Pre5tig3's 91 XJ Build - Page 5 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Pre5tig3's 91 XJ Build
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-19-2011, 08:04 PM   #61
Pre5tig3
1991 XJ Cherokee
91 XJ 5" 35s c4x4 winch bumper IRO long arms (The wheeler)
96 Volvo 850 t5 wagon
1969 c20
Pre5tig3 is offline   Reply With Quote Quick reply to this message
Unread 05-28-2011, 10:10 PM   #62
Pre5tig3
1991 XJ Cherokee
Broke a bolt holding the sway bar on the driver side need to drill out and get a new bolt. Also looking into a jar stage 3 bumper not sure if I want the loop or not.
1969 c20
Unread 05-31-2011, 07:56 PM   #63
Pre5tig3
1991 XJ Cherokee
I sold my 86 cutlass so this build is about to start really moving heres what the plans are in the near future.
-Desert Tan paint
-Painting the outlaws II's Black along with the grill
-Hood on with lebaron vents and hood pins
-33's the so called 31's aka 29's are looking small hope I can get most my money back or use them tell there done.
-Re gear 4.10s maybe 4.56s
-splice tcu wires so trans works(DONE)
-trans flush and diff oil change
-dynomax exhaust ( straight pipe is getting to loud)
-Jcr front a rear bumpers
That should do it for a little bit maybe Ill eventually get to make it a DD with 35s.
1969 c20
Unread 05-31-2011, 07:58 PM   #64
ajamison
1991 MJ Comanche
looks good i like it a lot!
ajamison is offline   Reply With Quote Quick reply to this message
Unread 05-31-2011, 09:48 PM   #65
Pre5tig3
1991 XJ Cherokee
Thanks man I've probally looked through your build atleast a dozen times sence I bought mine.
1969 c20
Unread 06-01-2011, 02:24 PM   #66
Pre5tig3
1991 XJ Cherokee
Finally got around to spliceing the wires to the TCU and now it shifts and have 2nd gear what a difference that makes in power and hopfully a little better mpg.
1969 c20
Unread 06-02-2011, 03:47 PM   #67
Pre5tig3
1991 XJ Cherokee
1969 c20
Unread 06-02-2011, 09:05 PM   #68
Pre5tig3
1991 XJ Cherokee
Tore out the headliner couldn't stand it rubbing on my head only problem now is the temp thing on the roof vibrates and looks funny might have to do something or remove it all together.
1969 c20
Unread 06-09-2011, 10:53 AM   #69
Pre5tig3
1991 XJ Cherokee
Havnt been doing much to it latley besides filling it with gas but I did get around to removing the pin stripes and washing it.
1969 c20
Unread 06-14-2011, 01:59 PM   #70
Pre5tig3
1991 XJ Cherokee
Today I replaced my sway bar links bushings and fixed the broken bolt so I can actually use the sway bar as a DD with it disconeccted was scary.
Also been kicking the idea around of getting the RC shackle relocation bracket because my shackles are vertical and plus a extra inch would be nice than re instal my spacers up fron to sit a 5" but then will need new shocks that I just bought less than a 1000 miles ago. =/
1969 c20
Unread 06-15-2011, 04:50 PM   #71
Pre5tig3
1991 XJ Cherokee
So im getting ready for the weekend fishing trip with my buddy up by my cabin. He never been wheeling of any sort so Im going to show him how its done but last time I was banging the front up so I finally got around installing my front skid ( what a PITA to put in yourself) but now have some good front protection.
1969 c20
Unread 06-21-2011, 05:09 PM   #72
Pre5tig3
1991 XJ Cherokee
Finally got to do some good wheeling but got some trail damage broke my passenger mirror and the marker light.
1969 c20
Unread 06-22-2011, 03:15 PM   #73
Pre5tig3
1991 XJ Cherokee
Well Im very tempted on getting a RC relocation bracket or making my own So im guessing maybe a inch of lift out of that so sitting 4.5" in the rear with the 2" ome leafs 1.5" shackles and the bracket and then putting the 2" spacer up front so 5" in the front and use the 3" travel shocks for a while and try not to over flex them.
Seems like you can never be big enough I want to re gear and locker soon alsothe list is getting biggeer by the day.
1969 c20
Unread 06-23-2011, 05:39 PM   #74
Pre5tig3
1991 XJ Cherokee
So I been trying to get some of my friends into jeeps or any wheeling of the sort I told my buddy I will sell him my tires if he buys a jeep for a steal so I have a reason to get 33's or 32's
1969 c20
Unread 06-23-2011, 07:16 PM   #75
Pre5tig3
1991 XJ Cherokee
time to go to the upull again to get some parts
97+ mirrors
v8 ZJ Tie rods
seat belt
window cranks for the back doors
maybe a brush gaurd for now to protect the front.
1969 c20
