Project Jermey - JeepForum.com
 1Likes
post #1 of 99 Old 11-19-2013, 08:58 AM Thread Starter
Gage56
Project Jermey
Well i thought i should keep track of my buddies build
1990 6cyl 5speed
Bought for 2800.00
Not Real sure what direction he is going with this but here is what we got so far
Day i went to look at it for him
Then we picked up a new tub for 70.00
And now i am left with this to rebuild
Reason for new tub
Could it be fixed.... Sure but for 70.00 for the replacement tub why not
BUT Here is what needs fixed on the new tub
Otherwise the tub is SOLID and this will be less work in the long run to fix and make Purdy
So that is all i have for right now, the new side panels and floor boards should be here today and i get to start digging in
1992 YJ
Gage56 is offline
post #2 of 99 Old 11-20-2013, 07:01 PM Thread Starter
Gage56
Got some of the orange tub pulled apart
1992 YJ
Gage56 is offline
post #3 of 99 Old 11-20-2013, 08:21 PM
lovett86
that should be a nice build, finding a clean tub up here is a needle in a hay stack
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #4 of 99 Old 11-21-2013, 06:56 AM
HaskiE
HaskiE's Avatar
ha! I'm in early for this one!
I love the bait ans switch method of building. that's the path I'm headed with my build if it ever gets rolling. and you end up with enough parts for a 2nd jeep at the end! haha. Goodluck!
now, I'm in for the sub!
#theneverendingaxe
HaskiE is offline
post #5 of 99 Old 12-02-2013, 06:11 PM Thread Starter
Gage56
Well got a few more things done
And did this while i was working on it today
1992 YJ
Gage56 is offline
post #6 of 99 Old 08-17-2015, 07:53 AM
rustisexpected
So i guess its time for an update. Just to be clear my name is Jeremy and my jeeps name is Rusty.
I am going to use this post as an area to keep track of Rusty's current stats... This section is under construction.
Engine- 4.2L Nuttered
GM HEI distributor
GM CS144 Alternator
Motorcraft 2150 Carburetor
Big 4 wiring upgrade
Drivetrain- AX-15
NP231J W/ Teraflex SS SYE
Tom Woods rear ds
HDP front ds
HP D30 4:10 W/ Powertrax Lock Right Lunchbox & Cable Lock CAD
Ford 8.8 4:10 LSD (Ford racing clutch pack) Disc brakes
Wheels and tires- Pro Comp Xtreme A/T's 35/12.5-15
Trailmaster TM9 15x8 3.75 BS
Interior- Monstaliner
Sahara interior swap
Headliner
CB
BT headunit
LED courtesy and dome lighting
LED Dash lighting
Custom center console with 10" sub
D & P flip forward seat bases
Family roll bar swap
LED dash lights
Grab handles
Exterior- British racing car green paint
Black hood hardware kit
Stainless hardware
Cowl vent scoop
DIY Front bumper with built in hause fairlead mount, storage, and 2" receiver
DIY Rear bumper with 2" receiver
DIY F tube fenders
DIY R flares
Baricade full corner armor
Currie rocker armor
CJ tailgate conversion
Trucklite flush mount taillights
LED reverse and license plate lights
XJ roof rack
Smittybilt H2O 10k winch
rustisexpected is offline
post #7 of 99 Old 08-17-2015, 07:59 AM
rustisexpected
I gave up on useing the original frame after several attempts to repair. I sourced a new one locally. The only rough spot on the frame was the typical shock mount area. It was not rusted through but it was getting thin. I removed the shock mount and covered it with 3/16' plate. I know its a bit overkill but it was what i had in the shop. Not too bad for a guy who has never welded a day in his life...
post #8 of 99 Old 08-17-2015, 08:07 AM
rustisexpected
I sourced a 4:10 LSD 8.8, went through the axle, cleaned it up, and installed it. I took an experimental route with the 8.8 install, by just adding plate to the existing spring perches and drilling new center pin holes in the plate. At the same time i sourced a 4cyl dana 30 for the front. I also cleaned and coated the rolling chassis.
post #9 of 99 Old 08-17-2015, 08:10 AM
rustisexpected
I also gave up on my $70 replacement tub when this beauty showed up on Craigslist for $100.
post #10 of 99 Old 08-17-2015, 08:16 AM
rustisexpected
After stripping it down i found a small drivers side floor pan issue and replaced it, along with a bit of fender well trimming (to clear the 35's), and trucklite recessed tail lights. The drivers side rear corner had also taken a few hits. I worked the dents out with my body hammers.
post #11 of 99 Old 08-17-2015, 08:27 AM
rustisexpected
Once the tub was in a condition to paint, the windshield was next. The P.O. had drilled over 40 holes in the windshield frame, so i got to try out the new welder. The flux core worked fine for this , I picked up a bottle down the road in the build.
post #12 of 99 Old 08-17-2015, 08:34 AM
rustisexpected
With everything sanded down it was time for paint work. Being that i do not have a paint booth, or the room to dedicate to one, I improvised with a weighted poly plastic hanging from the ceiling with box fans and a furnace filter. I think it came out pretty well considering. There is zero bondo in my build, I like the mechanical look of a raw tub. After the paint cured I rolled on my monstaliner. I coated every inch on the inside of the tub, including the underside of the cowl.
post #13 of 99 Old 08-17-2015, 08:41 AM
rustisexpected
Next I purchased a set of factory Jeep Canyon wheels ($100) , and some used 35x12.5 Pro Comp Xtreme A/T's ($500). To go with the new RC X-series 4.5" lift ($450). Also some Smittybuilt knock off tube fenders ($200).
post #14 of 99 Old 08-17-2015, 08:51 AM
rustisexpected
to be added later
post #15 of 99 Old 08-17-2015, 08:58 AM
rustisexpected
At the same time i worked on giving Rusty his namesake. Accomplished with a mixture of hydrogen peroxide, white vinegar, and salt, in a spray bottle. Time lapse is about a minute.
