Project: Mooseicon! - Page 6 - JeepForum.com
post #76 of 1338 Old 01-15-2013, 04:44 PM
KateKGB
Originally Posted by tyvanwie View Post
Hm. Are you sure it was because of that? Or did you do anything else to it at the same time? I'm also planning on ar
Absolutely positive. The extra weight makes a big difference in the way it handles. For the positive IMO.
'05 Unlimited Rubicon - Sahara Edition #431
We are the diamonds that choose to stay coal
A generation born, to witness the end of the world
KateKGB is offline
post #77 of 1338 Old 01-15-2013, 05:05 PM
tyvanwie
Okay cool
tyvanwie is offline
post #78 of 1338 Old 01-15-2013, 05:09 PM Thread Starter
Moose340
Add weight would hold different down more which in turn would make it slightly different. I understand. It just confuses me, on a solid axle one side goes up the other side has to go down. Well the way it seems that this wont let it work like that. There bar has spines and the females on the arms to hold each other. So the bar twisted then? That seem like it would break eventually or the splines would round off.
Non timebo mala
Check out my build
Moose340 is offline
post #79 of 1338 Old 01-15-2013, 05:18 PM
KateKGB
Its in 3 parts, visialise it twisting letting your wheels travel more versus a solid sway bar that holds them more together. You always see the front where those splines are. That doesnt move. however on the bacj but there is a flex joint (not the technical term).
KateKGB is offline
post #80 of 1338 Old 01-15-2013, 05:23 PM Thread Starter
Moose340
Sounds pretty interesting, I will do some more research
Non timebo mala
Check out my build
Moose340 is offline
post #81 of 1338 Old 01-15-2013, 05:51 PM
KateKGB
Actually its 5. A solid piece that goes into the frame, not over it like your stock swaybar. Allowing for a winch to fit lower and tighter to the body, making it more stable and efficient. That has those splines that attach solidly to the flat piece with the decal. that attaches to another bar that goes to the suspension. The movement occurs mostly at that joint.
KateKGB is offline
post #82 of 1338 Old 01-16-2013, 07:25 AM
KateKGB
Kind of a crappy picture between the dirty jeep and snowfall, but heres how it attaches to the suspension.
KateKGB is offline
post #83 of 1338 Old 01-16-2013, 07:42 AM
Jankoid
Antirocks are awesome offroad. Whenever I know I won't be wheeling for a while I switch mine over to the tightest setting, which is almost as good as stock. For the trail I use the loosest setting. Lower control arms would also be a good buy.
Jankoid is offline
post #84 of 1338 Old 01-16-2013, 07:46 AM
KateKGB
I saved up to do all 8 of my CAs with my AR and lift. I had a bit of a DW and figured the CAs were the culprit. They were, bushings were shot.
God, so many acronyms!
KateKGB is offline
post #85 of 1338 Old 01-16-2013, 07:58 AM Thread Starter
Moose340
So many choices! Hahahaha
Non timebo mala
Check out my build
Moose340 is offline
post #86 of 1338 Old 01-18-2013, 12:32 AM Thread Starter
Moose340
Well I bought a few things for now. I got some kicker 5.25 and dash adapters, have some left over poly-fill so now I can finish my sound upgrades. Also got my OME steering stabilizer and my hydro graphing kit. Im going to go the covers for my speakers in the sound pod and the center section around the dash for starters. Just a start for now since I am at school I would be having a lot of time to do things
Non timebo mala
Check out my build
Moose340 is offline
post #87 of 1338 Old 01-18-2013, 12:55 AM
Jeeper4life88
2016 JK Wrangler
Jeep looks good moose! Do you still have those stock springs?
2016 Jeep Wrangler Unlimited
2004 Jeep Liberty
1981 Jeep CJ5
1977 Jeep CJ5
Jeeper4life88 is offline
post #88 of 1338 Old 01-18-2013, 01:02 AM Thread Starter
Moose340
Yes sir! Is this YJMan?
Non timebo mala
Check out my build
Moose340 is offline
post #89 of 1338 Old 01-18-2013, 04:02 PM Thread Starter
Moose340
New stickers are on.
I'm a sticker whore...... Oh and Ted is helping me!
Non timebo mala
Check out my build
Moose340 is offline
post #90 of 1338 Old 01-18-2013, 04:23 PM
bobthetj03
That first one is awesome! LOL!
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
