Project Corveep - Page 17 - JeepForum.com
 3Likes
post #241 of 419 Old 02-15-2013, 12:40 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Just posting this for future reference, I don't plan on doing this soon. Just making sure I don't forget
Stealing ideas from J.P. here. I want to eventually incorporate my fuel cell back into the factory spot....ish. I want to basically do the same thing J.P. did here and here is the finished product, except I want to raise mine about 2 inches so that it will be flush with the bottom of my frame. I am prepared to raise the floor in the back seat area by a few inches to accommodate this, if needed. Here is a sketch I edited to get my idea across:
Red is where I would like to notch the cell
Green is where the factory filler tube / air vent will connect
Brown is the output to the pump / regulator
Blue is the return from the regulator
I'm not sure if I want to actually notch out the Brown part for the "sump" if you will, or if I should follow what J.P. did and use a fuel pickup system inside the tank. If I notch out the corner for a "sump", that would be perfect for connecting it to my current system.
Some other fuel cell options:
http://justgastanks.com/product_info...oducts_id=3798
http://justgastanks.com/product_info...oducts_id=3692
Axle info:
http://www.pirate4x4.com/forum/jeep-...tml#post622178
This mod will be much sooner than the fuel cell, I would like to trim my rear fenders a bit when I stretch the axle, a cut similar to this looks great, I think. I definitely don't want a comp cut, and I would like to keep a bit more of the rear panel than this shows.
Found it here: http://www.4wdandsportutility.com/fe.../photo_16.html
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #242 of 419 Old 04-28-2013, 06:57 PM
Jim1611
Jim1611's Avatar
You driving yours yet?
Jim1611 is offline
post #243 of 419 Old 04-28-2013, 07:10 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
I've been known to set off a few car alarms
Still without gauges and rear driveshaft, so It only goes down the street to the gas station about once a month. I've been trying to decide what to spend money on next, completely redoing the dash, or swapping / stretching the rear axle. I know the dash is more important (for engine health) and cheaper, but I reeeeeally want to stretch the rear!
Andy, KD8EIA
Grewe02 is offline
post #244 of 419 Old 04-29-2013, 07:11 PM
mncdriver
1987 YJ Wrangler
I say do them both! I have LS envy.
mncdriver is offline
post #245 of 419 Old 05-23-2013, 07:49 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Well I've spent the past few weeks trying to connect my starter to the key on the column, instead of the lever switch under the hood. I have been using a ton of resources from John Strenk, mostly through this thread
http://www.jeepforum.com/forum/f8/bu...nector-901819/
And I can confirm that A-14 is the starter wire, A-12 is the battery wire, and A-13 is the engine control (run) wire.
Turns out that my wiring has a voltage drop somewhere along the lines, and I'm only getting 6 volts on the starter when I turn the key. So for now I'm going to stick with lever switch, until I can figure out either what is causing the drop, or if I want to completely bypass the factory wiring just to get it working.
Andy, KD8EIA
Grewe02 is offline
post #246 of 419 Old 05-24-2013, 02:18 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Not sure I'm ready to spend $600 on one of these...
http://www.summitracing.com/parts/prf-10110
Andy, KD8EIA
Grewe02 is offline
post #247 of 419 Old 05-27-2013, 09:03 PM
Jim1611
Jim1611's Avatar
That might be a good investment Andy. Bad wiring can cause a fire and what if it starts when you're gone. Could be terrible if it's parked inside the garage. My biggest concern with that much cash outlay is does it work and is the quality there.
Jim1611 is offline
post #248 of 419 Old 05-29-2013, 09:42 AM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Good point Jim. I think I will give it a go re-wiring some of it myself first. If I can't get it to dance, I'll probably spend the cash.
In other news, I just put this bad boy on order
Andy, KD8EIA
Grewe02 is offline
post #249 of 419 Old 05-29-2013, 09:31 PM
Jim1611
Jim1611's Avatar
I'm looking forward to seeing that dash installed. I like it
Jim1611 is offline
post #250 of 419 Old 07-08-2013, 08:29 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Got a present today!
Andy, KD8EIA
Grewe02 is offline
post #251 of 419 Old 07-13-2013, 10:19 PM
Jim1611
Jim1611's Avatar
Looks nice Andy and well made. Are the rectangular holes below the gauges for switches? And what's going right over the sterring wheel? This ought to help you get that wiring tied up.
Jim1611 is offline
post #252 of 419 Old 07-14-2013, 12:44 AM
Coiz
1979 CJ7
I'm with Jim. Looks great but am also curious on what is above the column.
What are you going to run with those 9 switches?
Mike
Coiz is offline
post #253 of 419 Old 07-14-2013, 06:47 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Above the column, for now it is just a blank piece of steel, and later once I decide what all I want to put there, it will be an idiot light cluster. Turn signals, parking break, check engine, stuff like that. I haven't decided if I want to just go with blank LEDs there, or something different. At the moment, I'm leaning towards some etched indicators. Like a left arrow and a right arrow for the turn signals, an engine for the CEL, maybe a skull and cross bones for the parking brake.
Those holes are cut for the ARB style switches. 9 of those, and 1 of these on the far left. Copying Mike with his radiator fan idea here
http://www.waytekwire.com/item/44279...TOGGLE-SWITCH/
Also, the holes under each switch will house a push button style circuit breaker
http://www.waytekwire.com/products/1...pe=Panel-Mount
So for all of the switches, I think it will be
Radiator Fan - 3 position, on-off-on.
Air compressor
Rear Locker
Front Locker
Rock Lights
Rear Lights
Forward Lights
Interior Lights
Extra 1
Extra 2
Not sure what I'll put in the Extras yet, but I figure it's not a bad idea to have options for expansion
Andy, KD8EIA
Grewe02 is offline
post #254 of 419 Old 07-14-2013, 08:37 PM
Jim1611
Jim1611's Avatar
You like wiring, don't you.
I like the switches. That fold down feature is a great idea on the dash too.
Jim1611 is offline
post #255 of 419 Old 07-16-2013, 11:21 AM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Ha, they didn't call me sparky for nothin in the Navy! Ha. I've been trying to get the old wiring to work for awhile now, tinkering with it here and there. Replaced a few wires to get the thing cranking with the key, and it still has a lot of bugs. I think the engine harness I got is not wired correctly for my tub. Honestly I'm getting closer and closer to buying that painless harness. I called them and they confirmed it does replace the factory bulkhead connector, which I think is a big part of my problems.
Andy, KD8EIA
Grewe02 is offline
Hello, My '07 JK Project... Liquor Jeep Builds 132 08-03-2014 08:40 PM
CJ5 Project redcj576 Jeep CJ Forum 148 05-26-2013 12:34 AM
yj project cage013 Jeep Builds 5 08-01-2011 12:40 PM
my project YJ confusedYJTJ Jeep Builds 6 10-26-2010 09:04 PM
my 97 project andrew383 Jeep Builds 7 09-19-2010 02:08 PM
