Project Black Sky - Page 4 - JeepForum.com
post #46 of 58 Old 05-20-2011, 10:16 AM Thread Starter
nm96xj
Originally Posted by mike1087 View Post
looks good man
Thanks!
I am saving for some 35's right now so it will fill in the empty wheel wells. 33's are not cutting it any more.
nm96xj is offline
post #47 of 58 Old 05-20-2011, 10:27 AM Thread Starter
nm96xj
so of course I had to get some flex pictures....
here is where I was before:
(blue circle is where I can now get to with the brackets)
here is where I can get to now. that blue circle is there as a reference:
and some more:
I tried doing it in reverse but the rear tire kept wanting to climb the wall...
Then I threw in a stock isolator leveling it out some.
an some cosmetics too. finally got the back retinted to a 5%
nm96xj is offline
post #48 of 58 Old 05-22-2011, 02:43 PM Thread Starter
nm96xj
just an updated list:
-1996 SE
-4.0/AX-15/231
Front Axle
-HP dana 30
-3.07 gearing
-Spicer U-Joints
-Spicer lower ball joints
-Speciality Alignment's Alignment upper Ball joints
-Gusseted Control Arm Mounts
-GMC c1500 Brake lines
-RC 8159 13" Shocks
-4.56
Rear Axle
-C8.25
-3.07
-ripped off and rewelded Shock Mounts
-Wrangler Rear Brake line
-RC 8160 12" Shocks
-4.56
-new shock mounts
Suspension
-6.5" RC coils with 1.5" Tera Flex Spacer and stock isolator
-4.5" RC Leafs with 1.75" Tera Flex shackle
-RC Adjustable Track Bar
-2" wheel base stretch
-RC Long arms
-RC Shackle Relocation Brackets
Tires/Wheels
-33x10.5r15 Super Swamper TSL Radial's
-Unique 297's 15x8 - 4" BS
-36x13.5r15 or 35x12.5r15 tires
Armor
-custom 3/8" front bumper
-Front Skid
-Tcase Skid
-custom rear bumper
-weld in sliders
Engine
-MSD Ignition
-Performance Injection Ev6 Injectors
-MSD 12mm plug wires
-Blast coil
-62mm Bored throttle body
-2.5" custom exhaust
-2 row radiator
-2/0 battery cables/grounds
Interior
-5% tinted window
-full custom mechanical gauges
-4 Diamond Audio Hex Component Speakers
-2 Rockford Fosgate Punch series 10" subs/amp
-Custom false floor
Misc
-custom roofrack
-Clearanced extended Yoke
-trimmed fenders
-trimmed rear quarters
-cobra CB
-102" S.S. whip CB antenna
-PA system
-4 Hella 550 front mounted lights with 100watt Super White bulbs/12awg wiring
-2 fog light rear mounted lights with 100watt Super White bulbs/12awg wiring
-removable doors
-full recovery gear and tool's
Black = current
Red = plans for the next 3-6 months
nm96xj is offline
post #49 of 58 Old 05-25-2011, 01:32 AM Thread Starter
nm96xj
Debating on if my jeep will look good with a front stinger...
Idea's?
Thoughts?
Comments?
nm96xj is offline
post #50 of 58 Old 05-25-2011, 11:25 AM Thread Starter
nm96xj
Okay SO I got my new Brake line installed and my new shocks installed!
I mean look at the difference :lol:
also believe it or not Butter is what I always use to instal bushings. why you might ask?
1) biodegradable
2) Cleans up easy
3) doesnt react or harm any bushing
4) any excess will melt away in the sun
5) cheap and available
6) works the best. I can install even the bar pins by hand..
nm96xj is offline
post #51 of 58 Old 05-25-2011, 12:40 PM
doogie
doogie's Avatar
Idea's?
Thoughts?
Comments?
I think you are tall enough and have enough tire to pull off a stinger. To me, that's what it takes to make a stinger look at home. This is one of my favorite stingers TNT Customs Stinger/Bumper but if it were on my Jeep as it sits....the bumper would be writing checks my XJ couldn't cash.
Nationalmssociety.org
Current = 1996 XJ, 2.5, 2-Door, 5-Speed, 4.88's, 3.5" Mix-N-Match, Black 15" KMC XD122's, 31" BFG AT's, RE QD's
Previous builds 99-XJ, 98-XJ, 89-XJ, 05-TJ, 95-ZJ, 79-J10
doogie is offline
post #52 of 58 Old 05-25-2011, 11:09 PM Thread Starter
nm96xj
Thanks for the feedback!
I would be adding on the front bumper. I mean 3/8" 3x6 steel is nice to have.
I can get one for about $60 shipped and just weld it on, I have a winch mount ready to go too but need a winch....
Also need 35's that I should be saving for
nm96xj is offline
post #53 of 58 Old 05-25-2011, 11:31 PM Thread Starter
nm96xj
UH!!! I need my front brake lines to come in soon....
altho my 1ton dodge rear brake line works wonders!!! it is 6" longer than my yj line and 9" longer than stock. direct bolt in. This is at near full droop
and It seems as tho my new shocks were measured right too! you can see the passenger side one is near perfect compressed length and the drivers I think is near full droop
nm96xj is offline
post #54 of 58 Old 05-26-2011, 10:41 AM Thread Starter
nm96xj
Picked up 2 Grand Cherokee Upper Control Arm Bushings because mine disappeared... I have about 10% of the bushing left so the bar is smacking around in the mounts... How I dont have death wobble I dont know....
Grand cherokee bushings have the solid bolt sleeve where the regular cherokees have a big bolt sleeve that has little bumps in it to center the bolt.
nm96xj is offline
post #55 of 58 Old 05-26-2011, 11:29 AM Thread Starter
nm96xj
also did a quick shake down run (which is where I found out my bushings were bad). nothing to hard just something to shake the bolts loose real good so I can do a final torque
nm96xj is offline
post #56 of 58 Old 05-26-2011, 09:52 PM Thread Starter
nm96xj
So I took the new ones and drilled them out to 1/2" hardware because of these....
only 1 hour to instal one side..... I will go in the morning to instal the other side....
These things are the biggest pain in the *** to change....
nm96xj is offline
post #57 of 58 Old 05-27-2011, 10:15 AM Thread Starter
nm96xj
Alright So this is how I replaced my UCA Bushings.
First you take your control arm and remove the bolt:
then you put it up and out of the way:
then you take your All joint press and pop it out: (mind you on the drivers side I had to use a 1 5/16" socket on the end to push it all the way thru)
then once removed set your new one in:
and then press it all the way in:
and once it is seated bolt it all the way back up: (i drilled out the "bumps" and then used 1/2" hardware on mine)
Install time was just over an hour on the drivers side about 20 minutes on the passenger side
also found some new rock rash!
nm96xj is offline
post #58 of 58 Old 05-31-2011, 12:15 PM Thread Starter
nm96xj
So I did a bit of wheeling yesterday and
full damage report
leaky axle seals
I dont know how I hit the drag link
I dont know how I hit the exhaust either
flexed and cracked the rear hatch
nm96xj is offline
Project "Blue & Black YJ". My '91 YJ Build. Matt Graham Jeep Builds 305 03-12-2014 11:43 AM
want to see how a black tj looks with black light bezels and black trim grill inserts Dutra177 Jeep Picture Requests 33 01-21-2014 11:13 PM
Black TJ Black Top Black Wheels on 33's TigerSpeed Jeep Picture Requests 13 03-07-2011 09:56 PM
Project Black XJ. Pacifier Jeep Builds 49 02-05-2011 03:57 PM
Project Black Pearl sean924 Jeep Builds 3 02-07-2010 12:59 PM
