Project CJ7 "PJ edition" complete rebuild ! - Page 2 - JeepForum.com
post #16 of 67 Old 12-19-2013, 05:22 AM Thread Starter
KristPJ
1976 CJ7
Originally Posted by sig0jeep
You have worked your tail off on that body. It is looking great and you are going to have a great ride when you are done!!
thanks ! it's all fun stuff ! learning at the sane time !
http://www.jeepforum.com/forum/f22/project-cj7-pj-edition-complete-rebuild-1628105
KristPJ is offline
post #17 of 67 Old 12-19-2013, 07:34 PM Thread Starter
KristPJ
1976 CJ7
So here are the pictures of what was done today, it is all on ruff for now, all I want it to have the tub ready to sit on the frame fast enough so I can finally get started on installing my GenRight suspension. Then I will be able to take my time fix every little detail on it and sandblast it for a clean build! I am some how satisfied with my work, i never done any body/metal work before... ok there are a few points that need to be corrected, like little gaps for bad mesuring but all this can be addessed! So the missing part of the firewall is now in place, driver side floor pan and a few little patches. and the step brace patch, you can see here on the pictures, all the grinding of the welds will come later on in the build, for now it is far from the priority
KristPJ is offline
post #18 of 67 Old 02-15-2014, 08:39 PM Thread Starter
KristPJ
1976 CJ7
I'm back! sorry for those of you following me, I know I have not posted anything in a while, once again! But in the past few week I did a little more work, ordered a few more parts and drew some plans for new parts I want to get build (new frame body mounts with integrated 1 inch lift, a little like the genright YJ one's). So I was kinda busy with it anyways! What I have done in the past weeks, still on the tub (can't wait to finish with it so I can get the genright suspension started), before christmas I had cut and welded the driver floor panel in as shown in previous post. since then I rebuild the lower part of my cowl support, welded it on then installed the Jeep clip from classic ent. and built my rocker panel. once all these were set I welded them in place on the tub. as you can see the rocker is a little longer. this is to fit with the new corner guards... wheel well is a little further back for the stretch. I wasn't sur how I would install the genright stretch corner guards on the tub. In the instructions they say to bolt them on with the hardware they come with. Maybe down south where the weather is nice 11.5 months out of 12 it is a good idea! But here in Quebec, Canada, with 6 months of winter, 2 of spring 3 of fall ... and if lucky 4 weeks of summer, I didn't like the idea of squeezing two sheet metal together, the risk of getting water or crap stuck in between, starting a new phase of rust! Not my plan... So i tool many mesurements clamped the corner guard on and off making sur all was ok then cut off all the old part of the rear quarter panel so i can next weld in the corner guard as replacement! i also had to trim about 3/8" on the top of the corner guard and about 1" near the tail gate part so I can have enough space to weld on the remaining part of the tub. I also removed the support behind the door since I need the rebuild the lower part of it to, then maybe trim it a little since there is a nice diffrence between the tub sheet metal and the corner guard. 18 Ga vs 3/16" ... a challenge to weld ! Once I finish welding it in place, I need to bring in my frame so I can get the new body mounts placed at the right spots. passenger side are all in place from factory, but driver side, since it is a YJ to CJ conversion, I got rid of the rotten mounts for the new CJ ones. Parts I ordered for this is the energy suspension body bushing kit, and the crown kit for the sleeves. So this is it for now, I really will try hard to update more often. I have lots of mesurments taken and keep double checking ... so no worries for the tub tweaking, I know its not braced but I am not worried about it.
KristPJ is offline
post #19 of 67 Old 02-22-2014, 06:28 PM Thread Starter
KristPJ
1976 CJ7
I passed a few hours at the garage this afternoon, I finally got the driver side all closed!
Last time I prepared the body and corner guard. today I tacked it in place... I think I will need to do tacks for the whole piece, welding 18Ga to 3/16 was a little challenging, I don't think I will be able to do a continuous bead.
All i have to do now on this side, is the final welding, and trim the rocker to have it fit with the fender well. fix the little details and install the body supports. For this I will bring in my frame so I can be sure all fits straight in place. then I will proceed to the final stuff and continue to the passenger side. (I might not update much for the passenger side since it is pretty much a copy and past of the driver side. I'll wait for the Finished product before priming it for more updates)
so this is what it looks like for now, you can see the strech in the fenderwell, a few welds and a few places I need to retouch!
One thins I forgot to take in picture and post is the panel support(where the door jam screws in) i had to remove it and rebuild the lower part. this will be installed soon. Ill post a picture next week.
KristPJ is offline
post #20 of 67 Old 03-10-2014, 11:12 AM Thread Starter
KristPJ
1976 CJ7
So this week I some how did good progress, it may not seem like much but I think it's all good since everything worked out fine! I brought in my frame at the garage(not working on this one yet) so I could sit the tub on it and be certain all sits straight! I got my Energy suspension bushings in place, finished fixing the front driver body support, positioned the outboard floor rail, installed the rollbar to see if all was in right spots, then dropped the tub on the frame, braced the rear corner guards at the right measurements so i can weld in the body panel support(one with the door jam)... anyways here are a few pictures plus a glimps one of the tub with the mini boat side rocker I will be installing this week ! ] No worries about the crossmember, o got a new ones build like the original, but in 3/16 steel And the glimps picture ...
KristPJ is offline
post #21 of 67 Old 03-10-2014, 07:24 PM
lovett86
well, thats looking good
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is online now
post #22 of 67 Old 03-11-2014, 12:12 PM Thread Starter
KristPJ
1976 CJ7
thanks!
KristPJ is offline
post #23 of 67 Old 06-10-2014, 03:42 PM Thread Starter
KristPJ
1976 CJ7
Once again, it's been a while since I last posted the work done on my CJ build, so here is a quick update; lately I got going on the passenger side,I prepared and tack welded the passenger side floor, build a few more body parts and started the install. What I will have left is to cut the quarter panel and replace it with the corner guard. here you can see the difference between the stock fender well opening and the new opening with the gen-right stretch corner guards. so as soon as this corner guard is welded I will be able to install the new mounts for the body in the right spots so the tub is centered on the frame then I can do a little of the ruff buffing, and put is aside so i can get the suspension started. i recently found a clean dana 60-isu full float to replace the dana 61 I accidently purchased a few years ago !
KristPJ is offline
post #24 of 67 Old 06-11-2014, 07:18 PM
lovett86
nice work on the tub, i know what u mean about the weather up here, im just over in ontario and just about every car older then 3 years has rust on it
its a rusty one
post #25 of 67 Old 08-31-2014, 02:27 PM Thread Starter
KristPJ
1976 CJ7
here we go again! as mentioned in the past posts, I did not want to update until my passenger side was almost over, since it was a copy and past of the driver side... so, here is what was done in the past few months, in my free time. build a few parts and welded them in place, then I braced the tub(should of started with this) with the measurments I got to put everything back in place as it should be. Once all this was placed, I sandblasted my windshield frame, I still have a few repairs to do on it but it looks pretty clean! then I went for the rear end and tac welded my corner guard ! so here are the new pictures... slowly not fast it is starting to look like a CJ. I still have to straighten a few parts and area's on the tub, but it should not be a big deal. I also drew a few new parts i need to get build with autocad, high clearence bullet prood body mounts, my axles flanges for the rear disc conversion and started the rear inner frame parts aswell ! more to come in the next few weeks ! any suggestions or comments are always appreciated !
KristPJ is offline
post #26 of 67 Old 08-31-2014, 09:42 PM
lovett86
jeeps looking good
its a rusty one
post #27 of 67 Old 08-31-2014, 10:21 PM Thread Starter
KristPJ
1976 CJ7
jeeps looking good
thanks! i had a look at your build! great job!
KristPJ is offline
post #28 of 67 Old 08-31-2014, 10:38 PM
lovett86
Thanks man, hoping to have it running this winter and maybe painted next spring
its a rusty one
post #29 of 67 Old 12-04-2014, 10:56 AM Thread Starter
KristPJ
1976 CJ7
Once again it has been a while since I last wrote up here. but a few things have been done in my spare time. Since the last time I worked on the tub, I have taken it off the frame, so I can place the mechanics on. Cut the factory suspension mounts, I also cut of the bad part of the rear inner frame. I took the measurement and drew it. now it is off the the machine shop to cut and fold those new parts for the frame. I will mention it again, for now all I am doing will be on the ''ruff'' I want it to be very clean when I am done so i will not sand blast not prime anything until i am 100% sure there will be no more cutting grinding or welding to do... as you can see I placed tranny and clocked t-case on the skide, they will most probably move again, I am waiting for my order of M.O.R.E bomb proof motor mounts. My wooden rack will also have to move away. To build the suspension and support the jeep I need something more solid, so I build some ajustable screw jackstands 18 inch to 30 inch ajustement. they should be done be the weekend, UPS said I will receive my scaffold scewjacks today ... for the rest all is in place. Rear Dana 60ISU is gone to get shortened. so hopefully I will receive all I need in the next week or so. From there I will be able to prepare the rear 4 link. here are the few pics I have, more will come soon. I will let you see the finished product of the Jackstands from here to next weekend.
KristPJ is offline
post #30 of 67 Old 12-05-2014, 10:17 PM Thread Starter
KristPJ
1976 CJ7
Today I tack welded the 3 other jack stands, and i recieved my scaffold screw jacks! all I need to do now is finish the welds, get 4 tappered bearings so with the weight of the jeep i can still turn the ajustment handle freely and build the top part of the jack stands. I'm hesitating on a flat 3/4 x 2 x 4 inch plat or something more in a "U" shape in similar size. I also need to cut the screws a little. they sould ajust from 20 inches to 33/34 inches high.
Here are a few pictures if what they look like
http://www.jeepforum.com/forum/f8/pr...orumsite/20623
KristPJ is offline
