Project: 98 ZJ Polar Edition - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Project: 98 ZJ Polar Edition
The Original 3/8" Ruffstuff Diff Cover!The Cure for your Tie Rod Roll!1976-1986 Jeep CJ7 with Stationary Vent Windows Weatherstr
Unread 04-17-2015, 10:57 AM   #1
jayheats
So I got this jeep with only 80,000 miles on it. Time to start building it
1998 White Grand Cherokee
jayheats is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 10:59 AM   #2
jayheats
First I put a RC 3.5 kit on, adj upper control arms, new front track bar, track bar drop bracket. This is how it looks
Unread 04-17-2015, 11:00 AM   #3
jayheats
Tried on a set of JK wheels
I loved the way these wheels looked, but after driving it for a while I decided that the 2 in wheel spacers didn't give me the solid ride feel I wanted. These things have to be centered absolutely perfect or else.. vibration. What is causing the vibration, is it a bad bushing, ball joint, track bar, wheel bearing? Just one more thing to put in the equation... In the end I decided to remove them.
Unread 04-17-2015, 01:28 PM   #4
jayheats
After the JK Wheels I went down and got a set of new rims and some 31in duratracs. They ride pretty well. Mild growling howling sound going down the freeway. I have had mudders that are way worse. These are a 15x7.5 with 3.75 backspacing
Unread 04-17-2015, 01:32 PM   #5
jayheats
Decided to build a low profile roof rack. Used the cover plate from a JK and some painted unistrut. I love this stuff because when I put the mountain boards on the roof I can connect the bungees anywhere.
Unread 04-17-2015, 01:40 PM   #6
jayheats
Built some tow points and mounted them to the factory tow plate brackets.
Unread 04-17-2015, 01:45 PM   #7
jayheats
After 8 months of driving on the RC 3.5 kit... I have decided I'm done. The RC 3.5 lift kit is just too stiff. A week later I lowered the Jeep down to a 2bb, stock control arms, rancho 9000 adj shocks and It rides WAY better... Only problem now is that the jeep is lower, so chances are the 3.75 backspacing on the rims is going to cause fender stuffing issues.
Here is a pic of the ZJ with a 2BB
