Project: Mooseicon! - Page 83 - JeepForum.com
post #1231 of 1338 Old 07-05-2013, 01:31 PM
AngryTJ
Originally Posted by Moose340
Hmmmm I see. So ask the manufacture if they have head of that problem then.
So I could go with a one inch then coolio
Which one are you considering?
AngryTJ is offline
post #1232 of 1338 Old 07-05-2013, 01:48 PM
Jankoid
Or you could just tell us which one you are considering and we can tell you.
Jankoid is offline
post #1233 of 1338 Old 07-05-2013, 03:20 PM Thread Starter
Moose340
Rokmen, I've always liked there stuff
Non timebo mala
Check out my build
Moose340 is offline
post #1234 of 1338 Old 07-05-2013, 03:34 PM
Jankoid
Yes, you will need a body lift with that skid. You might could use a UCF LOPRO mount and get away without the body lift.
Jankoid is offline
post #1235 of 1338 Old 07-05-2013, 04:05 PM Thread Starter
Moose340
Eh I'm pretty sure I want to go with a body lift any way
Non timebo mala
Check out my build
Moose340 is offline
post #1236 of 1338 Old 07-05-2013, 04:16 PM
AngryTJ
It'll help if you ever get a gas tank skid as well.
AngryTJ is offline
post #1237 of 1338 Old 07-05-2013, 04:36 PM Thread Starter
Moose340
That's what I thought! Plus I can go up to 33's
Non timebo mala
Check out my build
Moose340 is offline
post #1238 of 1338 Old 07-06-2013, 02:06 PM
G Beasley
So trying to think of mods I can do under or around a hundred bucks. Any suggestions?
Other question. I was looking at body lifts, I heard some where that a Rubi needs a 1.25" bl cause of the 241 t-case when you go to TT will have problems fitting. Any truth to this?
I have the 1.25" body lift with Savvy UA and I had to do the socket trick as described below.
Originally Posted by janesy86 View Post
Def a tight fit for me with the Savvy UA. I had to still dent the tub a little above the Tcase. I just put a big a$$ socket over it and jacked it up to put a dent where it was needed.
I think I used the 32 mm , but your description also works .
G Beasley is offline
post #1239 of 1338 Old 07-06-2013, 02:48 PM Thread Starter
Moose340
J.U.M. Just use hammer! Lol thanks I'm not to worried about denting the tub a bit. I just didn't want to go to pound town on it
Non timebo mala
Check out my build
Moose340 is offline
post #1240 of 1338 Old 07-07-2013, 06:43 PM Thread Starter
Moose340
Well I took some pictures of the jeep and my lake style cause I forgot shoes!
Non timebo mala
Check out my build
Moose340 is offline
post #1241 of 1338 Old 07-08-2013, 02:45 PM Thread Starter
Moose340
Looks like I will be getting a rokmen 1" body lift and rokmen half inch leveling spacers to help get rid of the rake.
Also pretty sure I've decided to run 285/75 tires just not sure if the make
Non timebo mala
Check out my build
Moose340 is offline
post #1242 of 1338 Old 07-08-2013, 07:06 PM
Luke95
16s?
I <3 rockrash
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #1243 of 1338 Old 07-08-2013, 08:47 PM Thread Starter
Moose340
Correct sir!
Non timebo mala
Check out my build
Moose340 is offline
post #1244 of 1338 Old 07-09-2013, 10:08 AM
Luke95
Correct sir!
Treadright old style mtrs and wheel the **** out of em.
I <3 rockrash
Luke95 is offline
post #1245 of 1338 Old 07-09-2013, 01:15 PM Thread Starter
Moose340
I <3 rockrash
That's what I was thinking!
Non timebo mala
Check out my build
Moose340 is offline
