Project: Ground up - Page 5 - JeepForum.com
post #61 of 107 Old 03-06-2012, 01:35 AM
TJRHD
NOT A HATER
TJRHD is offline
post #62 of 107 Old 03-06-2012, 08:31 AM
hallsofstone
Awesome work!
Jeeping Ohio Every Day
00 TJ Sport - Ever evolving DD/Rig
85 Suzuki GS700 - ugly
K.C.C.O.
hallsofstone is offline
post #63 of 107 Old 03-06-2012, 09:19 AM
Sgt.Fuzz
Surgical.
My build:
Sgt.Fuzz is offline
post #64 of 107 Old 03-06-2012, 09:28 AM
Imped
Imped's Avatar
Give credit where it's due man.....
Marking it was tough. You had the easy job.
OlllllllO
IndyORV
Imped is online now
post #65 of 107 Old 03-06-2012, 02:13 PM Thread Starter
RockRodHooligan
RockRodHooligan's Avatar
Thanks for your help yesterday buddy, you didn't have to come up on your Office Space Day, it was good to get to do a little Jeep building with you again!
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #66 of 107 Old 03-06-2012, 02:38 PM
Imped
Imped's Avatar
No problem bud.......sarcasm. You had the tough job.
OlllllllO
IndyORV
Imped is online now
post #67 of 107 Old 03-06-2012, 04:13 PM Thread Starter
RockRodHooligan
Yeah I know, just giving thanks where thanks is due. It's not often I get to work on the Jeep, even less that I get help when I do.
96 XJ:
***** inches...
post #68 of 107 Old 03-06-2012, 08:42 PM
kyle_craig
I'm honored to grace the presence of your signature. Looking forward to seeing more progress!
kyle_craig is offline
post #69 of 107 Old 03-06-2012, 11:32 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
2 months goes by and this is all the updates i can whore out of you? i feel like i just watched the tail end of a really good tele novella and there was no previews for next week.
My builds:
and
or follow us on
spyder6 is offline
post #70 of 107 Old 03-07-2012, 12:54 PM Thread Starter
RockRodHooligan
Lol yeah I ran into some issues with getting the time to work on the truck, between working at 4WP full time, school full time, and working at O'Reillys on my days off there was no time.
96 XJ:
***** inches...
post #71 of 107 Old 03-07-2012, 09:35 PM Thread Starter
RockRodHooligan
Flipped it over and sectioned the front, and welded both ends across the bottom. I had to cut the flange off of the backside of the forward most crossmember to make the cut where I wanted to, I'm not thrilled about that, but I'm going to go back with a 1x1 angle and plug weld the hell out of it to the back side of the forward crossmember and the front flange of the second.
I also ended up cutting a crossmember out when I sectioned the rear, I will go back and cut part of that floor section up with the crossmember as part of it, and weld it overlapping the rear seam, allowing me to double up the sheet metal there, as well as adding a crossmember under it for added strength. You can see I have done a similar thing to the bed sides also.
Wa La! The 5' box!
I will cut this raised section out and patch in a piece to make that I sectioned it less noticeable
96 XJ:
***** inches...
post #72 of 107 Old 03-08-2012, 06:13 PM Thread Starter
RockRodHooligan
Block is at the machinist this week, should have it back Thurs in time for class. I also ordered the new cam and lifters, decided to go with the Comp Cams 68-239-4 (Duration 262/270, Lift .493/.512). It might be a little on the radical side, but with the port work I've done, larger valves, and lighter rotating assembly(pistons,valves) we'll see how I like it, I know I love the way it sounds:
If nothing else a new milder cam is an easy enough swap.
As for the bed, I'm thinking about some 1x1" 1/8" angle to weld to the back side of the lip that the bedsides attach to across the bedrail. Then capping the bedrail with a piece of 3/16" plate. The 1/8" piece will give me something solid to weld to since I completely drilled out the original spot welds, as well as add a little more rigidity to the bed side, the 3/16" plate will add a lot more rigidity to it, as well as armor up the bed rail for when I end up rubbing up against a tree or rock.
96 XJ:
***** inches...
post #73 of 107 Old 03-14-2012, 07:21 PM Thread Starter
RockRodHooligan
Snapped a couple of pics yesterday when I had to run up to my Dads to pick up some stuff, just a couple of pics for comparison of a kind of before/after:
And a little bit of a mock up(as much as I could do without someone to hold the flare) of things to come.
I have the 25-27th off work, so I'm going to head back up for another run at it. I hope to get the patch work and overlapping patches welded up, as well as a couple more passes of tack welds done on the inside of the bed, and ground down. Then cut the bed sides down and tack them back together for test fit. I'm going to wait to weld them back on the bed, till I can take the section I cut out to my buddy and have him use it as a templet to bend up the bedside re-enforcements.
96 XJ:
***** inches...
post #74 of 107 Old 03-26-2012, 01:50 PM Thread Starter
RockRodHooligan
Spending the next couple days working on the truck again, making progress on the back seam but it's not going together the way I want it to. I am really trying to avoid using on the bed floor unless I absolutely have to, but using weld is proving difficult with the thin sheet metal. I'm looking into something OLD school, they used to use Lead as a body filler, now days they use a type of solder for obvious reasons. Only thing is the Solder kits start out at about $110 and go up from there, more than I want to spend considering I can get a gallon of the good Bondo for about 1/2 that. :/
96 XJ:
***** inches...
post #75 of 107 Old 03-26-2012, 01:54 PM Thread Starter
RockRodHooligan
Lmao, after Danno's response I felt it necessary to add it!
96 XJ:
***** inches...
4.7l stroker , 9" rear , back half , bobbed , comanche , custom , hanneman blister flares , hp44 , indyorv , manche , np231 hd hybrid case , propane injection , zone offroad mj
my 3year project became a 6month project gattaca37 Jeep Builds 7 03-21-2011 03:49 PM
Ground Hawgs on a CJ/YJ/TJ silentknight Jeep Picture Requests 7 09-09-2010 04:46 PM
Ground Pounder Fab arnold303 Jeep Builds 3 08-14-2010 02:11 PM
1964 CJ Ground Up Resto jkoz79 Jeep Builds 23 03-03-2010 07:48 AM
Ground Hawgs Kasia Jeep Picture Requests 0 11-19-2007 08:36 PM
