Poison Spyder Build TJ - Page 3 - JeepForum.com
post #31 of 1108 Old 01-23-2012, 10:19 PM Thread Starter
Driver831
So I put in my order for all new front axle truss and bracketry work for the new axles. T & T Customs were great at working with me on exactly what i needed. I definitely recommend them if your looking for axle parts, trusses or brackets!
http://www.tntcustoms.com/axleanddrivetrain.aspx
Took the Jeep out for a midnight run to test out the Long Arm. It worked GREAT. SMOOTH ride!
Driver831 is offline
post #32 of 1108 Old 01-31-2012, 12:30 AM Thread Starter
Driver831
Got the order in from T&T Customs a few days ago. the front HP44 Truss looks sweet! built in Rock Krawler driver upper mount housing for it. best thing about it is the option to push the axle forward with eas of moving the spring buckets back up to 2.5"!! may have to do this for the 42" fitment! haha. also picked up the tires and rims with axles today. all and all my roommate was right.. Its like Christmas ever 2 weeks here. The UPS guy knows me by name ha
gotta clean up axles, torch off everything and the mounts for new trusses front and rear. also rerunning brake lines and changing dif covers. ha i don't do chrome...
For Specs Axles have 4.88 Motive Gears and Posi front and rear. Rear is about to get a Detroit tho.. don't like posi in rear ends.. i dunno why.
42" Goodyear MT Kevlars on 17X10 Eagle Aluminum rims. got a lot of work ahead for this month. possible cage coming and Rigid lighting????? no idea
post #33 of 1108 Old 01-31-2012, 11:04 PM Thread Starter
Driver831
So my garage is a complete mess! I hate working in a mess cause I trip over EVERYTHING! Hacked off axle brackets to ready the new truss for the front. I have to decide how far forward I want to move the front axle. Emailed Jeremy at Rock Krawler about the limits of the 5.5 Long Arm. I'm hoping for at least 1" to an 1.25" may not seem like much... but makes ALL the difference with the short wheel base. Also need to decide on a Steering stabilizer bracket to mount on the truss from T&T Customs. haven't quite figured that one out. I have 1 month to get axles under it, exhaust re ran, drive shafts, steering, and brakes. along with the 523466 other little things ha.
Don't let people tell you an axle swap is cake work. Getting all your angles correct, tac welding, removal to fully weld then to powder coat housing. I hope its ready for March Madness at 4WheelParts Orlando FL. thes the only thing that's killing me is I know I have a time limit. School is kicking my butt right now and work sucks. Engineering and Math major's I don't wish upon anyone.
blah blah just rambling..
post #34 of 1108 Old 01-31-2012, 11:14 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
a 44 and an 8.8 for 42s?
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #35 of 1108 Old 01-31-2012, 11:31 PM Thread Starter
Driver831
42"s aren't permanent I promise! They came on the rims so I figured I'd ride out for a few weeks till i get the 37"s I want for the 17X10" rims.. My old rims lug pattern won't bolt up to the new axles
post #36 of 1108 Old 02-02-2012, 02:01 AM Thread Starter
Driver831
Wake up, fo to class, then go to work, then spend the whole night working on the Jeep.. Guess I wouldn't have it any other way. ha
Started the removal of the front axle today and this evening. Glad I have an awesome assortment of jacks and cinder blocks. My appt complex is just gonna love me... Old bump stops are SHOT. ha Half was already rotted away. Out goes the rest of the Procomp lift and in the the Rock Krawler springs and pads. T&T Customs did a killer job on the truss for this 44, just have to decide where I want my stabilizer for the steering. Haven't decided yet. Also need to get a drag link for the pitman arm to the pass tire.
The 44 looks so pretty under the TJ even not painted or welded it just looks like it belongs.
Test Friday in Thermo 2. looks like I got a few days off
post #37 of 1108 Old 02-02-2012, 08:21 PM Thread Starter
Driver831
So I lied.. This morning I woke up super early to get the front somewhat in position. Shocks on, trackbar in place, upper arm adjusted correctly, and wala! 42" tires clear in the front!
post #38 of 1108 Old 02-07-2012, 09:19 PM Thread Starter
Driver831
God school sucks! Tests come at the worse time, so does work. I'm startin to stress out about this build with everything colliding together on me. Appt complex is NOT happy with the current state of the build
Got the notice on the door today, so I put the old axle under it but still on jacks. Front end should be here tomorrow from River City Powder Coat. But Structures test thurs, and Thermo quiz Fri, also work all weekend. Test in Vector Analysis Wend. I'm kinda in tweak mode! Remember I have till march 10th to have this thing 100% mobile, I gotta get it together!
Now that I'm done venting... Figured sense I'm taking rotors off to get axle done I'll replace seals bearings and use my rotor machine that has been collecting dust. also to be "cost efficient" I'm (FOR NOW) going with a 'bastard joint' for my drive shafts. Just to cut cost right now and put it into something I can't simple fix. Using all National seals and bearings.. I figure sense its already all apart, I might as well put new in it now, not 75mph on the highway haha
On final tacking on the truss I went with a 7-8 degree caster, stock is 7. wanted to go 5, but wanted a window of error in case my gage is off or not on level ground surface. I'm happy with my decision tho.
post #39 of 1108 Old 02-14-2012, 02:16 AM Thread Starter
Driver831
Got the front end modded in, everything lined up just as I expected! ha would post a picture of it but since the appt complex came down on me, I had to move my operation into the garage, space is tight! Went with a 18 degree pinion angle for the 8.8. With this angle the only drive shaft angle is at the double cardon on the SYE at the T-case.
Going with the triangulated 4 link rear im doing away with a rear sway bar as well as a track bar. In doing this tho i had to remove exhaust to make the upper arms work. Exhaust also hits front drive shaft.. this needs to be addressed with a few other minute things.
Rear end is at the powder coater and should have back in the next few days.. test Wednesday and hopefully this weekend it will be back on the road for a madin voyage! well without exhaust lol. but driving!
post #40 of 1108 Old 02-16-2012, 12:12 AM Thread Starter
Driver831
In the process of touching up a few loose ends while the rear ends is getting powder coated Cleaning up the undercarriage and painting the belly to black it out. Wourth SKS Undercoating. Trying to get some measurements on my new exhaust setup. Going with a smaller cat and muffler. I'm thinking Magnaflow or Banks for exhaust.. Haven't decided yet. Also setting up some steering angles and numbers for cromo steering. Going OTK with it!
Failed my Vector Analysis test today.. but hey! The Jeeps moving along nice! LOL!
post #41 of 1108 Old 02-16-2012, 09:15 AM
2003X
Great update, coming along nicely.
My Build
2003X is offline
post #42 of 1108 Old 02-16-2012, 04:25 PM Thread Starter
Driver831
Looking at what I have to do for my exhaust system revamp. With the HP44 the front drive shaft hits the exhaust coming off the manifold that runs down the oil pan. Also the cat is squeezes in between the frame mount and the transmission. With the triangulated 4 link like I said, its gotta get reran.
On another note I am doing some upgrades on the drives hafts to convert them to the flange style yoke and D44 front yoke
post #43 of 1108 Old 02-16-2012, 04:46 PM
97jeepsport
subscribed nice looking jeep !
97jeepsport is offline
post #44 of 1108 Old 02-17-2012, 10:44 PM Thread Starter
Driver831
Ordered brake lines today, thinking of running them through the rear truss.
Think that would be the best way to keep them out of the way of everything. Playing the waiting game on parts.. Time to enjoy a Fri night and chill!
post #45 of 1108 Old 02-17-2012, 11:01 PM
Bama_WJ
Shame you had to give up on the one tons. Build is looking awesome otherwise! Very nice TJ.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
TJ Poison Spyder BFH or Stinger Seal Jeep Picture Requests 5 08-02-2013 01:14 PM
poison spyder rockers WhiteRuby06 Jeep Picture Requests 40 08-21-2011 10:24 AM
poison spyder custom 08rubi Jeep Picture Requests 0 12-15-2009 04:05 PM
poison spyder rockers chandlerr Jeep Picture Requests 0 01-22-2007 06:44 AM
Poison Spyder Rockers TERPS Jeep Picture Requests 7 08-03-2006 05:09 PM
