Project: Ground up - Page 2 - JeepForum.com
post #16 of 107 Old 07-27-2011, 10:38 PM
mallard15
That sounds like an awesome plan. I love that mj. The green just pops and yea I wouldn't like having fiberglass panels either.
Bestop Extendatrunk for sale (150$) PM me
Yukon 4.10 R&P Gears Set (300$) PM me
mallard15 is offline
post #17 of 107 Old 08-07-2011, 08:52 PM Thread Starter
RockRodHooligan
RockRodHooligan's Avatar
This is what I have planed for the bed of the truck. The idea actually came from the Ultimate F150 that Petersen's built for the 2011 Ultimate Adventure.
Take one long bed:
Drill out all the pinch welds and remove the bedsides. This will allow me to make my welds thoroughly in and outside of the bed when it's going back together, as well as take care of the little bit of rust thats in there.
The section to come out of the front
Section out of the rear
For the bedsides I'm only going to make one cut, about a 28" section out of the middle(thats an estimate, not going to cut the bedsides until after the bed had been cut down, and remeasure). I'll cut the section out, then tac weld the two back together, cut my new wheel well opening, then finish the weld.
This is all that will be visible of the factory bed sides once I get the flairs on
I think the whole corner is going to come together nicely
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is online now
post #18 of 107 Old 08-07-2011, 10:29 PM Thread Starter
RockRodHooligan
Also, I have made a few changes to the engine "recipe". Rather than going through all the hassle of converting the Jeep over to OBD1 or OBD2, I've decided to simplify things and build it to run on propane. My choice to run E85 was based on the idea that I would be building a TJ, with an existing OBD2 system to plug into, since I have nether OBD1 or 2 to start off with now, Propane makes sense.
I'll be switching to a carbureted style intake manifold, designed for the 4.0L head, from Clifford Performance, carburated type distributor, and tentatively, the conversion kit from gotpropane.com. I still need to call them and ask a few questions, both about the kit, and a few general questions about propane in general(octane rating, approx range per forklift sized tank, ect). No need for a new engine wiring harness, gage cluster(or dash if OBD2), injectors, ECU tune, fuel pump, fuel cell, etc.
96 XJ:
***** inches...
post #19 of 107 Old 08-07-2011, 11:47 PM
Bennettj13
I still think you should leave the MJ be, but I'm there to wrench whenever you finally start.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #20 of 107 Old 08-21-2011, 11:14 PM Thread Starter
RockRodHooligan
Well the High Performance Engines class I signed up for in spring has been canceled for the semester, as well as another class I was supposed to take, and I just found out about a half an hour ago. Too late for me to sign up for any classes to fill the gaps in my schedule, and for me to e considered a full time student, effectively cutting my "income" from my GI Bill in half. would have been nice to have been notified about that, rather than finding out wen I checked my schedule to see what class I have tomorrow night(I don't have class now, by the way).
No engine build untill ateast January now. Guess that gives me some more time to collect parts.
96 XJ:
***** inches...
post #21 of 107 Old 08-22-2011, 01:45 AM
Sgt.Fuzz
My build:
Sgt.Fuzz is offline
post #22 of 107 Old 08-25-2011, 07:06 PM
JJeeper09
Can't wait for this man
JJeeper09 is offline
post #23 of 107 Old 08-25-2011, 08:09 PM
curt7088
I have a couple questions for ya if you don't mind... why a three link up front instead of a triangulated 4? ease of fabrication?
if your going through all the trouble you are obvisiouly doing so, why not a coilover setup, or maybe remote resi's? (front) and this looks like it's going to be quite the epic build, I will lay awake at night thinking of this build when i'm all alone inside my barracks room!
thread
Originally Posted by george29223
lol iam stealth like a 900 pound cat ha ha
curt7088 is offline
post #24 of 107 Old 08-25-2011, 08:12 PM
Imped
Imped's Avatar
I should've never shown you that green MJ. I've opened up a can of worms.
OlllllllO
IndyORV
Imped is offline
post #25 of 107 Old 08-25-2011, 08:20 PM Thread Starter
RockRodHooligan
I've looked into a triangulated front when I had my XJ, and after talking with the guys on Pirate, it's just not worth the extra fab work needed to place everything in the right place, on top of having to go full hydro. I've got enough expenses in this as it is, I'm not trying to add hydro assist to that list, that can easily be added at a later time, same goes for coil-overs in the front, the cage work needed to support everything is more than I want to tackle right now.
It is all your fault.
96 XJ:
***** inches...
post #26 of 107 Old 08-25-2011, 08:23 PM
curt7088
Originally Posted by RockRodHooligan View Post
I've looked into a triangulated front when I had my XJ, and after talking with the guys on Pirate, it's just not worth the extra fab work needed to place everything in the right place, on top of having to go full hydro. I've got enough expenses in this as it is, I'm not trying to add full hydro to that list, same goes for coil-oversJust not in the budget with my income right now.
thanks man i was just wondering about it is all...
p.s. i didn't even think about the full hydro that would come with... haha...
thread
curt7088 is offline
post #27 of 107 Old 08-25-2011, 08:25 PM
Xerxes
this might help visualize the color.
Originally Posted by melk:
"Either more or less lube may change the moaning!"
|::Sahara Owner::|
Xerxes is offline
post #28 of 107 Old 08-25-2011, 08:37 PM Thread Starter
RockRodHooligan
It's cool. The amount of work it takes to put coil-overs in the XJ/MJs is pretty extensive, one unfortunate side effect of a unibody. Granted the "cab" section has a lot of bracing that the XJs don't, the front end still needs to be stiffened up a bit. Coil-overs are still an option, but it would be later down the line, after I get the bugs worked out of the current build phase.
I'm still thinking about the Grabber blue, but since I've decided to build the MJ, I'm toying around with Molten Orange also, even though I would like to keep it a solid color, so I can spray it as a single stage paint for both cost and ease of touch up.
96 XJ:
***** inches...
post #29 of 107 Old 08-25-2011, 08:42 PM
Xerxes
cant see the pic? I see it but here's the link http://www.facebook.com/photo.php?fbid=2169391430967&set=a.2169385390816.124152.1132162258
|::Sahara Owner::|
Xerxes is offline
post #30 of 107 Old 08-25-2011, 08:53 PM
curt7088
eye steel kant c it... darn DOD internet web filter!!!
thread
curt7088 is offline
4.7l stroker , 9" rear , back half , bobbed , comanche , custom , hanneman blister flares , hp44 , indyorv , manche , np231 hd hybrid case , propane injection , zone offroad mj
my 3year project became a 6month project gattaca37 Jeep Builds 7 03-21-2011 02:49 PM
Ground Hawgs on a CJ/YJ/TJ silentknight Jeep Picture Requests 7 09-09-2010 03:46 PM
Ground Pounder Fab arnold303 Jeep Builds 3 08-14-2010 01:11 PM
1964 CJ Ground Up Resto jkoz79 Jeep Builds 23 03-03-2010 06:48 AM
Ground Hawgs Kasia Jeep Picture Requests 0 11-19-2007 07:36 PM
