Project Corveep - Page 7 - JeepForum.com
 3Likes
post #91 of 444 Old 05-19-2008, 09:42 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
I only put the teflon tape on the threads... Is that what you guys are talking about? Should I go back and take it off? I kinda cranked down on all of those fittings, so might be tough. Especially now that they're all mounted. Will it hurt to leave it there? I did not use any teflon on the fittings where the hose connects onto.
Next, I liked this one better
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #92 of 444 Old 05-20-2008, 05:44 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The problem with teflon tape on flared fittings is.... you rely on the tight fit at the flare to seal the fitting. When you put teflon on the threads, the joint can "feel" tight before the flare bottoms out and seals. You can try running the system and see if it leaks.
The other thing that kind of sucks about teflon and fuel systems.. get one of those little "hangers" of teflon out past the threads, shear it off when tightening and see how those injectors like it.
BESRK is offline
post #93 of 444 Old 05-20-2008, 06:53 AM
next
Grewe02 - that is definitely a better one
I agree with bersk on taking it off. Also, you don't need to torque AN fittings very hard for them to seal.
next is offline
post #94 of 444 Old 05-20-2008, 08:32 AM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Hm. I guess I'll go and make sure the teflon didn't get inside the lines. Don't need any injectors blowing up
Andy, KD8EIA
Grewe02 is offline
post #95 of 444 Old 05-20-2008, 08:39 AM
next
It looks like you've already picked up your LS1 stuff as I'm a little late to the party. Let me know if there's anything else from that arena that you may need and I might be able to help as I've been a Moderator over at LS1Tech for about 5 years.
next is offline
post #96 of 444 Old 05-20-2008, 04:05 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Andy.. get back to work..
I want to hear it bouncing off the rev limiter already!
BESRK is offline
post #97 of 444 Old 05-20-2008, 04:18 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
I'm going to send off the harness / computer tomorrow morning. Computer needs flashed and the harness needs a few of the plugs trimmed and a few things added. Fuel pump / fan controller.
Other than that... I need UPS to hurry the hell up!!!
Andy, KD8EIA
Grewe02 is offline
post #98 of 444 Old 05-21-2008, 06:13 PM
next
Why are you having the PCM reflashed?
next is offline
post #99 of 444 Old 05-22-2008, 04:44 AM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Because right now it's programmed for an 800 HP car with a Blower
Andy, KD8EIA
Grewe02 is offline
post #100 of 444 Old 05-22-2008, 11:38 AM
Fozzy_Bear
____Proud to be a
Fozzy_Bear's Avatar
I know a few local guys who I trust to tune a LS1. And they work for a good price too. - The people I take my LS1 to do a great job.
Lemme know if you'd like the contact info
Don't mind me... I'm just the comic-relief, talking bear.
Fozzy_Bear is offline
post #101 of 444 Old 05-22-2008, 05:30 PM
MeatPuppet
MeatPuppet's Avatar
Moving! To SD?
Andy,
We need to crack a beer before you leave! I might be having a get together this weekend (Sun). I'll call you to see if you can hang. Are you still at the 513 phone number?
Jim
The “meat puppet” is a peculiar inhabitant of the digital world—a fictional character that passes for a real person online.
MeatPuppet is offline
post #102 of 444 Old 05-22-2008, 05:56 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Robert, You better believe I want that number!! Do these guys have a dyno?
Jim yes that's still my number. Give me a call... Just got home Gonna upload a couple of pics in a second...
Andy, KD8EIA
Grewe02 is offline
post #103 of 444 Old 05-22-2008, 06:21 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Somehow forgot my memory card at home today, so I was only able to snap 3 pictures using the camera's built in memory
Ok, so headers came in. Got off work early so decided to give them a test fit. Got the driver side on. Cool. Good. Went to the passenger side. No go. I originally had a picture showing why they didn't fit, but I had to delete it.
Sooo. Here's why they didn't fit. The tube coming from the most forward port hit the top of the motor mount. Not the same spot it hit last time, this time it hit the part that bolts to the block. Not the part that's welded to the frame. So, what was I to do? Fiddle with the motor mounts to raise the motor a bit. After about 2 hours of un-bolting and re-bolting all 37,000 bolts on the motor mounts, I made it work. AND raised the motor a tad in the process
Anyway, these are the only pics I could get.
I did my best to get the actual motor half of the motor mount in this one... The part that is sandwiched by the rubber. That is what was hitting it. The bolt with the rubber was in the lower of the two holes that are on the angled portion of the mount. I moved the bolts to the upper holes.
If these don't work, I'll probably go with these
http://www.speedwaymotors.com/Tru-Ra...hed,53710.html
And now for suggestion time I bought some radiator hoses for a 2002 Yukon. They fit length wise, and they fit on the water pump fine, but here's the problem:
They don't fit on the damn radiator!! So, I'm going to call Advanced Adapters tomorrow and see what they say to do. I know that they make adapters for hose sizes. I'll see if Advanced Auto has any. If not, what do you guys suggest? Just buy bigger hoses and squeeze down on the water pump end of them?
Andy, KD8EIA
Grewe02 is offline
post #104 of 444 Old 05-23-2008, 05:48 PM
next
I wouldn't suggest the "squeezing" down as you'll have a hard time maintaining a good seal.
Is your radiator from a Yukon (Vortec motor I think) or something LSx based?
next is offline
post #105 of 444 Old 05-23-2008, 08:27 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
It's from Advanced Adapters. They say it's made for an LS equipped narrow frame Jeep.
Andy, KD8EIA
Grewe02 is offline
Hello, My '07 JK Project... Liquor Jeep Builds 132 08-03-2014 07:40 PM
CJ5 Project redcj576 Jeep CJ Forum 148 05-25-2013 11:34 PM
yj project cage013 Jeep Builds 5 08-01-2011 11:40 AM
my project YJ confusedYJTJ Jeep Builds 6 10-26-2010 08:04 PM
my 97 project andrew383 Jeep Builds 7 09-19-2010 01:08 PM
