painting dash pad - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > painting dash pad
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-29-2014, 11:32 AM   #1
neal90
1982 CJ7
painting dash pad
I have a spice / nutmeg not sure what the color is cauled but its the tanish looking dash that is now getting crackes all in it and I want to replace it. I have lookd and they are way more than I want to pay for one in good condition. So im going to get the gray paintable one from morris and paint. Whats the bast paint/color to use thanks
neal90 is offline   Reply With Quote
Unread 04-30-2014, 09:32 AM   #2
novotny242
I have a 97 TJ which had an all light gray interior that I hated. I painted everything black. I went with SEM's Color Coat over all of the competitors like DupliColor, etc. Just a personal preference from past experience using just about all of them out there on other projects. If you want a similar color to the spice color of your jeep you should order the Camel color. I sprayed my seats with it and it's a close match and more durable than the DupliColor equivalent. You should also check out www.paintscratch.com. You'll be able to get an OEM match from them. I have a black hard top that I plan to paint in the Spice color. I ordered the paint from them. You can get it in a rattle can or by the pint, quart, etc. Better quality and little more expensive but worth looking into. Good luck.
novotny242 is offline   Reply With Quote
