Plus 1 horse power: The after build - Page 6 - JeepForum.com
post #76 of 432 Old 03-30-2014, 10:02 PM
Maertz
2009 JK Wrangler
Originally Posted by awinski View Post
alright guys heres my write up on the stretch.
started out by getting the jeep up on jack stands and getting everything disconnected from the axle and frame aside from the brake lines. moved the axle out of the way
then we moved on to cutting out the coil buckets, shock mounts, and old cross member with the plasma. later went back and used a cut off wheel to get all of the welds and remaining scraps
put the links in, got the pinion angle, made our new cross member made out of 2x3 3/16" steel with the coil buckets and moved it into position. tacked it in place and checked everything out. at ride height.
took the axle back out to weld the cross member in place and the control arms got a nice fat bead then painted.
put everything back in and got the shock mounts in, for now i am running the stock rubicon shocks because the compressed length of the fox's was just too much to find a nice place to fit them. this is also why the bump stop is set about 2" lower than it can be. later on ill either make the move to metal cloaks 6 packs. or king coil overs. if i use the metal cloaks ill simply use the same brackets, and take out the spacer i made, gaining another 2" of up travel. deciding between 12 or 14" travel. ill probably go with 12 since i honestly probably don't need 14" to run blacks at rausch and sometimes other places.
buddy got fox's for his cummins
lastly we got the corners all finished up, started with a paper template, then moved to the rubber liner, and lastly the aluminum.
used 1/4 20 stainless bolts and nutcerts from an amish store, think i payed $5 for that and the install tool. i liked the spacer they had for the install as it had a tapered end to keep the nutcert centered, a grade 8 bolt and some wd40 also helps.
drilled the body holes to 3/8" with a step bit, hammered in the nutcerts for a tight fit, also have to mention i got the idea to use jb weld on the nutcets and let me just say idk if it was that or a higher quality nutcert than what poison spyder uses, but i had absolutely no issues with spinning nut certs. completely happy with this turn out!
flares were the last, ill be making some steel ones soon, but this works for now lol. the garden edging was so i could get it passed by a local cop and get the warning signed.
getting used to driving it, but i'm completely happy with the turn out and it also rides a lot smoother, can't wait to test it out off road once i get new shocks.
im sure the first thing you noticed was the steering radius? next time you go off road you'll love it though i promise. sorry if i missed it, but you make your links? also im assuming you still have a track bar, or no?
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #77 of 432 Old 03-30-2014, 10:07 PM Thread Starter
awinski
yeap, made my own links, and still running the stock rear track bar. made a new bracket out of 3/16". don't have a pic of it, so i guess ill have to take one tomorrow and go back to edit
i did notice it around turns, not the radius, just the feeling i got, its like i could feel where the jeep was squating and the axle being back. it was the opposite when i first made the jump from the four door to the 2 door. hard to explain it, but i honestly don't notice any difference in parking lots etc. kinda weird to explain
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #78 of 432 Old 03-30-2014, 10:11 PM
Maertz
2009 JK Wrangler
nice toss some pics up! last bracket i want to cut off is the old coil perches, i have no torch though... but soon after i want to get my axles and such finally installed... also go 14" travel
Maertz is offline
post #79 of 432 Old 03-30-2014, 10:13 PM
Guns003
Any side pics with the flares on? I really want to see how that worked out. The back shot of your jeep looks so sweet btw
1995 YJ
35" Procomp MT2s, 5.5 inches of lift, RE 4.5 XD, Bilsteins, MORE body lift, Bumpers,TJ flat fender flares, HD steering, Durango steering box, ZJ 136amp alt, Ford 8.8 Rear, 4.56s
Guns003 is offline
post #80 of 432 Old 03-30-2014, 10:18 PM Thread Starter
awinski
will do, honestly the coil perch was the most annoying to cut off.
no side shots that i know of. it does look awkward since i didn't work the comp cut into the flare yet, i don't see a point as ill probably be making steel ones in the next two weeks
awinski is offline
post #81 of 432 Old 03-30-2014, 10:21 PM
Maertz
2009 JK Wrangler
yea i save it for last hoping id come across a torch.
Maertz is offline
post #82 of 432 Old 03-30-2014, 10:25 PM Thread Starter
awinski
on the second i cut the top weld from the wheel well with a grinder and cut off wheel, then used a pry bar, was much easier than torching like the other side honestly
awinski is offline
post #83 of 432 Old 03-30-2014, 10:29 PM
Maertz
2009 JK Wrangler
hmm i will have to look at that, thatll be my during the week project so i can get the axles back in over the weekend ....hopefully.
Maertz is offline
post #84 of 432 Old 04-02-2014, 12:56 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
Sharp
My builds:
and
or follow us on
spyder6 is offline
post #85 of 432 Old 04-02-2014, 01:26 PM
84jeepcj7rock
Nice looking build. How do you like your tire carrier. I want something I can remove easily and the wife wants a tailgate. It doesn't seem to hold the spare as high as the swing down bumpers which is nice cause I like to see out the back.
84jeepcj7rock is offline
post #86 of 432 Old 04-02-2014, 07:57 PM
Guns003
thanks alot man, its a decent bumper/carrier but your gonna have to mess with it and adjust it for it to be easy enough for your wife to use. Mine i have to like shoulder it and it doesnt swing that great but ive seen people with them at meets that it works great because they spent time adjusting it. Next time maybe comment on my build, dont like hijacking his thread.
1995 YJ
Guns003 is offline
post #87 of 432 Old 04-03-2014, 02:39 PM Thread Starter
awinski
Going to Rausch this sunday, won't be doing too much as I still have the stock shocks in the rear. A friend wants me to join him as it'll be his first time, so it'll mostly be blues and maybe I'll venture down some blacks. Anyone is welcome to join
awinski is offline
post #88 of 432 Old 04-04-2014, 10:38 PM Thread Starter
awinski
Small update for sunday, I'm now running trimmed 7" wide tj flares, also relocated my evap canister, don't really have any pics as of yet as its still in the super tiny garage.
awinski is offline
post #89 of 432 Old 04-04-2014, 10:46 PM
mtnbiker995
2009 JK Wrangler
TJ flares?? Why's that? Front or rear?
mtnbiker995 is offline
post #90 of 432 Old 04-04-2014, 10:49 PM
Maertz
2009 JK Wrangler
Tjs rape... Id do it...
Maertz is offline
jeep , jk , stretched , stretched jk , stretched two door
