Project CJ Vette - Page 12 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Project CJ Vette
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line20 Ton Press Brake DIY Builder Kit @ Swag Off Road
Unread 02-08-2011, 08:55 AM   #166
SKT
1981 CJ7
Originally Posted by 243 View Post
Good luck
Hopefully you can get some progress photos while the shop is working their magic!
X2...
Click here to see thousands of 'Abandoned and Neglected' Jeeps rotting away...
SKT is online now   Reply With Quote Quick reply to this message
Unread 02-08-2011, 10:21 PM   #167
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Fixed a bunch of pictures that were broken. For your viewing enjoyment
After I recuperate some of the savings I spent on the shop cost, I'll start buying some necessities.
Fuel cell straps
http://www.summitracing.com/parts/SUM-291220S-99/
I'm pretty sure I've decided on Auto Meter gauges with the stock dash. So what I'll probably do is buy a new dash to fit my Jeep, with only the steering column holes in it. I'd really like to keep the stock speedo, I'll have to do some research to see if I can do that or not.
Dash
http://www.jeep4x4center.com/product...umber=11144.10
Maybe something along these lines? Still not too sure
http://i222.photobucket.com/albums/d...e/DCP_1636.jpg
I'd like to keep it more along the lines of stock looking, maybe with some AutoMeter angled mounting cups
http://www.autometer.com/cat_mounts.aspx?sid=54
Or something combined like this, maybe used in conjunction with the stock MPH gauge?
http://www.sfxperformance.com/parts/AUM1310.htm#
I also found this post on CK5 about setting up a tach,
http://coloradok5.com/forums/showthr...=252178&page=9
Lots of general tips
http://www.jeepforum.com/forum/f22/o...-swap-1287392/
Shoot me some dash ideas!
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote Quick reply to this message
Unread 02-10-2011, 05:19 AM   #168
243
1978 FSJ Cherokee
WOW!!!!
Oh crap, I am late for work....
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 02-11-2011, 01:55 PM   #169
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Originally Posted by Jim1611 View Post
Hey Andy if you haven't seen any of Joe's welds, well he's pretty darn good at it. Glad he's close by.
Hey Jim, I'm pretty sure you read this thread every time I update it so I'll just ask here instead of PMing you. I want to stretch my rear axle about 4"-ish as soon as it gets out of the shop. Joe has already agreed to help me with the Jeep, just gotta ask if he'll help with the stretch.
My question, will your shackle hangars work if I mount the rear set on the outside of the rear bumper? They'll be mounted vertical instead of horizontal. Will that be a problem with the way they're designed? I'm ok with having them welded straight to the bumper if needed
Andy, KD8EIA
Unread 02-11-2011, 07:17 PM   #170
Jim1611
Jim1611's Avatar
You could make that work Andy. If you mount them vertically just keep in mind that the shackles themselves will need to have room to move past the hanger itself. That means you won't be able to have a tie block between the shackle plates. You would still hit on the frame they're bolted to though at some point. I'm going to look around at some of the stretched frames and see what I can find. I think with the right bracket this will work though and if it did you wouldn't have so much hanging behind the axle.
I am subscribed to your thread, just made my look at it this morning. Glad you're moving forward and let me know if I can help.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 02-11-2011, 09:25 PM   #171
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Here's what I'm thinking of, taken from Tony's 1,000,000,000 page thread
flatlander757's 03 TJ build/update thread
Keep in mind, my tires will be about half that size
Originally Posted by flatlander757 View Post
Andy, KD8EIA
Unread 02-12-2011, 06:37 AM   #172
243
1978 FSJ Cherokee
I think they would work fine if you cut the lower end off flush with the bumper and look better too.
How long do you expect the Jeep to be in the shop?
Unread 02-12-2011, 08:48 AM   #173
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
If all goes well, (ie no motor rebuild), they say 1 more week. So I'll be realistic and say 2 weeks.
Andy, KD8EIA
Unread 03-01-2011, 05:16 PM   #174
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Shop called today, they started on it this morning. (3 weeks later...) He says he's going to rebuild the transmission, which I expected. When Eddie and I put the new main shaft in it wasn't exactly the best. We were in a hurry. That and the motor / wiring harness looks great. Thank God. I really didn't want to pay for a new harness.
He also says he ordered a clutch master / slave setup, accelerator cable, and some other small things. I think he said a dipstick and a small air filter for the right side valve cover. So no surprises yet. I knew all of that stuff needed ordered. Probably could have saved some money and ordered them myself but I didn't know what I was looking for and didn't want to order the wrong stuff.
Now that he's working on it, I hope to have it back in about a week or two!
Andy, KD8EIA
Unread 03-06-2011, 08:16 PM   #175
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Ahh, hopefully it'll be back to you soon (fingers crossed ).
Whenever you wanna stop by & do some plasma, drilling, grinding, welding, repeat, my garage is at your service.
Taylor wants to have me plasma a bumper & truss for his XJ. So the more the merrier.
Joe Dillard is offline   Reply With Quote Quick reply to this message
Unread 04-02-2011, 11:12 AM   #176
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Just dropped the Jeep off at M.I.T Drive train locally. They quoted me an estimate at just under $4k to finish it up and get it running. Not street legal, and not Cali legal, just running. I'm gonna head back over there in a few days and see if the price came down any. I supplied almost everything to get it running. They just need to install it and *hopefully not* rebuild the motor. Wish me luck!
Only 2 months later. Not too bad.
They fired the engine yesterday. Going to finish the wiring and I should have it by next weekend if all goes well
Andy, KD8EIA
Unread 04-07-2011, 03:15 PM   #177
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
I'll let the video do the talking
Andy, KD8EIA
Unread 04-07-2011, 04:00 PM   #178
cjFitz
1978 CJ7
Sweet! Congratulations!
[B][URL="http://www.jeepforum.com/forum/f22/cjfitzs-78-7-a-1179865/"]My CJ's Build Thread[/URL][/B]
cjFitz is offline   Reply With Quote Quick reply to this message
Unread 04-07-2011, 07:01 PM   #179
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Nice! Sounds good Andy!! It's always a satisfying moment to fire the engine for the first time.. sort of breathes new motivation into the project.. letting you "see the light at the end of the tunnel".
So what's the plans for the axles?
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote Quick reply to this message
Unread 04-07-2011, 07:24 PM   #180
Coiz
1979 CJ7
Very cool.
Mike
My build thread
Coiz is offline   Reply With Quote Quick reply to this message
