Project CJ Vette - Page 17 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Project CJ Vette
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 02-15-2013, 12:40 PM   #241
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Just posting this for future reference, I don't plan on doing this soon. Just making sure I don't forget
Stealing ideas from J.P. here. I want to eventually incorporate my fuel cell back into the factory spot....ish. I want to basically do the same thing J.P. did here and here is the finished product, except I want to raise mine about 2 inches so that it will be flush with the bottom of my frame. I am prepared to raise the floor in the back seat area by a few inches to accommodate this, if needed. Here is a sketch I edited to get my idea across:
Red is where I would like to notch the cell
Green is where the factory filler tube / air vent will connect
Brown is the output to the pump / regulator
Blue is the return from the regulator
I'm not sure if I want to actually notch out the Brown part for the "sump" if you will, or if I should follow what J.P. did and use a fuel pickup system inside the tank. If I notch out the corner for a "sump", that would be perfect for connecting it to my current system.
Some other fuel cell options:
http://justgastanks.com/product_info...oducts_id=3798
http://justgastanks.com/product_info...oducts_id=3692
Axle info:
http://www.pirate4x4.com/forum/jeep-...tml#post622178
This mod will be much sooner than the fuel cell, I would like to trim my rear fenders a bit when I stretch the axle, a cut similar to this looks great, I think. I definitely don't want a comp cut, and I would like to keep a bit more of the rear panel than this shows.
Found it here: http://www.4wdandsportutility.com/fe.../photo_16.html
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote Quick reply to this message
Unread 04-28-2013, 06:57 PM   #242
Jim1611
Jim1611's Avatar
You driving yours yet?
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 04-28-2013, 07:10 PM   #243
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
I've been known to set off a few car alarms
Still without gauges and rear driveshaft, so It only goes down the street to the gas station about once a month. I've been trying to decide what to spend money on next, completely redoing the dash, or swapping / stretching the rear axle. I know the dash is more important (for engine health) and cheaper, but I reeeeeally want to stretch the rear!
Andy, KD8EIA
Unread 04-29-2013, 07:11 PM   #244
mncdriver
1987 YJ Wrangler
I say do them both! I have LS envy.
mncdriver is offline   Reply With Quote Quick reply to this message
Unread 05-23-2013, 07:49 PM   #245
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Well I've spent the past few weeks trying to connect my starter to the key on the column, instead of the lever switch under the hood. I have been using a ton of resources from John Strenk, mostly through this thread
http://www.jeepforum.com/forum/f8/bu...nector-901819/
And I can confirm that A-14 is the starter wire, A-12 is the battery wire, and A-13 is the engine control (run) wire.
Turns out that my wiring has a voltage drop somewhere along the lines, and I'm only getting 6 volts on the starter when I turn the key. So for now I'm going to stick with lever switch, until I can figure out either what is causing the drop, or if I want to completely bypass the factory wiring just to get it working.
Andy, KD8EIA
Unread 05-24-2013, 02:18 PM   #246
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Not sure I'm ready to spend $600 on one of these...
http://www.summitracing.com/parts/prf-10110
Andy, KD8EIA
Unread 05-27-2013, 09:03 PM   #247
Jim1611
Jim1611's Avatar
That might be a good investment Andy. Bad wiring can cause a fire and what if it starts when you're gone. Could be terrible if it's parked inside the garage. My biggest concern with that much cash outlay is does it work and is the quality there.
Unread 05-29-2013, 09:42 AM   #248
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Good point Jim. I think I will give it a go re-wiring some of it myself first. If I can't get it to dance, I'll probably spend the cash.
In other news, I just put this bad boy on order
Andy, KD8EIA
Unread 05-29-2013, 09:31 PM   #249
Jim1611
Jim1611's Avatar
I'm looking forward to seeing that dash installed. I like it
Unread 07-08-2013, 08:29 PM   #250
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Got a present today!
Andy, KD8EIA
Unread 07-13-2013, 10:19 PM   #251
Jim1611
Jim1611's Avatar
Looks nice Andy and well made. Are the rectangular holes below the gauges for switches? And what's going right over the sterring wheel? This ought to help you get that wiring tied up.
Unread 07-14-2013, 12:44 AM   #252
Coiz
1979 CJ7
I'm with Jim. Looks great but am also curious on what is above the column.
What are you going to run with those 9 switches?
Mike
My build thread
Coiz is offline   Reply With Quote Quick reply to this message
Unread 07-14-2013, 06:47 PM   #253
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Above the column, for now it is just a blank piece of steel, and later once I decide what all I want to put there, it will be an idiot light cluster. Turn signals, parking break, check engine, stuff like that. I haven't decided if I want to just go with blank LEDs there, or something different. At the moment, I'm leaning towards some etched indicators. Like a left arrow and a right arrow for the turn signals, an engine for the CEL, maybe a skull and cross bones for the parking brake.
Those holes are cut for the ARB style switches. 9 of those, and 1 of these on the far left. Copying Mike with his radiator fan idea here
http://www.waytekwire.com/item/44279...TOGGLE-SWITCH/
Also, the holes under each switch will house a push button style circuit breaker
http://www.waytekwire.com/products/1...pe=Panel-Mount
So for all of the switches, I think it will be
Radiator Fan - 3 position, on-off-on.
Air compressor
Rear Locker
Front Locker
Rock Lights
Rear Lights
Forward Lights
Interior Lights
Extra 1
Extra 2
Not sure what I'll put in the Extras yet, but I figure it's not a bad idea to have options for expansion
Andy, KD8EIA
Unread 07-14-2013, 08:37 PM   #254
Jim1611
Jim1611's Avatar
You like wiring, don't you.
I like the switches. That fold down feature is a great idea on the dash too.
Unread 07-16-2013, 11:21 AM   #255
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Ha, they didn't call me sparky for nothin in the Navy! Ha. I've been trying to get the old wiring to work for awhile now, tinkering with it here and there. Replaced a few wires to get the thing cranking with the key, and it still has a lot of bugs. I think the engine harness I got is not wired correctly for my tub. Honestly I'm getting closer and closer to buying that painless harness. I called them and they confirmed it does replace the factory bulkhead connector, which I think is a big part of my problems.
Andy, KD8EIA
