project Bumptastic - Page 5 - JeepForum.com
post #61 of 1204 Old 03-29-2010, 10:30 AM Thread Starter
TJdualsport
YouTube - 100_0126.MOV
YouTube - 100_0124.MOV
TJdualsport is offline
post #62 of 1204 Old 03-29-2010, 11:49 AM
KnacK
Quick question:
On this vid: YouTube - GOPR0014.mov
What kind of camera setup did you use and do you have any pics of it on the side of your Jeep?
Chris
'88 YJ Laredo, Hardtop
Red
4.2L Auto 190k miles
3" Body Lift, Rancho Shocks, 31" Wranglers
Sagging springs
Bald tires
Blown tranny
Dead 4.2
Empty wallet
KnacK is offline
post #63 of 1204 Old 03-29-2010, 03:18 PM
slopoke36
How did hook up your headsets? Are they just for comms inside the vehicle?
92 YJ, 4.0L, 2.5" RC, 31x10.5 15 on Falken WildPeak A/T 15 x 8.5, Rear cargo rack, Ammo can console, CB, CD player w/soundbar, Hard /bikini tops. O|||O
slopoke36 is offline
post #64 of 1204 Old 03-29-2010, 08:08 PM Thread Starter
TJdualsport
I used the HD Go pro action camera. I had the suction cup mount on at that time and is what we usually use.
GoPro Official Store: Wearable Digital Cameras for Sports
On the intercom setup. its a system used in the airplane. Currently its hooked up to the passenger, ipod, cb and ham radio. I need to setup the PTT feature so i can transmit out of the head set to the radio.
I purchased the headsets and comm through ebay. its the avix 4000
A-4000 Intercom | World Wide Products Inc. | Intercoms
post #65 of 1204 Old 03-30-2010, 02:00 AM Thread Starter
TJdualsport
A on the fly video from mojave road over st patty weekend.
YouTube - Mojaveroad2010.wmv
post #66 of 1204 Old 03-30-2010, 02:21 AM
mJUSTINm
Cool video. Stuck on dropkick murphys lately? I like it!
-Justin
mJUSTINm is offline
post #67 of 1204 Old 03-31-2010, 12:15 AM Thread Starter
TJdualsport
hahaha yea I dont have much music on this laptop. but you cant go wrong with drop kick
post #68 of 1204 Old 03-31-2010, 01:35 AM
mJUSTINm
Never! Ever since I got into them I've wanted to see them in Boston on St. Patty's Day. You down?
Back on topic uh... Nice jeep? Haha
-Justin
mJUSTINm is offline
post #69 of 1204 Old 04-05-2010, 05:39 PM Thread Starter
TJdualsport
post #70 of 1204 Old 04-11-2010, 05:57 PM Thread Starter
TJdualsport
Version 2.0 is coming up quick. first step is rebuilding the 8.8 Limited slip. I picked up a rebuild kit for the LS for a few bucks. I figured id give it a shot before dropping in a locker. I rearranged the clutch pack in the LS to be alot more aggressive.
tonight they are soaking for the "break in" period in 80w90 semi synthetic.
you can see 2 of the stock LS clutches in the pick on the lower center of the pic. notice the bright shiney metal... yea those are toast.
the rest of V2.0 is trussing gusseting, 8.8 install, 2.0 bilstien bumps, shock relocation.. and prolly a few more other things as i go.
post #71 of 1204 Old 04-12-2010, 06:32 PM Thread Starter
TJdualsport
got back to it today, installed the spider gears. (pain in the ***) i opted to put the carrier back in the diff housing and use the axle shafts to help hold it all together while using them to turn the spiders to get everything into place. took a frew tries with the different shims but its in there really tight. (thats what she said)
Once i had the spiders in place i put the big spider pin in place to make sure it all lined up. next was the S spring. its a ***** too. I ended up using hose clamps to compress the "S" and then a BFH to tap it into place.
I had to adjust the S spring a few times to get the axles shaft in without any contact between the two.
I then removed the carrier to install the ring gear. I used a cross patter to get it in with damaging anything.
so here it how it sits. I need to get ahold of a good torque wrench to torque it all down. (mine is busted) then i can put my backing plates and harware in and then i gotta finish prepping the housing for the welding.
post #72 of 1204 Old 04-14-2010, 10:02 PM Thread Starter
TJdualsport
Got the gears in, axle shafts in, brake brackets and everything torqued down. I left the tone ring off since i use my TC with a speedo gear. does anyone know if it will affect anything by leaving it off (the tone ring) ?????
post #73 of 1204 Old 04-17-2010, 11:36 AM Thread Starter
TJdualsport
a on board video of my barstow to laughlin and back. the camera is attatched to my jeep at about 3:55
from Jason Gonderman on Vimeo.
post #74 of 1204 Old 04-19-2010, 06:46 PM Thread Starter
TJdualsport
new goodies arrived.. I heart the UPS man
some parts came in....
oooo yeaaaa
post #75 of 1204 Old 04-20-2010, 10:40 PM Thread Starter
TJdualsport
install is extremely straight foward and easy, i mounted the ballast under the horn and in front of the air box. crazy bright.
New Deltas
and HID!!!
Hello, My '07 JK Project... Liquor Jeep Builds 132 08-03-2014 07:40 PM
CJ5 Project redcj576 Jeep CJ Forum 148 05-25-2013 11:34 PM
yj project cage013 Jeep Builds 5 08-01-2011 11:40 AM
my project YJ confusedYJTJ Jeep Builds 6 10-26-2010 08:04 PM
my 97 project andrew383 Jeep Builds 7 09-19-2010 01:08 PM
