Project DD, '95YJ - Page 2 - JeepForum.com
post #16 of 89 Old 03-21-2012, 08:40 AM
firefighter315
The engine problem is right in front of your eyes....the little scissor jack is missing! Get that replaced and fire it up!
Have you figured out what is coating the side of the fan shroud? If it's fluids from a blown head gasket, I think I'd expect to see it on the top of the shroud too.
My YJ Build Thread
firefighter315 is offline
post #17 of 89 Old 03-21-2012, 01:35 PM Thread Starter
Firemandan
1979 CJ7
FF315, The oil dip stick is missing the top disk that seals it to the tube, from what I can see is's oil thats blown out of the tube. I am about to see what I need to pull the engine and I might get started on that either today or friday, i'm on shift Thursday.
As far as the jack goes, That was the first thing I tried when I got her home, dang thing still didn't crank. Thinking about putting new air in the tires and see if that will work, or a IAFF sticker in the back glass.
Firemandan is offline
post #18 of 89 Old 03-21-2012, 02:10 PM
firefighter315
Just go ahead and add the sticker, take it with you to work, empty out a bay and have at it. You'll have a Sunday coming up and everyone knows firefighters don't do ANYTHING on Sundays. Plenty of time to work on the Jeep!
My YJ Build Thread
post #19 of 89 Old 03-21-2012, 02:12 PM Thread Starter
Firemandan
1979 CJ7
Ok folks, I hooked up the fuel line and wanted to see what was up with that.
I primed the line and on the first hit, she fired up!!!!
sounded rough but she still fired up. I let it run for about 45 seconds and shut her down, but she fired on the first hit!!!!!ic kle:
post #20 of 89 Old 03-21-2012, 02:18 PM Thread Starter
Firemandan
1979 CJ7
Exhaust system is shot. I have the pipes and everything needed to fix that just gotta get motor out and see what's up with the water in the oil.
Wish me luck guys!
post #21 of 89 Old 03-21-2012, 02:21 PM
Almighty90
Good luck with it!
Almighty90 is offline
post #22 of 89 Old 03-21-2012, 02:27 PM
jrayzhunter
Welcome! Just cut a hole inthe floor board and peddle with your feet!
If it ain't broke..... blow it up!
jrayzhunter is offline
post #23 of 89 Old 03-21-2012, 02:34 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
I would seriously think about finding a low miles junkyard engine and do a swap before I thought about rebuilding that one. probably end up cheaper by the time you tear that one down and start finding all the internal problems that need to be fixed. have fun and welcome to the YJ world.
To view the NEW
click here!!!
tobias94yj is offline
post #24 of 89 Old 03-21-2012, 02:42 PM Thread Starter
Firemandan
1979 CJ7
Not a bad idea neighbor.
post #25 of 89 Old 03-21-2012, 02:44 PM Thread Starter
Firemandan
1979 CJ7
I'm gonna let a buddy check it out and see just whats wrong with it. If we feel that a new engine is needed, then I'll be looking at the local yards to see whats out there. Thanks for the input.
post #26 of 89 Old 03-21-2012, 02:47 PM Thread Starter
Firemandan
1979 CJ7
lol, helped on a many engine swaps at the station on sundays.
post #27 of 89 Old 03-23-2012, 11:33 PM Thread Starter
Firemandan
1979 CJ7
ok guys, the motor is ready to be pulled. I have everything disconnected and tagged. I have a busy day tomorrow, Saturday, so I am planning on pulling it and loading it in the truck to take to my buddies Monday after work and let him see what he can do with it. While the motor is out I'm planning on cleaning the engine compartment up and take a real good look at the underside and get started on the minor body work that I want to take care of. I will be posting pictures of whats going on with the "DD" prodject. If anyone has any tips or pointers, I will be glad to listen.
post #28 of 89 Old 03-24-2012, 08:56 PM Thread Starter
Firemandan
1979 CJ7
engine is out!!!
post #29 of 89 Old 03-27-2012, 11:24 PM Thread Starter
Firemandan
1979 CJ7
Dropped the engine off at my buddies shop on monday,he said he should be able to break into within 2 weeks. That gives me time to work on the body and the inside. Planning on taking everything out from the inside and prepping the floor for coating of some kind, keep in mind, this is gonna be a DD not a show type build so the cost of line-x is out of the question but I will spend a little on a good quality, DIY product. Any ideas?
post #30 of 89 Old 03-28-2012, 06:55 AM
deermjd
Check out Monstaliner. I have not used it personally but it has great reviews and it costs under $150.
94 ZJ Laredo (sold)
98 ZJ TSI (sold)
92 YJ 4.0
deermjd is offline
PROJECT: RAPED APE- 95yj v8 swap titosgreen95yj YJ Wrangler Technical Forum 72 07-27-2015 10:42 PM
TJ AX-15 will fit 95yj??? KenJ95 YJ Wrangler Technical Forum 10 04-19-2013 03:34 PM
95yj dixiebell YJ Wrangler Technical Forum 4 11-20-2011 07:56 PM
D44 into a 95yj PfcLove YJ Wrangler Technical Forum 25 09-29-2011 05:19 PM
95YJ 2.5L problems..help help help jeep couple YJ Wrangler Technical Forum 8 10-30-2006 07:11 PM
