Project CJ Vette - Page 15 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Project CJ Vette
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerraiThe Original 3/8" Ruffstuff Diff Cover!
Unread 05-27-2011, 03:08 PM   #211
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
License plate light / third brake light came in the mail, the frame is something I saw at Wal-Mart / Autozone forever ago and thought "this will be perfect for when I move my license plate frame."
Well I finally bought the Rock Hard 4x4 license plate relocation bracket, with a military discount and after chatting on the phone with the owners for awhile, it was very cheap.
I couldn't get the camera to show the light correctly, it looks blue but it is very white. Lights up the plate perfectly I think. Plus, it's different. Haven't seen many Jeeps (or cars for that matter) with something like this
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote Quick reply to this message
Unread 05-29-2011, 04:31 PM   #212
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Any preference? I like both equally I think. This was the only plate I could pick for the Corveep, Was the only one to fit all of the characters
Andy, KD8EIA
Unread 05-30-2011, 06:40 AM   #213
MeatPuppet
I like scenic mountain to seashore.
Jeette?
Bowtied?
Cjvette?
The “meat puppet” is a peculiar inhabitant of the digital world—a fictional character that passes for a real person online.
MeatPuppet is offline   Reply With Quote Quick reply to this message
Unread 06-07-2011, 03:35 PM   #214
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Just stacking some info here for later use
http://www.clubcobra.com/forums/aust...uages-ls1.html
http://www.ls1tech.com/forums/conver...l#post14906867
http://www.thirdgen.org/techboard/lt...p-4th-gen.html
Andy, KD8EIA
Unread 06-07-2011, 08:53 PM   #215
woooter61
Can't wait to see some more pics. Making good progress!
woooter61 is offline   Reply With Quote Quick reply to this message
Unread 07-30-2011, 07:37 PM   #216
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
About a month ago, I was driving the Jeep to the gas station and the front driveshaft decided it didn't want to be under the Jeep anymore. After a week or two of not being able to get the 1 1/8 inch nut off the pinion, I borrowed the neighbor's hi-lift handle and parked the Jeep against the curb. It came off in about 3 seconds. Notice the front right bolt, half of it is still stuck in the yoke.
A few weeks ago, Quadratec was nice enough to ship me a pair of these. One for the Dana 30 and one for the AMC 20. Apparently the splines are different on the pinions so make sure you get the right one.
More to follow soon
Andy, KD8EIA
Unread 07-30-2011, 08:17 PM   #217
Jay12
This is also a "jeepvette":
http://cgi.ebay.com/ebaymotors/Custo...item3a68741092
Also ugly as hell IMO
Build
Jay12 is offline   Reply With Quote Quick reply to this message
Unread 08-06-2011, 06:26 PM   #218
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Kinda glad I'm replacing the pinion seal while I'm in here. This is all that is left of the old one.
Andy, KD8EIA
Unread 08-06-2011, 10:10 PM   #219
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Since I brought all my tools out, Dakota figured she should bring her ball out, too. That torque wrench is almost as big as the damn drive shaft!
Anyway, got the pinion yoke replaced. Started the torque out at 100 ft lbs, then increased it by 25 each time till I heard the click. Once I got to 200, I stepped it up by 10 ft lbs each time. Randy's ring and pinion say anywhere between 200 and 250 is ok. I got it up to 230 ft lbs. Check out the U-bolts, I threw one of them in so you all could see. The yoke itself is actually beefed up to support the bolt going through the yoke instead of threading into it.
I was going to wait to install the drive shaft until tomorrow so I can clean it up and paint it. But knowing myself I knew I couldn't wait. I wanted to drive it. So I went to install the drive shaft. Until... See on the right side of the yoke? The tab that holds the u-joint cap in place is gone. Looks like I'll be calling Quadratec in the morning!
Andy, KD8EIA
Unread 08-24-2011, 01:10 PM   #220
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Got new yokes for both ends of the t-case. I'll hopefully be motivated enough to change them this weekend.
In other news, I got a new toy Thank God no more Civic!!!
Andy, KD8EIA
Unread 11-15-2011, 06:33 PM   #221
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
I work slow. In other news, it moves!!! Again.
Before,
During,
And after,
I followed the advice of JeepTech and torqued the output yoke to 120 ft/lbs.
I couldn't get the slip joint to extend enough, so out came the ratchet strap. It got cut off in the upload, but I strapped it to the rear axle. In hindsight, it probably would have been easier to install this end first.
I moved it about 10 feet in reverse, and then forward again. Just enough to fix the parking job from when I pushed it in. I'll have to fill the transfer case tomorrow, got dark outside before I could fill it up. After that, I think it'll be car wash time around the block.
Andy, KD8EIA
Unread 02-14-2012, 05:37 PM   #222
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Bought some factory alloys and went from 265/70/17 to 285/70/17. Next is a tuner so I can fix the speedo, then back to the Jeep.
Speaking of, I'm going to get some brackets welded on the front bumper of the CJ so I can tow it around.
Andy, KD8EIA
Unread 03-23-2012, 12:10 AM   #223
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
About 2 weeks ago I got off my hind quarters and stole Joe Dillard's trailer for an hour or two. Towed the CJ over to his place and welded up the brackets that came with my tow bar kit.
At first we thought of cutting off the tabs on the front of the bumper and welding the brackets on top of that. Decided against it since they are pretty huge and pretty handy. Thought about welding them above the bumper for the sake of clearance on the rocks, but then I'd need a huge inverted hitch since it would be so high. Finally decided to mount them below, and make them rock proof. They appear to be pretty un-smash-able to me.
Found some scrap square tubing in Joe's garage, and welded the brackets to them.
Fabbed up an L bracket for the side, and a plate for the rear. Welded it all in and Presto!
Andy, KD8EIA
Unread 03-23-2012, 12:16 AM   #224
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
After flat towing the Jeep home, couldn't get the D300 back into gear. While towing I had everything open / neutral. Axle hubs, t-case, and trans. Going to see if I can find time this weekend to drop it down, and next weekend I'll take it apart and possibly (hopefully) have a good reason to buy a 4:1 conversion for it.
Andy, KD8EIA
Unread 03-23-2012, 12:41 AM   #225
Joe Dillard
Electric Chair Operator
Looks good with paint on 'em Andy.
Bummer about the tcase. Taylor will figure it out.
Joe Dillard is offline   Reply With Quote Quick reply to this message
