02-11-2010, 11:59 AM
Bennettj13
I feel bad for you guys. I had no problems at all with mine.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #172 of 1333 Old 02-11-2010, 12:52 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Yea, I've been going to town with that 5/16 bit...and I used a 1/2 to enlarge the other ones while I wait for my girlfriend to get home so I can go get a 17/32. So I'm close, but not quite there lol
one more question, the bottom tailgate hinge had a bracket on the backside...Am I supposed to re-use that or am I going to get some flange nuts when Gerald send the longer bolts?
Gotta love corrosion. The studs twisted out by hand, which is kinda funny.
And just so everyone knows, I almost ordered replacement bolts from the dealership until I read that I'm supposed to get some included with the corners...they are $3.25 a peice from the dealership.
Apex is offline
post #173 of 1333 Old 02-11-2010, 01:13 PM
SuperWade2
SuperWade2's Avatar
If you are talking about the 2 brackets with the threaded holes that fit flush inside the tub behind the tub side of the hinges, yes you reuse those. I don't think there were enough Flange nuts included to replace
The top one you should be able to reach from inside the rig along the back corner (I had to move the carpet)
2017 WK2 Overland
post #174 of 1333 Old 02-11-2010, 01:25 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Yea the top one is securely attatched using rhinoliner. The bottom one fell out, and I cannot get the studs out of it. I may just pick up a few extra flange nuts from Home Depot or something. I think that's all the questions I had, I think it is funny that you make the jokes about how it'll take you three weeks and 6 sets of instructions to finish a project...That's how I feel right now
Apex is offline
post #175 of 1333 Old 02-11-2010, 01:50 PM
SuperWade2
SuperWade2's Avatar
I had to put the bracket in my vice and use vice grips on the stud and was able to get the bolt out... but I also didn't have much rust or anything to deal with. Was just a stripped torx (although I did shatter two T40 socket bit things).
2017 WK2 Overland
post #176 of 1333 Old 02-11-2010, 01:53 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
I had to put the bracket in my vice and use vice grips on the stud and was able to get the bolt out... but I also didn't have much rust or anything to deal with. Was just a stripped torx (although I did shatter to T40 socket bit things).
My T40 held up pretty nicely...But the salty winters here in Ohio did a number on that bracket. Doesn't help that I run without the inner wheel well.
Apex is offline
post #177 of 1333 Old 02-11-2010, 07:10 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Wade, if you pop your head in here again please tell me where you got a 17/32 drill bit at. Home Depot and Sears don't have it...
Apex is offline
post #178 of 1333 Old 02-11-2010, 07:15 PM
corndogduff
I got a full set of precision bits from Fastenal, down to 64th sizes, you might wanna check there...
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
corndogduff is offline
post #179 of 1333 Old 02-11-2010, 07:28 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Hmm, Fastenal...I was going to call Grainger tomorrow and check there. I'll add Fastenal to the list.
Apex is offline
post #180 of 1333 Old 02-11-2010, 08:22 PM
SuperWade2
SuperWade2's Avatar
Mom and Pop Ace Hardware here in town...which doesn't help you much
2017 WK2 Overland
indyorv
CJ5 Project redcj576 Jeep CJ Forum 148 05-26-2013 12:34 AM
'94 XJ Project DDR Jeep Builds 32 08-30-2011 10:50 PM
The TJ Project GriffTatum Jeep Builds 17 08-11-2011 02:44 PM
my project YJ confusedYJTJ Jeep Builds 6 10-26-2010 09:04 PM
my 97 project andrew383 Jeep Builds 7 09-19-2010 02:08 PM
