Pond Scum - Page 7 - JeepForum.com
 2Likes
post #91 of 215 Old 03-01-2014, 08:49 AM Thread Starter
Ben
Originally Posted by contdevelop View Post
Did you have schematics to go by for the wiring? Or how did you figure that out?
I have the 1998 TJ FSM that's quite simple to find online.
On the motor side, I used LT1Swap.com. I ended up sending him the PCM too, I figured with as much info as he has, he's gotta know what he's doing, and I kinda felt like for as much as I used his website, sending him $75 for PCM programming was the least I could do as thanks.
http://lt1swap.com/2000harness.htm
The guy has tons of info up, pin out for every connector, info on what's needed and not needed, and he even has a bunch of wiring diagrams hosted, for example:
Ben is offline
post #92 of 215 Old 03-03-2014, 10:06 AM Thread Starter
Ben
Got the radiator mounted.
Tight fit...
Ben is offline
post #93 of 215 Old 03-03-2014, 07:00 PM
jmhall79
Couple questions about your wheels: Are they Pro Comp 1069's with 4.75 backspacing and 9" wide? If so are you getting any rubbing? I am getting either the 1069's in 17x9 4.75" BS or Mickey T's Classic 3 4.5" BS on my TJ SE. I would rather go 1069's as they are 200 cheaper for 5 but do want it to rub. Diggin the build come on warm weather!!!!!
jmhall79 is offline
post #94 of 215 Old 03-04-2014, 07:58 AM Thread Starter
Ben
Thanks.
Yep that's exactly what they are.
At full lock, they touch the LCA and the antirock, but just barely. I haven't done anything about it, because with tube lowers I just use them as the stop and don't push the steering so far.
My front axle is maybe 1.5-2" forward, so you might find with the axle in the stock location that at full stuff the 35s would rub the back of the inner fender.
No rubbing at all in the rear, with the 8.8 and no wheel spacers.
Shoot, I'll be out your way this weekend. Taking a little time away from doing this every weekend to get some snowboarding in at Vail & A basin.
Ben is offline
post #95 of 215 Old 03-11-2014, 09:59 AM Thread Starter
Ben
No Jeep love this past weekend, went to Arapahoe Basin, which I guess is very close to the Holy Cross trail.
Anyway, back to the grind. I ordered a clutch master cylinder, a straight waterpump inlet, and picked up some brake line and a ford solenoid at NAPA.
Ben is offline
post #96 of 215 Old 03-18-2014, 07:24 AM Thread Starter
Ben
The wiring continues. I knew it would be a lot of wiring. Sure didn't see it being 2 months of wiring.
Oh well, ECU is mounted, intake is in, MAF is in and wired back to ECU (had to take apart loom to do that, bummer).
Not done the wiring, but getting very close to it.
I drew this up. Been trolling craigslist for AutoMeter Ultra Lite gauges. Good things are in the works here:
Ben is offline
post #97 of 215 Old 03-18-2014, 12:30 PM Thread Starter
Ben
Ben is offline
post #98 of 215 Old 04-02-2014, 10:56 AM Thread Starter
Ben
**** this.
The clutch master is ****ed, the metal body edelbrock just doesn't work without serious modification to either the firewall or pedal box, possibly both. So I'm steppin back from that, gonna try the TJ master with the Novak brass connector that converts it to brake line, which I guess I should have done in the first place.
The power steering cooler is in, all plumbed up, filled with fluid (and I'm sure this will surprise Steve) it ****ing leaks everywhere. The reservoir leaks at the stupid cast in fitting, the gear leaks at the pitman arm, there's ****ing steering fluid coming out everywhere.
I made a kick ****ing *** shifter handle then realized I'm a dickhead and that there's a spring & collar that slide down over it, but won't slide down over it with my cute/stupid brass knuckle gusset ****ing thing on there so that got cut all to ****ing hell.
And I'm still ****ing soldering things to things. There was a point yesterday where I hopped in the driver seat expecting to hear the key actuate the starter, and instead hear the lovely sound of silence. So that sucks ***.
Ben is offline
post #99 of 215 Old 04-03-2014, 12:30 PM Thread Starter
Ben
lovely lunch at the junkyard.
got a XJ front shaft in piss poor condition ripe for the M18 treatment.
got 2 electric fans, 1 yet unknown, and 1 dual fan from a windstar with the wiring and dual 60A relay bank
Ben is offline
post #100 of 215 Old 04-04-2014, 07:57 AM
TheBlueKJ
2003 KJ Liberty
Sounds like your having all sorts of fun over there. Just hang in there it will get better eventually
Blue 2003 Jeep Liberty Sport 4x4 Lifted, Front OME 790s/Bilstien, Custom Rear; 245/75/16 A/Ts KC Daylighters
thread)
TheBlueKJ is offline
post #101 of 215 Old 04-05-2014, 06:33 PM Thread Starter
Ben
Packed up the back half kit and put it away. I can't do that now or I'm never going to finish. So the tank is going in in a not permanent place. Still had to rework the shocks though, so the shock crossmember, rear crossmember and everything fit nicely.
The top is mounted in pretty much the same spot, just rotated 90, and a little tighter to the frame rail, and that gives me 31" between them, plenty of room for a 30" tank with a 3/16ths mount. Yeah I'm re-using those POS shocks for now. Wanna fight about it? It's got maybe 3" up and 3" down. Come at me bro.
This will get a cover on top, the whole floor will be redone eventually about 5" above the existing one. But that will be later, all that matters now is getting the tank hung and fuel lines in.
Ben is offline
post #102 of 215 Old 04-06-2014, 05:10 PM
MattSteve
What fuel cell is that? I tried looking, but couldn't find any info. That setup looks exactly how I want to eventually set something up.
Other than that, your build is looking great!
MattSteve is offline
post #103 of 215 Old 04-06-2014, 05:42 PM Thread Starter
Ben
RCI2162A, it's 30"l x 12"w x 9"h
Ben is offline
post #104 of 215 Old 04-07-2014, 07:20 AM Thread Starter
Ben
fuel lines are in, coiled at the tank area, waiting on the fuel cell mount.
dash is in, key on hot powers it up via the new fuse block. key all the way bumps the starter.
Short list:
spark plug wires
oil & filter
switch out oil pressure sender
gas tank mount
Ben is offline
post #105 of 215 Old 04-15-2014, 01:35 PM Thread Starter
Ben
I got 2 of these hanging from the stock crossmember, it's 1/4" x 1" bar, it bolts onto a same size bar that runs across to the back bumper, and combine they support the tank.
Thoughts?
The bottom sits flush with the top of the rear crossmember:
Tank sits here:
Also, replaced the stock oil pressure sensor with this, it's got the autometer sender and a gauge:
Ben is offline
Dredged my Pond today!!!! ronprice Jeep Builds 4 10-02-2007 07:28 PM
