Project Corveep - Page 12 - JeepForum.com
 4Likes
post #166 of 465 Old 02-08-2011, 10:21 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Fixed a bunch of pictures that were broken. For your viewing enjoyment
After I recuperate some of the savings I spent on the shop cost, I'll start buying some necessities.
Fuel cell straps
http://www.summitracing.com/parts/SUM-291220S-99/
I'm pretty sure I've decided on Auto Meter gauges with the stock dash. So what I'll probably do is buy a new dash to fit my Jeep, with only the steering column holes in it. I'd really like to keep the stock speedo, I'll have to do some research to see if I can do that or not.
Dash
http://www.jeep4x4center.com/product...umber=11144.10
Maybe something along these lines? Still not too sure
http://i222.photobucket.com/albums/d...e/DCP_1636.jpg
I'd like to keep it more along the lines of stock looking, maybe with some AutoMeter angled mounting cups
http://www.autometer.com/cat_mounts.aspx?sid=54
Or something combined like this, maybe used in conjunction with the stock MPH gauge?
http://www.sfxperformance.com/parts/AUM1310.htm#
I also found this post on CK5 about setting up a tach,
http://coloradok5.com/forums/showthr...=252178&page=9
Lots of general tips
http://www.jeepforum.com/forum/f22/o...-swap-1287392/
Shoot me some dash ideas!
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #167 of 465 Old 02-10-2011, 05:19 AM
243
1978 FSJ Cherokee
WOW!!!!
Oh crap, I am late for work....
Dave's 78 Build
243 is offline
post #168 of 465 Old 02-11-2011, 01:55 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Originally Posted by Jim1611 View Post
Hey Andy if you haven't seen any of Joe's welds, well he's pretty darn good at it. Glad he's close by.
Hey Jim, I'm pretty sure you read this thread every time I update it so I'll just ask here instead of PMing you. I want to stretch my rear axle about 4"-ish as soon as it gets out of the shop. Joe has already agreed to help me with the Jeep, just gotta ask if he'll help with the stretch.
My question, will your shackle hangars work if I mount the rear set on the outside of the rear bumper? They'll be mounted vertical instead of horizontal. Will that be a problem with the way they're designed? I'm ok with having them welded straight to the bumper if needed
Andy, KD8EIA
Grewe02 is offline
post #169 of 465 Old 02-11-2011, 07:17 PM
Jim1611
Jim1611's Avatar
You could make that work Andy. If you mount them vertically just keep in mind that the shackles themselves will need to have room to move past the hanger itself. That means you won't be able to have a tie block between the shackle plates. You would still hit on the frame they're bolted to though at some point. I'm going to look around at some of the stretched frames and see what I can find. I think with the right bracket this will work though and if it did you wouldn't have so much hanging behind the axle.
I am subscribed to your thread, just made my look at it this morning. Glad you're moving forward and let me know if I can help.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is online now
post #170 of 465 Old 02-11-2011, 09:25 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Here's what I'm thinking of, taken from Tony's 1,000,000,000 page thread
flatlander757's 03 TJ build/update thread
Keep in mind, my tires will be about half that size
Originally Posted by flatlander757 View Post
Andy, KD8EIA
Grewe02 is offline
post #171 of 465 Old 02-12-2011, 06:37 AM
243
1978 FSJ Cherokee
I think they would work fine if you cut the lower end off flush with the bumper and look better too.
How long do you expect the Jeep to be in the shop?
Dave's 78 Build
243 is offline
post #172 of 465 Old 02-12-2011, 08:48 AM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
If all goes well, (ie no motor rebuild), they say 1 more week. So I'll be realistic and say 2 weeks.
Andy, KD8EIA
Grewe02 is offline
post #173 of 465 Old 03-01-2011, 05:16 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Shop called today, they started on it this morning. (3 weeks later...) He says he's going to rebuild the transmission, which I expected. When Eddie and I put the new main shaft in it wasn't exactly the best. We were in a hurry. That and the motor / wiring harness looks great. Thank God. I really didn't want to pay for a new harness.
He also says he ordered a clutch master / slave setup, accelerator cable, and some other small things. I think he said a dipstick and a small air filter for the right side valve cover. So no surprises yet. I knew all of that stuff needed ordered. Probably could have saved some money and ordered them myself but I didn't know what I was looking for and didn't want to order the wrong stuff.
Now that he's working on it, I hope to have it back in about a week or two!
Andy, KD8EIA
Grewe02 is offline
post #174 of 465 Old 03-06-2011, 08:16 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Ahh, hopefully it'll be back to you soon (fingers crossed ).
Whenever you wanna stop by & do some plasma, drilling, grinding, welding, repeat, my garage is at your service.
Taylor wants to have me plasma a bumper & truss for his XJ. So the more the merrier.
Joe Dillard is offline
post #175 of 465 Old 04-02-2011, 11:12 AM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Just dropped the Jeep off at M.I.T Drive train locally. They quoted me an estimate at just under $4k to finish it up and get it running. Not street legal, and not Cali legal, just running. I'm gonna head back over there in a few days and see if the price came down any. I supplied almost everything to get it running. They just need to install it and *hopefully not* rebuild the motor. Wish me luck!
Only 2 months later. Not too bad.
They fired the engine yesterday. Going to finish the wiring and I should have it by next weekend if all goes well
Andy, KD8EIA
Grewe02 is offline
post #176 of 465 Old 04-07-2011, 03:15 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
I'll let the video do the talking
Andy, KD8EIA
Grewe02 is offline
post #177 of 465 Old 04-07-2011, 04:00 PM
cjFitz
1978 CJ7
Sweet! Congratulations!
cjFitz is offline
post #178 of 465 Old 04-07-2011, 07:01 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Nice! Sounds good Andy!! It's always a satisfying moment to fire the engine for the first time.. sort of breathes new motivation into the project.. letting you "see the light at the end of the tunnel".
So what's the plans for the axles?
BESRK is offline
post #179 of 465 Old 04-07-2011, 07:24 PM
Coiz
1979 CJ7
Very cool.
Mike
Coiz is offline
post #180 of 465 Old 04-07-2011, 07:43 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
For now, just going with 1 piece shafts in the back, and going to stretch it a little bit. I might put a pinion brake on the transfercase as well. That's just to get it street worthy.
Long term, I'm thinking 9" front and rear. 60 knuckles and more than likely a 3 link up front, and for sure a trussed 4 link in the back.
My first step though is to get a few gauges hooked up so I can actually drive it without worrying about it overheating. After that the rear axle is getting moved and setup.
Andy, KD8EIA
Grewe02 is offline
Hello, My '07 JK Project... Liquor Jeep Builds 132 08-03-2014 07:40 PM
CJ5 Project redcj576 Jeep CJ Forum 148 05-25-2013 11:34 PM
yj project cage013 Jeep Builds 5 08-01-2011 11:40 AM
my project YJ confusedYJTJ Jeep Builds 6 10-26-2010 08:04 PM
my 97 project andrew383 Jeep Builds 7 09-19-2010 01:08 PM
