project Bumptastic - Page 50 - JeepForum.com
post #736 of 1201 Old 12-30-2012, 02:50 PM
wizzo
Where is the difficulty in the front end? I don't see a problem if I setup the ford towers and the shocks right anyway sorry for clogging up ur thread I'll pm
wizzo is offline
post #737 of 1201 Old 12-30-2012, 03:27 PM Thread Starter
TJdualsport
Keep clogging away I don't care. Easier then pm. Your springs unseating on droop. Bump steer ... Control arm contact . On compression your gonna have to keep an eye on your bump stops and trac bar. Setup your bumps and limit strap your droop when you get it all worked out.
my dual sport build http://www.jeepforum.com/forum/f22/project-bumptastic-947070/
TJdualsport is offline
post #738 of 1201 Old 12-30-2012, 09:49 PM
wizzo
Yeh for the bumps I will be setting and prothane's I've only read good things.. For the rear I will stick to 10 inch, I agree 12 inch would be hard, I think I could do it with decent travel up and down in the front though..
Then again I'm on short arms :P it's just for bragging rights haha
wizzo is offline
post #739 of 1201 Old 12-30-2012, 10:02 PM Thread Starter
TJdualsport
go for it man set it up. im not trying to talk you out of it. im just sayin its not as easy as popping them in.
post #740 of 1201 Old 12-30-2012, 10:54 PM
mJUSTINm
Front end will be limited by control arms contacting the lower shock mounts. Move the lower shock mounts to the lower control arm mount, shave the stock lower shock mount down for clearance, and go from there. The rear end will bind because of the track bar. I want to throw a double Johnny joint track bar on the rear and see what that gains me. I think with all that done, you could pull about 12".
-Justin
mJUSTINm is offline
post #741 of 1201 Old 12-31-2012, 12:32 AM Thread Starter
TJdualsport
post #742 of 1201 Old 12-31-2012, 01:15 AM
wizzo
Thanks for the info, I'm thinking about a rough country lon arm upgraded to currie johnny joints, but not sure bout the radius arms, getting stuff here is hard and u don't find much custom fabrication here.. Ill see way happens and keep u guys updated..
wizzo is offline
post #743 of 1201 Old 12-31-2012, 09:08 AM
mJUSTINm
Awesome pic Kevin. Saw the others on Facebook. Looks like it was a good trip, except for Brian. (That's his name, right?)
-Justin
mJUSTINm is offline
post #744 of 1201 Old 01-02-2013, 03:11 PM
wizzo
Tjduelsport do you mount any sort of top with ur tire carrier?
wizzo is offline
post #745 of 1201 Old 01-03-2013, 10:14 AM Thread Starter
TJdualsport
Yea my hard top fits, Velcro the glass shut. I wanna run a frameless soft top. I need a couple parts. Currently have a bikini top on. My tire carrier is completely easily removable.
post #746 of 1201 Old 01-03-2013, 07:09 PM
WJDesertRacer
Looks good. I want to go to mojave Ive never been up there. I still need to get my rear axle swapped out and driveshafts for 4wd. Are you planning on being at tierra del sol? I know another guy building a TTB xj who I was going to try and do a high speed run with
<a href=
WJ dual sport</a>
WJDesertRacer is offline
post #747 of 1201 Old 01-03-2013, 08:49 PM Thread Starter
TJdualsport
Ya man Mojave is some of the best. I have friends who Prerun all over and they love the run we do. Hours and hours of high speed... I need to do some change up on my jeep and after that let's go . I'll work with Justin on setting it up. We're for sure doing a death alley to Vegas run end of march
post #748 of 1201 Old 01-04-2013, 12:53 PM
mJUSTINm
Kevin, any dates yet for the Death Valley run?
-Justin
mJUSTINm is offline
post #749 of 1201 Old 01-04-2013, 07:59 PM Thread Starter
TJdualsport
End of march
post #750 of 1201 Old 01-04-2013, 08:09 PM
WJDesertRacer
Do you drive back to death valley or take road home from Vegas?
<a href=
WJ dual sport</a>
Hello, My '07 JK Project... Liquor Jeep Builds 132 08-03-2014 07:40 PM
CJ5 Project redcj576 Jeep CJ Forum 148 05-25-2013 11:34 PM
yj project cage013 Jeep Builds 5 08-01-2011 11:40 AM
my project YJ confusedYJTJ Jeep Builds 6 10-26-2010 08:04 PM
my 97 project andrew383 Jeep Builds 7 09-19-2010 01:08 PM
