Project Danger Cart XJ - Page 2 - JeepForum.com
post #16 of 283 Old 12-04-2011, 03:50 PM Thread Starter
dukie564
1995 XJ Cherokee
Had an issue with my headlights flashing on and off - tracked it back to an overloaded switch due to my h4 headlight upgrade.
Time for a wiring upgrade! Ordered a harness and relays from eAutoworks.com. Difference was (literally) night and day. Never new my headlights were supposed to be that bright!
Also installed a set of 1.5" wheel spacers I picked up from a guy on JeepForum - Love the stance!
You can see the yellow wiring harness and the spaced out wheels in this picture:
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #17 of 283 Old 12-04-2011, 03:51 PM Thread Starter
dukie564
1995 XJ Cherokee
New issue arose after installing the spacers - my rear tires would hit the flares over big dips due to my inverted rear spring setup (not intentional). I had been thinking for a while while planning out my lift that I was going to install shackle relocation boxes in the rear end. I had been eyeing H.D. Offroad's kit - buy they had always been a weld in solution. Well it just so happened that I was in this quandary about what to do about the rear end hitting when Brian at H.D. Offroad announced the release of their bracket version 2.0 - BOLT IN! They were on a special too where all I had to do for a partial refund of $40 was to post a review/writeup on a few jeep sites. WOOHOO!
Full Review/Install writeup HERE: http://www.jeepforum.com/forum/f11/i...stall-1240026/
Jumped on it:
There's a bracket that bolts though the stock shackle bolt, and using the 4 bolts that hold up a hitch or gas tank skid plate. I already had a hitch I had previously installed when we moved to tow a uhaul, so it was cake. The brackets can be installed over a hitch and the fuel skid if you desire, but I chose to mount these as close to the frame as possible for max clearance and least lift from the brackets (5/8" min built into the brackets if using stock shackles). The other bracket then gets bolted to the top piece and the shackle goes though whichever hole optimizes your rear shackle angle for your setup. The bracket can also be reversed for wheelbase stretches.
I had shackles of the leaf springs I had picked up off a Dodge Dakota for my bastard pack lift springs. Turns out they were 1" longer than stock - exactly what I wanted so the shackle wouldn't hit the brackets under full compression, and to give me the 1.5" total lift I wanted out of the combination.
I'm sensing a theme developing here...
Top Bracket installed, and hitch reinstalled
All done and adjusted - PERFECT! (well...except for my leaf springs...)
MUCH better - Bonus: Rides like a caddy - my spine loves these
dukie564 is offline
post #18 of 283 Old 12-04-2011, 03:52 PM Thread Starter
dukie564
1995 XJ Cherokee
Also around the same time, I was debating installing 703 injectors out of a Dodge Neon. These are about the same size as the stock XJ injectors, but had 4 spray holes instead of one. Better atomization of the fuel for better throttle response and (maybe) better mpgs. Mainly I wanted to do it because I was positive my stock injectors had never manually cleaned or replaced. So i grabbed a set from the local JY and cleaned them up, and rebuilt them with new orings, pintle caps, and microfilters.
Full Writeup HERE: http://www.jeepforum.com/forum/f11/i...-4-0l-1224714/
(Petroleum Jelly?)
Mmmm..tasty
Way better
Niceeeeee
Runs a lot smoother now, and response seems better. MPGs now at 18.5-19.0 avg.
dukie564 is offline
post #19 of 283 Old 12-04-2011, 03:52 PM Thread Starter
dukie564
1995 XJ Cherokee
Installed one of my 6.5" door speakers - required quite a bit of creative "massaging" with a hammer and pliers
dukie564 is offline
post #20 of 283 Old 12-04-2011, 03:54 PM Thread Starter
dukie564
1995 XJ Cherokee
so...onto the juicy stuff I guess, and my current place. Lift plans and parts collection.
Plans as they currently stand:
4 1/2" lift +/-
33x10.5 or 33x12.5 tires in 15x7 rims with 1.5" spacers
3" XJ (actually 4" TJ) coils + 3/4" poly spacer
Bastard Pack rear - XJ / Dakota components with graphite paint and liners, optimized to be as flexy as possible - 3" lift +/- goal for these over stock, w/ 7/16" center pins
Dakota shackles and HD Offroad Relocation boxes (already installed) for 1.5" lift
Stainless Steel extended brake lines
Adjustable short LCAs for now. Long arms later - ideally a 3 link, mid-arm setup.
Shocks - 10" travel front, 8" travel rear
Progressive bumpstops front and rear, rear bumpstop plates, UHMW cylinder bucket spacer up front
Adjustable trackbar and HD frame mount, with frame rail crosstie
steering box brace rod
shims in the rear to adjust angles
Stock Turbine Wheels
Skids - gas tank and TC case
The pile of parts collected so far:
Currie 4" TJ springs and Adjustable LCAs with dual JJs - so beefy
Rough Country Stainless Brake Lines
Stock Turbines:
In great shape!
Dakota Leafs:
Stock gas tank skid and coil spacers
Custom trackbar (won't work for me), Clayton HD Mount, and Frame Crosstie, and Rusty's Offroad grade 8 spring plates and ubolts
Anyways...onto the finished(ish) products...
Painted and Rebuilt LCAs
Cleaned & Painted Coils:
Spring pack Progress:
Made some spring clips
Graphite Paint Applied
Gas Tank Skid cleaned and painted
Picked up a 1/2 Tread BFG KM as a winter tire to replace my ****ty A/T spare till I can afford new bigger ones
Now you're up to date!
dukie564 is offline
post #21 of 283 Old 12-05-2011, 01:31 PM
Xjoutsider
Good work on the jeep man. I peiced my lift together for other people junk. Looking forward to see the lift on.
Xjoutsider is offline
post #22 of 283 Old 12-05-2011, 02:22 PM
thirdeye
sick! looks good
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #23 of 283 Old 12-05-2011, 02:25 PM Thread Starter
dukie564
1995 XJ Cherokee
This is my name inspiration by the way:
"A super-powered, high-tech vehicle designed by a genius, or perhaps space aliens, the Danger Cart can reach speeds of up to four miles per hour. The most impressive aspect of the Danger Cart is, of course, its fierce appearance - many a villain has trembled in fear at the sight of it lumbering toward them."
dukie564 is offline
post #24 of 283 Old 12-05-2011, 07:45 PM
KevKaos
Nice build thread Dukie. It's amazing how a vehicle can look so clean on the outside yet have practically rusted through floor pans. Now if we could just get you up to Rausch with us, you'd be set.
KevKaos
Honey Badger Wheelin'
RED JEEP CLUB # 621
It's not much, but check out my build thread;
Originally Posted by krashnpa View Post
I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.
so I use my original nuts?
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline
post #25 of 283 Old 12-05-2011, 07:53 PM Thread Starter
dukie564
1995 XJ Cherokee
went night wheeling a bit tonight locally. Nice to see the jeep with a fresh coat of mud on it
dukie564 is offline
post #26 of 283 Old 12-06-2011, 12:35 AM
tofuzeppelin
tofuzeppelin's Avatar
cool build man, glad to see you rocking a 5speed XJ, and doing it justice none the less
01 TJ with some stuff
77 SJ Cruzer
Lifes to short for bad coffee and bald tires
tofuzeppelin is offline
post #27 of 283 Old 12-07-2011, 09:35 AM Thread Starter
dukie564
1995 XJ Cherokee
Festivenesssssss
dukie564 is offline
post #28 of 283 Old 12-07-2011, 11:36 AM
andrewmacc
I applaud you for all the write-ups. I never have the patience, plus whenever I'm working on my Jeep I find myself always telling the spectators "now if you have to do this to your truck, don't do what I'm about to do."
Hahah. Good job!
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
post #29 of 283 Old 12-07-2011, 03:24 PM Thread Starter
dukie564
1995 XJ Cherokee
Planning some killer homebrew disconnects based off JKS's design, but better and WAY cheaper
What do you guys think?
dukie564 is offline
post #30 of 283 Old 12-09-2011, 07:45 AM Thread Starter
dukie564
1995 XJ Cherokee
Turned over a quarter million miles today - ready for the next quarter million!!!!
dukie564 is offline
Project Manager special was Project Wifey-(TJ Wrangler) wfochris Jeep Builds 42 10-22-2011 04:00 PM
my 3year project became a 6month project gattaca37 Jeep Builds 7 03-21-2011 02:49 PM
my project YJ confusedYJTJ Jeep Builds 6 10-26-2010 08:04 PM
my 97 project andrew383 Jeep Builds 7 09-19-2010 01:08 PM
My Cj-7 project Petescj Jeep Builds 1 09-03-2008 06:39 AM
