Project Indecision: A Jeep addict's 06 Unlimited LJ - Page 24 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Project Indecision: A Jeep addict's 06 Unlimited LJ
Unread 06-24-2014, 02:04 PM   #346
Bigbear92
Yeah elbe is where we go just up the highway from me and this weekend we are taking a camping trip to the naches they have a fun run going on so we will do some exploring over there
Bigbear92 is offline   Reply With Quote Quick reply to this message
Unread 06-25-2014, 08:33 AM   #347
clintrivera
Nice looking YJ. Who's putting on the fun run?
Build
clintrivera is offline   Reply With Quote Quick reply to this message
Unread 06-29-2014, 08:33 PM   #348
Bigbear92
Thanks, found out it was naxja putting on the event so i was the only wrangler running the trails but it was a real fun weekend put in a solid 10hrs of trails
Unread 07-06-2014, 07:07 PM   #349
clintrivera
Sounds like a blast!
Well, the other day I went to leave work and the Jeep wouldn't crank. Everything turned on, but no crank. I could spin the starter by shorting the solenoid, so that was ok.
After dragging it home on the trailer (and finding the winch on my trailer took a dump) A found out this happened.
Pretty delicate little piece for something that has to start the car. If you don't know what this is, it's the thing that turns the ignition switch.
Figured that out and decided to whip a skid plate together.
It took the better part of a day, but I think it will be plenty strong. I like that I can drop the skid without having to support the transmission too.
Also made a steering box skid while I was at it.
After all that work I decided I would go play in the woods. This is the only shot I got before the O ring on my power steering pump line blew again.
I felt the power steering cooler when I found out it blew again and it was so hot I could barely touch it. I don't think it had anything to do where I mounted it, since I wasn't even traveling at walking speed with the engine just above idle. The O ring wasn't torn, it look like it disintegrated - like it got too hot and fell apart.
So, I'm going to plumb and additional cooler in front of my radiator so it gets moving air from both the fan and vehicle speed. That should defiantly help out.
Build
Unread 07-10-2014, 08:10 PM   #350
G Beasley
Bummer that the O ring issue keeps popping up , but man your rig looks good in the woods . The fab work on the skid also looks amazing .
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 07-10-2014, 11:46 PM   #351
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Yeah dude.... for "whipping" up a skid, that thing looks damn nice. I want to see some better/more pics of this thing though!
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 07-11-2014, 09:43 AM   #352
clintrivera
I assumed there would be a few bugs to work out with this extensive of a build. I'm glad it's some pretty minor issues. Thanks for the compliment on the skid.
Thanks, it only cost $65 in steel plus the better part of a day. I need to save money where I can since I'm saving for Moab. I'm between cameras right now but when I get my new camera I'll take some better shots for sure.
My P/S cooler came yesterday so I decided to tackle that job. I'm not sure who designed the rubber "nuts" that hold the condenser to the grill, but I have some words for him. What a Mickey Mouse setup that is.
Welded up some tabs to the brace and bolted it down.
It's hard to see, but it is hiding behind all that chrome.
I also changed the O-ring to a Viton one I found at O'rileys. It was a Doorman part for fuel line. Viton is good for higher heat, and it's a stiffer seal so I think it will be better. The O ring that keeps blowing does see 4.5 GPM at 1600 PSI so it does need to handle some stress.
Got to work and the cooler was barely warm. Going on a poker run this Saturday, so I'll see how it does.
Build
Unread 07-11-2014, 10:42 AM   #353
Imped
Imped's Avatar
Viton is a good material choice for that oring. I'm interested to see if the durability changes. I'm assuming you were running Buna before?
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 07-11-2014, 02:48 PM   #354
clintrivera
I'm not sure what the one that came with the box is made out of. From what I read, the Viton is rated to 100 degrees more than the Buna O ring. I hope it will hold up, but it's not very scientific since I added much more cooling to the system.
Build
Unread 07-12-2014, 09:01 AM   #355
clintrivera
Put the forklift at work to work. It's hard to fully articulate an axle in a small garage with the tires on, plus when the weight of the vehicle is deflecting the joints, funny things can happen. It appears as though I either need more bump stop in the front, or rethink my fenders (high line).
Build
Unread 07-14-2014, 09:43 AM   #356
clintrivera
Took the Jeep out on a poker run this weekend. 0 problems this time and the O ring seemed to hold together. Even after lots of steering work in the tight trails the coolers weren't too hot to touch so the increased capacity must be doing some good.
Here's some pictures.
Build
Unread 07-14-2014, 09:46 AM   #357
clintrivera
It's been pretty hot here so the girlfriend and I decided to head to the river and cool off.
On the way back we passed a sign for a dam that I've passed 100's of times and decided to check it out.
Nothing too spectacular, but the whole intention of building this Jeep is to explore and see new things.
Build
Unread 07-14-2014, 10:22 AM   #358
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Are you running two steering coolers??
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 07-14-2014, 12:33 PM   #359
clintrivera
Yes. Although I may take the lower one off after Moab depending how hot the cooler gets to keep it more simple.
Build
Unread 09-18-2014, 11:45 AM   #360
clintrivera
For sale!
http://www.ebay.com/itm/221552117576...84.m1555.l2649
Build
