Project Cheap Jeep - Page 2 - JeepForum.com
post #16 of 17 Old 04-21-2012, 07:50 PM Thread Starter
tj98
Got the 8.8 under the Jeep finally, took two Saturdays. No problems with the install, I'm just slow and double checked everything.
With the East Coast Gear Supply brackets the 8.8 fits under the Jeep just like Ford intended it to. :mrgreen:
To bad you won't be able to see this under my stock height Jeep.
One clearance issue is the track bar mount, the rearend came with this bracket that has three holes in it. With my longest jackstand fully extended under the bracket and the right tire on the ground I'm 3/4" from hitting the bumpstop, the trackbar bracket is 1" from hitting the tub. I'm probably going to let it self clearance. If it causes a problem I'll cut a hole in the tub and build a tub for it.
I do have some driveline vibes under acceleration. From 20 - 40 mph it shakes pretty hard, light acceleration or steady state it isn't to bad. After 40 it smoothes out. I still plan to do a tummy tuck, sye, 1" BL and adjustable upper control arms next year. That should solve the vibes permanently, any suggestions for a short term patch?
The 8.8 has a longer pinion snout (?) than the D35 and is also offset 2.5" to the passenger side. It has a stock Jeep pinion angle.
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
14 JK Unlimited - Wife's
tj98 is offline
post #17 of 17 Old 05-10-2014, 06:00 PM Thread Starter
tj98
Sold. My son got a JK. I'm taking his 99 TJ.
4.0 Auto and A/C!
Oh and I kept the 8.8
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
tj98 is offline
Jeep SAS Project mikes_muse Jeep Builds 283 04-20-2013 06:04 PM
My JEEP Project hotrodzgarage Jeep Builds 10 06-03-2010 03:57 PM
My jeep project fatmanonalilbik Jeep Builds 1 01-31-2006 11:46 AM
jeep cj decoration project TonyTJ Jeep Builds 9 10-18-2003 02:22 PM
My Project Jeep! 81 CJ7 Quik26 Jeep Builds 11 01-09-2003 10:26 PM
