Project Black Sky - JeepForum.com
post #1 of 58 Old 02-22-2011, 11:58 AM Thread Starter
nm96xj
Project Black Sky
Since joining the forum Thought I would show you guys my build thread.
It has been a 3-4 year progression. So I will give photo updates and hope you follow along. I will give stock specs and post up current specs at the end.
Well back in aug. 2006 I bought my cherokee from my cross country coach for $2000. It was bone stock with 123,xxx and had every receipt from anything done on the jeep.
1996 jeep cherokee, HO 4.0, HP D30/CHRY 8.35, NP231, 3.07's
gave it a sound system
Diamond Audio HEX components in the doors, and Rockford Fosgate Subs in the rear with a very nice kenwood deck!
got some tint on the windows and tested it out as a stocker:
I needed a new cat so i redid the whole exhaust in the 2.5" flavor
nm96xj is offline
post #2 of 58 Old 02-22-2011, 12:02 PM Thread Starter
nm96xj
It was time for some new rubber;
and I wheeled it... and broke it
so took it the shop and had Big Bill weld it (i was still learning and didnt trust myself enough to do it)
nm96xj is offline
post #3 of 58 Old 02-22-2011, 12:07 PM Thread Starter
nm96xj
Then it was time for some new cleats. 15x8 with 4" bs
with the added back spacing it was cutting my tires and tearing the fenders up while wheeling
so i trimmed (young and dumb cinder blocks)
time for some new gauges
and a PA system
nm96xj is offline
post #4 of 58 Old 02-22-2011, 12:09 PM Thread Starter
nm96xj
Then I took my newly found welding skill and made a roof rack
lost the rear swap bar and made a bastard pac
nm96xj is offline
post #5 of 58 Old 02-22-2011, 12:11 PM Thread Starter
nm96xj
Then I tested it out
and that leaves me here
nm96xj is offline
post #6 of 58 Old 02-22-2011, 12:14 PM Thread Starter
nm96xj
I decided i needed to make MAJOR improvements on the rack so I made a new one
and i used it
And i made a hitch rack as well
then needed to upgrade the shoes again
33x10.5 radials
and i used them
nm96xj is offline
post #7 of 58 Old 02-22-2011, 12:18 PM Thread Starter
nm96xj
got stuck for the first time and lack of tow points got the better of my bumper
so i temporarily made a new one and remounted my hi lift
And I decided I wanted tinted lenses
got a new to me sound bar and redid it
also needed more storage
remounted my gauges (all mechanical)
and got a new center console
nm96xj is offline
post #8 of 58 Old 02-22-2011, 12:26 PM Thread Starter
nm96xj
got a piece of 3x6x3/8" (1 gauge) steel for $32 so i made a bumper out of is with 1/4" mounting plates and gussets
welded a ball hitch all the way thru the bumper for a tow point. and made sure it was welded on both sides
then started rewiring
nm96xj is offline
post #9 of 58 Old 02-22-2011, 12:26 PM Thread Starter
nm96xj
power box
nm96xj is offline
post #10 of 58 Old 02-22-2011, 12:30 PM Thread Starter
nm96xj
got rid of the stock control arms and got some new super flex Rubicon Express adjustable upper and lowers
attempted to bore my own throttle body:
had to get a new one and the JY only had a 94 so i had to improvise on the MAP sensor location
drilled out a zerk fitting
big bill showed me how i should have done it...
made a new butterfly
then did the cut and fold
nm96xj is offline
post #11 of 58 Old 02-22-2011, 12:33 PM Thread Starter
nm96xj
And then I got a little ambitious
nm96xj is offline
post #12 of 58 Old 02-22-2011, 12:36 PM Thread Starter
nm96xj
rear cargo area with extention piece
and went removable doors
pretty much brings me up to date at that time.
so here is a list of what i have....and what i want
Engine:
173,xxx miles
62 mm throttle body
intake
62 mm 1" spacer(i know it doesnt do anything.... but)
MSD ignition system
12mm spark plug wires
copper spark plugs
Ev6 Injectors
800 CCA battery
2/0 battery cable
6ga aux box wiring
2.5" full custom exhaust
505 performance 5.0L Stroker rebuild
OBA
Middle Drivetrain:
AX-15 5 speed with centerforce double friction clutch
NP231
1" extended drieshaft
SYE with front driveshaft
Axles:
Dana 30
3.07 gearing open
Beefed up LCA mounts
adjustable upper and lower control arms
5" longer brake lines
wj brake/knuckle swap
4.56 gearing
ARB Locker
Chrysler copr 8.25"
3.07 gearing open
Disk Brake swap
29 spline shafts/carrier
4.56 gearing
ARB locker
soft 8's
33x10.5" radial super swamper tires
35's
interior:
5% tinted windows
aftermarket gauges
00 center console swap
switch panel
CB
PA
Sound Box
sound system that THUMPS
false floor/cargo floor
Mag Lite mount
fire extinguisher
steam cleaned twice a year
exterior
highlift
roof rack
4-100 watt forward facing roof lights
2-100 watt rear facing fog lights
STICKERS
armor:
3/8" thick front bumper
front end skid
rear bumper
transfer skid
gas tank skid
weld in rocker guards
Winch
suspension
RE adjustable upper and lower control arms
full leaf packs with Tera Flex Lift shackle
coils with spacers
new proper front coils
long arms!
nm96xj is offline
post #13 of 58 Old 02-22-2011, 12:40 PM Thread Starter
nm96xj
flexed it some and mall crawled
got a new front skid
made quick discos for the door
mounted my hi lift
and then proceeded to roll it
nm96xj is offline
post #14 of 58 Old 02-22-2011, 12:42 PM Thread Starter
nm96xj
so i took the chance to clean the interior completely
and it sat for a while as i waited for parts
nm96xj is offline
post #15 of 58 Old 02-22-2011, 12:43 PM
frAnken_rubi
Nice build
/l o[____]o
l---L --OlllllllO-
()_)-()_)-o-)_)
http://www.jeepforum.com/forum/f22/frankin_rubi-tj-build-1140219
frAnken_rubi is offline
Project "Blue & Black YJ". My '91 YJ Build. Matt Graham Jeep Builds 305 03-12-2014 11:43 AM
want to see how a black tj looks with black light bezels and black trim grill inserts Dutra177 Jeep Picture Requests 33 01-21-2014 11:13 PM
Black TJ Black Top Black Wheels on 33's TigerSpeed Jeep Picture Requests 13 03-07-2011 09:56 PM
Project Black XJ. Pacifier Jeep Builds 49 02-05-2011 03:57 PM
Project Black Pearl sean924 Jeep Builds 3 02-07-2010 12:59 PM
