Project "Close enough" - HuLuD44's LCOG TJ Build
BUILD THREAD REVAMP TIME!!!! Since this thread was started over 3 years ago. And this Jeep has been through numerous transformations. Its time to freshen up the beginning of this with current specs and pic. 12/12/17
2000 Jeep wrangler sport. 6 cyl 4.0 Purchased from a dealer in 05' spotless, one owner, bone stock, with 45k on it. The Jeep has been rebuilt several times from budget 33s to 35s, to stretched on 37s and now the current set up on tons and 39s.
I will start the build log at the first major fab work I did to the Jeep. This was the Waggy 44 build, rear stretch to 104" wb, fuel cell, and sport cage. From there it will take on the natural progression up to where it is today.
Current Specs as of 12/12/2017
2000 TJ
6 cyl 4.0
IronMan Fab .25" MML
rh32 w/ Tranny cooler
Transfer Case:
Atlas 4 speed 3.8/10.3
Front Axle:
Steering 14 bolt
Barns Shave
Yukon 5:38
Yukon Full spool
Crane revolution seals
SOLID dana 70 Cs
SOLID D60 hub assemblies
Chevy KP outers
Yukon 35 spline chromos : Custom inners
Yukon Super joints
Ballistics 14 bolt truss : Modified to Driver drop
Ballistics Pinion guard
Yukon slugs
Steering:
7/8th Ballistics Heims
.25 DOM
Artec highsteer
PSC extreme Hydro Assist w/ cooler
Rear axle:
14 bolt
Full ballistics shave
Yukon 5:38
Yukon full spool
TMR Customs stubby truss with pinion tie in and guard
Disc breaks
Suspension:
110" WB
22" Frame height
Artec Back half Kit
Custom 3 link front
7/8 heim upper
1.25 heim lowers
.25 DOM
Ballistics brackets
Currie Antirock
Custom 4 link rear single tri
1.25 heims
.25 DOM
Ballistics brackets
Custom Straight panhard, 7/8 heims
14" Air shocks
Front 2" up/12" down
Rear 4" up/ 10" down
Tires/Rims:
39" Red label Krawlers (Stickies)
8 lug Steel
TMI rock rings
Armor:
Custom roll cage
Dove tail / 8" per side
Poison Spyder XC Negative flares w/ inners
Barns/Ballistics 3/8 diffs
UCF Ultra high belly
EMP Steering box
EMP Rad skid
EMP oil pan skid
Modified Smitybilt XRC stinger bumper
Misc:
Adams 1350 shafts
Hydroboost brake set up
RCI 2162 Cell w/ Genright fuel ring
1" daystar BL
JK front turn signals
Half Top / wind jammer
Best top Canvas half doors
Smittybilt Harness seats
Front and rear Suck down winches
Some of my favorite fashion shots.
August 17'
Big Dogs VA
4/16/16 Waggy44/8.8, 37 reds, 104" wb
The back dating will start shortly....................
2000 TJ
6 cyl 4.0
Transfer Case:
Front Axle:
Steering 14 bolt
Barns Shave
Yukon 5:38
Yukon Full spool
SOLID dana 70 Cs
Chevy KP outers
Yukon Super joints
Yukon slugs
Steering:
.25 DOM
Artec highsteer
Rear axle:
14 bolt
Yukon 5:38
Yukon full spool
Disc breaks
Suspension:
110" WB
22" Frame height
Artec Back half Kit
Custom 3 link front
7/8 heim upper
1.25 heim lowers
.25 DOM
Ballistics brackets
Currie Antirock
1.25 heims
.25 DOM
Ballistics brackets
14" Air shocks
Tires/Rims:
8 lug Steel
TMI rock rings
Armor:
Custom roll cage
EMP Steering box
EMP Rad skid
EMP oil pan skid
Misc:
Adams 1350 shafts
1" daystar BL
August 17'
Big Dogs VA
Image uploading. Refresh page to view
