project Bumptastic - Page 66 - JeepForum.com
post #976 of 1200 Old 10-19-2013, 01:04 AM Thread Starter
TJdualsport
My kings are 250 and foxes 200. You should be good to go. You get em tuned by Wayne?
my dual sport build http://www.jeepforum.com/forum/f22/project-bumptastic-947070/
TJdualsport is offline
post #977 of 1200 Old 10-19-2013, 01:05 AM
MO2500
Originally Posted by motodude248
What psi do you have the shocks set at? I just put some on the front of my WJ set at 200 psi and I am not sure if it was enough or not.
Pretty sure Fox specs 200psi, that's what I charge mine to anyway.
Instagram: @omsmike
MO2500 is offline
post #978 of 1200 Old 10-19-2013, 03:59 PM
motodude248
I had them charged by a local company here in the valley. I have heard that Wayne does amazing work though. At 200psi I feel like they ride great at higher speeds, but a low speeds they clunk around a lot. I am pretty sure that is because of the bar pin eliminators. Going to have to think of some way to stop clunking.
motodude248 is offline
post #979 of 1200 Old 10-19-2013, 05:21 PM Thread Starter
TJdualsport
I don't run bar pin eliminators I've always had issues with em. Save up some $$ and send em to Wayne. Be the best 100 bucks you've spent on shocks ever.
post #980 of 1200 Old 10-19-2013, 05:27 PM
MO2500
Are you running shocks with spherical bearings with bar pin eliminators? Am I understanding that correctly? The Fox shocks like above are designed to be clamped between two tabs with a bolt and nut. Bar pin eliminators are used on shocks with poly/rubber bushings that originally had a bar pin.
Instagram: @omsmike
MO2500 is offline
post #981 of 1200 Old 10-19-2013, 05:32 PM Thread Starter
TJdualsport
My current setup is factory mounted. Bar pin and rubber and then stock stem tops... My shock will be available soon. $$
post #982 of 1200 Old 10-19-2013, 07:59 PM
motodude248
Yeah they have the spherical bushing on the bottom mount. I am using the ORW bushing and the JKS adapter for the top and a custom made bar pin eliminator for the bottom. I am going to have to redesign the bottom mount. I would like to cut off the stock mount and weld in some new shock mounts. But to not have a welder.
Tj I have been following your build for awhile and enjoy watching the work you do. I have always wanted to run the Mojave road, just don't think my Jeep is setup well enough yet. Keep up the great work on the Jeep and all the other trucks you work on.
post #983 of 1200 Old 10-19-2013, 10:28 PM Thread Starter
TJdualsport
Thanks man, there are some big changes coming that I'm stoked on. You wild be surprised how fast you could prolly go. You need help or parts getting your jeep together let me know. We do a run in early march where all vehicles are welcome stock to wild. You should come and check things out!
post #984 of 1200 Old 10-19-2013, 10:29 PM Thread Starter
TJdualsport
I'm here in Fullerton with a full service metal fab shop. Are you local?
post #985 of 1200 Old 10-20-2013, 12:48 AM Thread Starter
TJdualsport
I'm committed now...
post #986 of 1200 Old 10-20-2013, 12:48 AM
motodude248
I am up in Northridge, up off of the 405. About 1 1/2 hours north of you.
post #987 of 1200 Old 10-20-2013, 01:00 AM
IEcrawlerTJ01
Workin late huh hahah
Nice
My name is Andrew btw. Met you at Blaine's the other day (was wearing the bright shoes Blaine made fun of me for hahah)
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #988 of 1200 Old 10-20-2013, 01:09 AM Thread Starter
TJdualsport
Haha yup, it was to meet you guys. always good putting names to faces. I got a practice session out in the ocean tomorrow then back at it. You ever need anything fabbed up let me know.
post #989 of 1200 Old 10-20-2013, 01:14 AM
IEcrawlerTJ01
Haha Ya. Always cool meetin people from the forum
And Right on brotha. Might recruit your skills for a cage build one day
Pm inbound
Nuff said...
post #990 of 1200 Old 10-21-2013, 01:17 AM Thread Starter
TJdualsport
Hahaha. The boys stay till the truck leaves
Hello, My '07 JK Project... Liquor Jeep Builds 132 08-03-2014 08:40 PM
CJ5 Project redcj576 Jeep CJ Forum 148 05-26-2013 12:34 AM
yj project cage013 Jeep Builds 5 08-01-2011 12:40 PM
my project YJ confusedYJTJ Jeep Builds 6 10-26-2010 09:04 PM
my 97 project andrew383 Jeep Builds 7 09-19-2010 02:08 PM
